Old 06-29-2017, 01:14 PM   #10389
fenton
Today is a sad day
Well guys, it is time for me to move on from my beloved BRZ. My family is expanding and I no longer have the luxury of keeping my sports car.
With that being said I will be selling off my latest phantom supercharger.
What I have:
-Phantom v3 4500kw kit with Partial throttle boost
-OFT
-3 x Odyssey PC680
-Procede Electronic boost control
Ideally I would like to find someone local as shipping the batteries really isn't a option.
fenton is offline   Reply With Quote
The Following User Says Thank You to fenton For This Useful Post:
Photomikes garage (07-28-2017)
Old 06-29-2017, 01:15 PM   #10390
Aztec
Lost in the twisties
Aztec's Avatar
Drives: 2014 BRZ Dark Gray Metallic
What I have:
-OFT
-3 x Odyssey PC680
I'll buy it without the batteries? I don't need the OFT as I already have one as well
Sent from my Pixel XL using Tapatalk
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft
Aztec's Build Thread
Aztec is offline   Reply With Quote
Old 06-29-2017, 02:37 PM   #10391
DAEMANO
Time Traveller
What I have:
-OFT
-3 x Odyssey PC680
Sad to hear it indeed. I'm sure your kit will find a new home quickly. Thanks for all your work as I know you've helped many people enjoy their cars to the fullest.
The Following 2 Users Say Thank You to DAEMANO For This Useful Post:
fenton (06-29-2017), Photomikes garage (07-28-2017)
Old 06-29-2017, 03:00 PM   #10392
illmatic_frs
illmatic_frs's Avatar
Drives: n/a
Thought I posted this yesterday but I guess it didn't go through..
My ESC stopped working a few days ago. Short version: looked at the wiring and found this (see pics). The blue and black wires leading to the ESC were singed together.
Has anyone seen this before? Any ideas as to the root cause? And what is the remedy? Can I just clean the connector ends with a file and reconnect? or Is the esc toast? How do i test if the unit is OK?
Much appreciate any ideas.. Life without boost just isn't the same
Sent from my ZTE A2017U using Tapatalk
illmatic_frs is offline   Reply With Quote
Old 06-29-2017, 04:04 PM   #10393
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
you posted it in the owners thread: http://www.ft86club.com/forums/showt...=66862&page=83
you have replies on that page.
If they were "singed together" I have to stand by my oppinion that they were vibrating or rubbing against eachother untill they wore through the insulation, causing them to arch. If it was corrosion as Ultramaroon suggested, the red wire should show some signs of contamination as it right next to the other two, and so should be exposed to the same conditions.
The system should not be damaged, so you can try to wirebrush those contacts, and put some new heatshrink insulation on them, but it looks like the plating is gone, so it may not be a very tight fit. You can replace those connectors, I have seen them on Amazon but cant remember the source, I'll try to see if mine has any markings, or Email Rob and he may help with that.
I have not heard of this happening before, but If i am right, it could be solved with wire spacers, something home made like this [ame="https://www.youtube.com/watch?v=Fll_OPtYsJE"]https://www.youtube.com/watch?v=Fll_OPtYsJE[/ame]
or what I did was to slip that plastic wire loom over the connectors which keeps them tight together, and wrap it with some electrical tape
This looks like a similar type of connector if you want to change it: https://www.amazon.com/s/ref=nb_sb_n...llet+connector
The Following 2 Users Say Thank You to Target70 For This Useful Post:
DAEMANO (06-29-2017), Gums (06-29-2017)
Old 06-29-2017, 04:22 PM   #10394
fenton
I've had this happen a couple years ago. It happened when the cable's were too tight, i had a hard shift and the engine moving caused the wires to disconnect and arc. Mine wasnt nearly as bad as your's but we were able to clean them.
Also if they do rub together for long enough the same thing can happen.
The Following 2 Users Say Thank You to fenton For This Useful Post:
Old 06-29-2017, 04:49 PM   #10395
Target70
Target70's Avatar
sounds like a spacer might be a good way to go just for safety. It sounds like it would be a better design choice to replace the 3 bullet connectors with one single indexed plug, but would probably lead to a price increase.
http://www.andersonpower.com/us/en/p...pole/pp75.aspx
something like this might work, they have multiple colors, look like they lock togeather, and are genderless so can be used on the motor and controller side independently.
Old 06-29-2017, 09:46 PM   #10396
Gums
Drives: SWP BRZ
Had the same issue some time ago, figured loose connectors was the issue.
Cleaned connectors and added a small hard plastic cylinder to the centre of the male connector to keep it expanded. No issues since.
Will be doing the cable tie separator just incase.
Gums is offline   Reply With Quote
Old 06-29-2017, 09:48 PM   #10397
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Same here. Cheap and effective
Installed Mods:
Old 06-29-2017, 09:58 PM   #10398
Gums
Drives: SWP BRZ
A sad day indeed Fenton, thank you for all your efforts in supporting the ESC for the community.
All the best for you and your family
Old 06-29-2017, 09:59 PM   #10399
Sojhinn
Sojhinn's Avatar
What I have:
-OFT
-3 x Odyssey PC680
Won't be the same without you brother. Good luck with the family.
Installed Mods:
Old 07-01-2017, 01:50 PM   #10400
illmatic_frs
Drives: n/a
I am happy to announce boost is back! Thank you gentlemen and have an awesome Canada Day :-)
The Following 3 Users Say Thank You to illmatic_frs For This Useful Post:
DAEMANO (07-05-2017), mrjj (02-21-2021), Sojhinn (07-01-2017)
Old 07-03-2017, 06:50 PM   #10401
silent runner
Drives: 93'Camry, 82'Corolla, 76' Celica
Fenton, you should hang on to the system and install it on your suv or minivan!
Congrats on your growing family!
silent runner is offline   Reply With Quote
Old 07-05-2017, 08:54 PM   #10402
j_Zer0
Drives: Asphalt FRS 2014
Dead Starter Battery Woes
Woke up to a dead battery this morning (again). My starter battery (PC680 FMJ) is less than a year old, so I'd rather try to trickle charge or maybe jump it than order another one. Only thing is, I'm not sure where to hook up the leads/cables. It doesn't quite make sense to me that I'd hook up cables to the main array terminals given that the dump batteries are in there. I've attached a picture of my battery array and labelled "main positive", "main negative" and "starter negative" (for the starter battery's negative terminal). So where do I hook up leads/cables to either trickle charge or jump? Thanks!
ESC+OFH | Borla Axleback | Helix clear side markers | Opti-coat | Beatsonic v2 Sharkfin antenna | TRD lowering springs | TRD sway bars | 18" Enkei Kojins + PSSs
j_Zer0 is offline   Reply With Quote
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
