Old 02-03-2013, 09:50 PM   #995
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by Sportsguy83 View Post
Just curious, why do you care about a Cat in FL? (unless you removed the secondary Cat in which case I would understand you don't want your daughter to run completely Catless)
Originally Posted by wootwoot View Post
Could be for autoX. He also may be trying to slow the inevitable destruction of the planet.
Yeah, that's why I said if he removed the secondary I understood it.
Old 02-03-2013, 11:20 PM   #996
FR-S Matt
Originally Posted by mangostick View Post
^ this. I had a subaru, I still hang with all my local subie friends .. and to be honest UEL matches those cars. IT DOES NOT match the personality of the FRS/BRZ imho. It sounds like a Harley and a Honda got it on and that's what came out the other side.
People are going to do what they want to do regardless of whether its going to give them actual gains or not. UEL headers are nothing more than oem compromise for cost and ease of mounting in a tight space.
Why pay performance $$ for another compromise?
There's no proof yet that there is a performance compromise on this car with either header. Not enough tests.
Old 02-04-2013, 12:56 AM   #997
OrbitalEllipses
Drives: Attitude
I can't stop it, why care?
I have retained the secondary cat.
Old 02-04-2013, 07:37 AM   #998
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
I was hoping to get her into AutoX after volleyball season this summer, one of her friends father told me the stock class required it. I haven't checked the rule book.
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 02-04-2013, 08:18 AM   #999
mangostick
Drives: whiteout FRS
what makes this car different from any other gasoline powered engine?
UEL with short tubes doesn't make the same power.. they just dont. I could get into the science of why but the only guys here going to get it are the Nameless crew and maybe a few others.
Long tube equal length headers have been making more power on various applications since the dawn of the combustion engine. Its not going to change any time soon.
mangostick is offline   Reply With Quote
Old 02-04-2013, 08:50 AM   #1000
Dimman
Kuruma Otaku
Dimman's Avatar
We can start with what the engine ECU needs to get information about fuel requirements. It needs an airflow reference (the MAF) and a combustion efficiency reference (the O2 sensor). Both of which are reading averages. But on an UEL header it is not scavenging equally on both banks. So if you need 12.5:1 AFR for best power on a UEL one bank may be at 12:1 and the other at 13:1.
To the UEL fans, ask yourselves if you have ever seen an UEL intake manifold...
Because titanium.
Old 02-04-2013, 08:53 AM   #1001
QFry
QFry's Avatar
Drives: '13 Argento FR-S
Doesnt the sound people are seeking have more to do with the pairing of the cylinders on the header than it does with the length of the primaries?
2013 Argento FR-S -> Lots of random PlastiDip, UNIChip Custom Tune, aFe Takeda Intake, Nameless Performance front pipe and axle back exhaust, Motegi MR125 7.5x17, Rally Armour mud flaps, Gloss black vinyl roof, ACT street clutch and flywheel,Whiteline bushings; Kartboy Shortshifter and shift bushing
QFry is offline   Reply With Quote
Old 02-04-2013, 11:22 AM   #1002
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
yes, and they suck.
4AGZE intake manifold
uspspro is offline   Reply With Quote
Old 02-04-2013, 11:29 AM   #1003
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Originally Posted by uspspro View Post
yes, and they suck.
I wouldn't trust any intake manifold that didn't suck.
industrial is offline   Reply With Quote
Old 02-04-2013, 11:39 AM   #1004
2forme
Old 02-04-2013, 11:44 AM   #1005
OrbitalEllipses
Drives: Attitude
Stock Subaru intake manifolds have unequal length runners...or at least the older cast aluminum manifolds did.
Old 02-04-2013, 12:13 PM   #1006
Dimman
Kuruma Otaku
Dimman's Avatar
How unequal?
Most I've seen look pretty equal. Any runner length variability probably has to do with port length.
I can't imagine any intake being as asymmetric as the exhaust manifolds.
Because titanium.
Old 02-04-2013, 12:18 PM   #1007
OrbitalEllipses
Drives: Attitude
No, it's not nearly that bad. Just being a smartass.
Old 02-04-2013, 10:01 PM   #1008
mangostick
Nope, pairing of the cyl's doesn't mean much because the firing order is still in order. All things equal (no pun) you would hear 1234 1234 .. when you run a uel header it pairs the exhaust pulses.. thus halfing (or close to) the frequency and giving the rumbly exhaust note. 13,24 13,24 13,24
21 months no dyno, 22 months no vendor dyno, 22months4rattles&leakssmh, amazing warped qualiy, y u no tag
Nameless Performance BRZ Axleback Exhaust ESBjiujitsu Engine, Exhaust, Transmission 1377 04-21-2020 02:23 AM
Nameless Performance Axleback is available for pre-order. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 114 07-23-2012 10:38 PM
Nameless Performance Downpipe is available for pre-order. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 4 07-12-2012 04:57 PM
We are Nameless Performance. John@Nameless Announcements, Contests, Giveaways 22 06-18-2012 11:32 PM
Nameless Performance is here. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 16 06-06-2012 04:32 AM
