Old 04-22-2017, 10:17 PM   #10347
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Originally Posted by godzuki View Post
hi all,
anyone run into an issue where the compressor switches on, but only for a moment before spinning down again? once the foot pedal switch reaches the first click it does this, the second click does nothing and keeping the switch engaged doesn't keep the compressor on.
when i turn on the system it beeps once, then there is a little delay, then 5 slow beeps.
all connections appear fine, tried reseating the meter and foot pedal connectors as well.
Is this version 3?
Installed Mods:
Old 04-23-2017, 03:45 AM   #10348
godzuki
godzuki's Avatar
Drives: frs
Originally Posted by Sojhinn View Post
Is this version 3?
v2 i believe
godzuki is offline   Reply With Quote
Old 04-23-2017, 11:14 AM   #10349
Sojhinn
Sojhinn's Avatar
v2 i believe
Does it have the headphone jack connectors?
Installed Mods:
Old 04-23-2017, 11:51 AM   #10350
DAEMANO
Time Traveller
Originally Posted by Gums View Post
One more thing to check, I had an issue with the plug on the voltage display.
Rob sent a new voltage display which fixed the issue. Wasn't until I dismantled the old display (removed the female section of the plug) that I noticed that the solder on one of the wires wasn't soldered properly. It looked like it was!
Allowed the voltmeter to work sometimes and not others.
Glad you mentioned this because it's a small issue that can make the whole thing go batty.
For anyone else with intermittent operation issues it's easy pop open the back of the voltmeter (one or two screws) and check that the solder on the input wires and/or connector are still holding up. If not, just re-solder. Cake.
Old 04-23-2017, 12:06 PM   #10351
WNDSRFR
Drives: FR-S,GTI
What ever happened to the V3 anyway? Haven't heard anything about it at all.
Old 04-23-2017, 12:12 PM   #10352
Sojhinn
Sojhinn's Avatar
I think there's at least 7-8 in the wild.
Installed Mods:
Old 04-23-2017, 08:12 PM   #10353
godzuki
godzuki's Avatar
Drives: frs
yup
Old 04-23-2017, 08:13 PM   #10354
Sojhinn
Sojhinn's Avatar
yup
Like was said double check the solder connections in both the voltmeter and the switch. Might have a bad connection.
Installed Mods:
Old 04-23-2017, 10:24 PM   #10355
Sojhinn
Sojhinn's Avatar
Also check the ground and make sure the second switch is actually engaging.
Installed Mods:
Old 04-24-2017, 03:41 AM   #10356
godzuki
godzuki's Avatar
Drives: frs
can anyone tell me if the first click only spins the compressor for a brief moment?
Old 04-24-2017, 02:41 PM   #10357
Urmyson
Has anyone added a header after the ESC? I'm thinking about picking up OFH and wanted to see if I'll be able to tell a difference.
Urmyson is offline   Reply With Quote
Old 04-24-2017, 03:00 PM   #10358
Sojhinn
Sojhinn's Avatar
First click should keep it running. Shouldn't be short burst.
Installed Mods:
Old 04-24-2017, 03:02 PM   #10359
Sojhinn
Sojhinn's Avatar
Full throttle Electric Supercharger Build Thread
I'm running a JDL header for the past couple of weeks. I'm actually enjoying it more for the off boost applications than on boost.
But there is a noticeable increase in performance either way. It won't be much though under boost.
Installed Mods:
Old 04-24-2017, 05:14 PM   #10360
WNDSRFR
Drives: FR-S,GTI
I've had the ESC/OFT/OFH combo for quite a while now and I couldn't be happier. That along with a Manzo V1 catback and it's the Ultimate.
As far as if you can tell the difference goes:
Yes you can tell the difference. It sounds outstanding. I don't know if the performance numbers are any better or not but to me just the exhaust note is well worth the price of admission.
You will never find a bolt on accessory that will ever beat the ESC for a price/performance/reliability combo. I just wish it was more readily available.
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
