Old 08-31-2017, 01:44 AM   #10529
Aztec
Lost in the twisties
Aztec's Avatar
Drives: 2014 BRZ Dark Gray Metallic
Originally Posted by Sojhinn View Post
Picture not showing on mobile app.
Had to edit the tags, should be up now
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft
Aztec's Build Thread
Aztec is offline   Reply With Quote
Old 08-31-2017, 01:45 AM   #10530
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Still nothing for me.
Installed Mods:
Old 08-31-2017, 01:49 AM   #10531
Aztec
Aztec's Avatar
3rd times the charm
NEW CAR!🚨🏎️⛽
Old 08-31-2017, 01:53 AM   #10532
Sojhinn
Sojhinn's Avatar
3rd times the charm
1)
Ok with the car on. And esc off. (car motor not running) . When you push the accelerator what happens with the moving square.
2)
With the car not on your esc should never turn on. What fuse location are you in?
Installed Mods:
Old 08-31-2017, 01:59 AM   #10533
Aztec
Aztec's Avatar
1)
2)
That could explain some issues I'm having LOL
are you talking about the voltage gauge tap? I believe I'm using the 10a that was not used in the FRS.
Sent from my Pixel XL using Tapatalk
NEW CAR!🚨🏎️⛽
Old 08-31-2017, 02:10 AM   #10534
Aztec
Aztec's Avatar
Here is the picture of the fuse which has the procede and the voltage gauge I believe.
Now that said, should I be checking my ECU taps? Would one of those cause the ESC to turn on when the car isn't on?!
Thanks
NEW CAR!🚨🏎️⛽
Old 08-31-2017, 10:19 AM   #10535
Sojhinn
Sojhinn's Avatar
Thanks
That looks right. But you opened the controller and soldered something yes?
Installed Mods:
Old 08-31-2017, 10:58 AM   #10536
Aztec
Aztec's Avatar
Yes but I believe the esc was turning on with the car off at that point too. The soldering fixed the unit from turning off, which was a previous issue lol.
I'm going to be checking the ECU wire taps next
NEW CAR!🚨🏎️⛽
Old 08-31-2017, 06:01 PM   #10537
Aztec
Aztec's Avatar
Just as a test, I re-flashed my ECU with the OTS ESC tune for openflash. I then applied the procede map that keenas is using with the exact same problem with the boost not being applied consistently. voltage going up etc.
Going back to previous statements, it sounds like something isn't wired correctly perhaps. If it matters i'm using a procede that is labelled for a BMW 335i or something. One of the first procede's that Shiv sent out to Fenton I believe.
I'll be checking the wire taps tonight
EDIT: @Sojhinn I looked at where the box moves when I accelerate inside the procede software and yellow box I believe goes up and down vertically, but staying on the left hand side
NEW CAR!🚨🏎️⛽
Old 08-31-2017, 07:09 PM   #10538
Sojhinn
Sojhinn's Avatar
Ok that may mean you may have wired the procede incorrectly. The box should.move left to right with the car on (motor not running).
Installed Mods:
Old 08-31-2017, 07:27 PM   #10539
Aztec
Aztec's Avatar
I was wrong. The blue box goes left to right with the motor not running. Going to check the connections tonight and see what I can find. I used your procede install video, are the colors universal to tap into between FRS and BRZ?
NEW CAR!🚨🏎️⛽
Old 08-31-2017, 07:28 PM   #10540
Sojhinn
Sojhinn's Avatar
OK then you are good. Just double checking.
Installed Mods:
Old 08-31-2017, 07:29 PM   #10541
Sojhinn
Sojhinn's Avatar
So then... This means some wire is loose or something is grounding somehow when you are pushing down on the accelerator for the phantom to turn on with the car off.
Is the voltmeter on when the car is off?
Installed Mods:
Old 08-31-2017, 07:30 PM   #10542
Aztec
Aztec's Avatar
Yes it is. I see the volts go down when the car is off and I press the accelerator. It's plugged into the correct fuse? Or maybe it's the wrong one?
NEW CAR!🚨🏎️⛽
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
