Old 08-23-2013, 08:13 PM   #1009
BRZNutt
BRZNutt's Avatar
Drives: 2014 DGM Subaru Impreza 2.0i 5 Door
Check out my solution for the AC line chaffing. Some may say it's overkill, but "overkill" is my middle name...
Just noticed this shot shows off the GS MCB as well...
2016 World Rally Blue Subaru WRX Limited
2013 Satin White Pearl Subaru BRZ Limited 6 MT (Sold)
BRZNutt is offline   Reply With Quote
The Following 2 Users Say Thank You to BRZNutt For This Useful Post:
jbravo373 (08-23-2013), johnb831 (08-23-2013)
Old 08-23-2013, 08:15 PM   #1010
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
You win!
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 08-23-2013, 09:54 PM   #1011
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Originally Posted by ATL BRZ View Post
Installation was a joke, less than 5 minutes total. The triangle is complete!
Thanks GrimmSpeed!
Domo approves, rocking out and all lol!!
The Following User Says Thank You to OICU812 For This Useful Post:
ATL BRZ (08-23-2013)
Old 08-23-2013, 10:02 PM   #1012
SliverBrz
Drives: Silver 2013 BRZ limited
What if you don't have a torque wrench ?
SliverBrz is offline   Reply With Quote
Old 08-23-2013, 11:12 PM   #1013
johnb831
johnb831's Avatar
Drives: SWP 2013 Subaru BRZ Limited
What did you use to do that? looks good!
johnb831 is offline   Reply With Quote
Old 08-24-2013, 12:30 AM   #1014
xn7485
Drives: 1995 Acura Integra GS-R
Any plans to share that setup?!
xn7485 is offline   Reply With Quote
Old 08-24-2013, 01:40 AM   #1015
PNW FRS
PNW FRS's Avatar
Parts List please???
2013 Asphalt / MT
Olympia, Washington
PNW FRS is offline   Reply With Quote
The Following User Says Thank You to PNW FRS For This Useful Post:
Wolfking (08-24-2013)
Old 08-24-2013, 01:40 AM   #1016
BRZNutt
BRZNutt's Avatar
I will most definitely share how I did it. The key component is the rubber vibration isolator that has a M6 threaded stud on one end that picks up the existing nutplate on the fuel hose cover. The other end has female threads to accept a M6 bolt or screw. This allows the hose to still move when the engine moves. This is just a prototype that I threw together using mostly parts I had laying around. I will post up a complete list of parts and where to source them. Here's a link to the isolator:[ame="http://www.amazon.com/gp/product/B007HKIWA6?ie=UTF8&force-full-site=1&ref_=aw_bottom_links"]Amico 6mm Male Thread 20x20mm Rubber Base Vibration Isolator Mount Black - Amazon.com[/ame]
OK, here's the rough parts list. No part numbers for the screws, washers and nuts, but I'm sure most can figure this out. All parts except the vibration isolator can be source from Lowes.
QTY 1: Rubber Lined Clamp, size 1" (see pic below for part number)
QTY 1: 19mm x 12mm Corner Brace (Stanley part number: S839-019)
QTY 1: Metric 6mm x 1mm (thread pitch) x 12mm (length) Screw or Bolt
QTY 1: Metric 6mm x 1mm (thread pitch) x 35mm (length) Screw or Bolt
QTY 4: Metric 6mm x 1mm (thread pitch) Nut or Lock Nut
QTY 4: Metric 6mm Washer
QTY 1: Amico 6mm Male Thread Isolator (link above)
Some things to note:
-The clamp size is probably closer to 7/8" or 15/16", but all they had was the 1".
-You can use regular free spinning nuts or lock nuts. If you use free spinning nuts, you may want to add lock washers.
- Make sure you only thread into the fuel hose bracket enough to break safety (1 or 2 threads showing past the nutplate on the bracket, reach your finger inside to check) and then lock it down with the nut. You do not want to thread the isolator all the way in, it will contact and possibly damage what is under the cover.
- When you are assembling everything in the car, try to orient the parts so that the AC line makes a natural bend down to the clamp. Don't put too much preload on the hose end fitting or lines.
- Finally, I assume no liability for damage to your car by installing this clamp set up. It has not been long term tested or approved for use by Subaru/Scion/Toyota or GrimmSpeed.
