Old 08-04-2018, 10:48 PM   #1023
wooly35
Drives: 2014 Scion FR-S LS3
holy crap! I never knew your car was that low. 3'' pipe should be no problem with a slight raise in the suspension. Ive been wanting a dual exhaust, and that routing you have looks perfect.
2014 scion FR-LS3 lol
wooly35 is offline   Reply With Quote
The Following User Says Thank You to wooly35 For This Useful Post:
DustinS (08-06-2018)
Old 08-06-2018, 10:56 AM   #1024
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Yeah the ride height is a large problem for clearance with dual 3". I need to raise it - and plan on raising it - but it just looks so good.
DustinS is offline   Reply With Quote
The Following 2 Users Say Thank You to DustinS For This Useful Post:
wooly35 (08-07-2018), zeal86 (08-06-2018)
Old 08-06-2018, 01:17 PM   #1025
all4spl
What coilovers are you on?
all4spl is offline   Reply With Quote
Old 08-06-2018, 01:56 PM   #1026
DustinS
DustinS's Avatar
Fortune Auto 500.
Old 08-06-2018, 02:02 PM   #1027
all4spl
I thought I saw that those coilovers don't go as low as others? But clearly you're having an issue going too low haha
Old 08-07-2018, 04:35 PM   #1028
DustinS
DustinS's Avatar
Moved the gauges. Still not the best oil pressure.
The Following User Says Thank You to DustinS For This Useful Post:
Zer0 (08-07-2018)
Old 08-11-2018, 07:51 PM   #1029
wooly35
Doesn't seem to bad. Mine at warm idle is right at 30psi. Might be a smidge on the low side.
Old 08-11-2018, 08:15 PM   #1030
ILLSMOQ
Drives: 2017 WR BLUE BRZ
My hot oil temp is about thare too
ILLSMOQ is offline   Reply With Quote
Old 08-13-2018, 01:50 PM   #1031
DustinS
DustinS's Avatar
What oil weight?
Old 08-13-2018, 07:05 PM   #1032
jflogerzi
jflogerzi's Avatar
I approve! wow nice custom work. How much $$$ have you spent in total rough estimate.
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
DustinS (08-14-2018)
Old 08-13-2018, 08:08 PM   #1033
wooly35
What oil weight?
5w30
Old 08-14-2018, 11:22 AM   #1034
DustinS
DustinS's Avatar
Thanks! and over $20k on the swap alone. Nowhere near finished.
@wooly35 I am running 15w-50 oil haha.
6-Shift (08-21-2018)
Old 08-14-2018, 11:32 AM   #1035
jflogerzi
jflogerzi's Avatar
I nearly spit my drink out when I read that. Wow but keep up the good work.
Old 08-14-2018, 12:04 PM   #1036
spitsnaugle
Drives: LS Swapped Scion FRS = 440HP
Its not hard to add up to that in these swaps.
Figure $6-12k for a good engine/trans combo (depending on how wild or new).
$6k for motec and harness.
$2k in mounts and headers.
Driveshaft at 500-700
Sensors, gauges, hoses, bolts, AC lines, wiring bits, misc. probably 500-1000.
spitsnaugle is offline   Reply With Quote
The Following 5 Users Say Thank You to spitsnaugle For This Useful Post:
6-Shift (08-21-2018), DustinS (08-14-2018), Sportsguy83 (08-14-2018), wooly35 (08-14-2018), Zer0 (08-15-2018)
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 11:54 PM
Ls or 2jz swap? sgoldberg01 BRZ First-Gen (2012+) — General Topics 13 03-22-2016 04:07 PM
Rod Swap protpibe Engine, Exhaust, Transmission 6 10-22-2015 12:38 AM
AT-->MT swap AlwaysSideways Want-To-Buy Requests 3 12-15-2014 12:14 PM
Should I swap? michaelahess BRZ First-Gen (2012+) — General Topics 8 06-12-2012 08:32 PM