The Following 8 Users Say Thank You to BRZNutt For This Useful Post:
ATL BRZ (08-24-2013), Clipdat (08-24-2013), jbravo373 (08-24-2013), johnb831 (08-24-2013), kwood9000 (08-25-2013), PNW FRS (08-24-2013), tripjammer (08-24-2013), xn7485 (08-24-2013)
Old 08-24-2013, 04:20 PM   #1017
xwd
Got my bar today, definitely one beefy mofo. Weighed right at 4 lbs.
Old 08-24-2013, 10:05 PM   #1018
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
Originally Posted by Slartibartfast View Post
Is there anyone in the group buy getting the red brace, who already has the red Perrin intake?
Cheers all!
Here you go. I just quickly took a pic with it laying next to the intake. Looks to be a perfect match to me. I will have a few installed pics tomorrow. I have also painted a few other pieces, as well as the other 2 stock braces with engine enamel, and they all match. The enamel is just slightly darker, but not a real noticeable difference unless your looking real close. Biggest difference is that the perrin and grimmspeed pieces have the wrinkle finish.
Shipping Damage
Also, as someone else noted. Mine came shipped in bad shape, one whole end of the packaging was busted open and the paint was all chipped off on that end. The whole bar was sliding in and out of the box, the packaging probably should be a bit better. I have emailed Grimmspeed about it, and hope they can do something about it. Right now will have to touch it up, hopefully they can ship a new one out, or send touch up paint, not sure how noticeable it will be, i am going to do a test fit and see how bad it bothers me....
Got a bunch more grimmspeed stuf fon the way...MasterBrake cylinder brace, Hood dampers, yay! That with my Grimmspeed EBCS, loving Grimmspeed!
gdrider77 is offline   Reply With Quote
The Following User Says Thank You to gdrider77 For This Useful Post:
Slartibartfast (08-24-2013)
Old 08-24-2013, 10:08 PM   #1019
SliverBrz
So I came home from work today to a little surprise. Yay my bar came.
First the whole transaction has been a pleasure with grimspeed. Only negative thus far is packing. There was very little paper to protect the bar and mine had a tiny chip in the red from the ends because of fed ex. However, it was minor enough that i don't mind and im only mentioning this so grimmspeed can put a little more packing in the future.
Now lets get to the bar.
WOW! Im usually very skeptical and I thought this was more of an engine bay dress up piece but NOPE. The moment you drive off your home and hit the streets you can already feel it. The car is more planted, nimble, quieter over bumps and less jarring. The car also feels more responsive. Whether this is a placebo effect or not, I have no regrets.
The Following User Says Thank You to SliverBrz For This Useful Post:
tripjammer (08-27-2013)
Old 08-24-2013, 10:33 PM   #1020
Slartibartfast
Klaatu barada nikto
Slartibartfast's Avatar
Drives: Raven FR-S MT
Thanks!
I have to say, this forum is awesome.
Pictures say a thousand words. I'm going to try to darken up the crinkle coat when I do the tri-braces. Nice to know the Perrin coating and the GrimmSpeed are so close.
I'll post up pictures when I have it all done.
Cheers
I vow to do no harm.
2013 Raven FR-S Manual "Lenore"
1985 Silver RX-7 GSL-SE (Gone and missed)
Slartibartfast is offline   Reply With Quote
Old 08-24-2013, 10:48 PM   #1021
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Sorry to hear about people experiencing shipping damage. I hope mine makes it out here to California without a big hole in the side of the box!
Originally Posted by humfrz
I'm old and lazy
Old 08-24-2013, 11:04 PM   #1022
Optimus Prime
Optimus Prime's Avatar
Drives: Whiteout 2013 FR-S
Received mine today. I am not the handiest of men, but even for my skill level this was like a 10m install where 4m was trying to find my socket set. And what a difference in ride/handling. It makes one wonder why this wasn't included from the factory.
Optimus Prime is offline   Reply With Quote
Anyone using the STi Flexible Strut Tower Brace? ngabdala Suspension | Chassis | Brakes -- Sponsored by 949 Racing 45 08-15-2019 02:59 AM
F/S Beatrush Strut Tower Brace Type-2 $175 Dan-in-Japan Brakes, Suspension, Chassis 2 02-24-2013 02:38 PM
FT-86 SpeedFactory Strut Tower Brace Review F1point4 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 35 01-07-2013 05:31 AM
DIY - Strut Tower Brace - FT-86 SpeedFactory F1point4 DIY (Do-It-Yourself) Guides 4 10-28-2012 05:30 PM
