Old 03-27-2018, 10:48 AM   #981
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Originally Posted by ILLSMOQ View Post
Since you can obviously fiberglass, why not skin it in carbon?
I have thought about that. If I go that far though, I think I will try and make a mold of it and make it completely carbon.
DustinS is offline   Reply With Quote
The Following User Says Thank You to DustinS For This Useful Post:
zeal86 (03-27-2018)
Old 04-03-2018, 01:40 PM   #982
DustinS
DustinS's Avatar
Got word that the engine is finished up and waiting to be shipped out. Depending on when the paperwork gets filled out on their end, I assume it will go out today or tomorrow.
The Following 3 Users Say Thank You to DustinS For This Useful Post:
ILLSMOQ (04-03-2018), Sportsguy83 (04-03-2018), toast (04-04-2018)
Old 04-11-2018, 10:46 AM   #983
DustinS
DustinS's Avatar
Engine is still waiting to be shipped...
Got the Expansion tank mounted. I wish the ports were on opposite sides, but I will make them work. I can/will move it up later if need be.
Custom Bracket. Could be a bit cleaner, but oh well. Most likely paint it black.
This will most likely be changed to a -12an fitting. I will run AN lines for the heater lines to make it look nice.
Contemplating removing the cross brace bracket as they don't fit with the LS anyway. I'll make a new bracket when I design new cross braces.
The Following 4 Users Say Thank You to DustinS For This Useful Post:
6-Shift (04-12-2018), BRX (04-12-2018), ILLSMOQ (04-11-2018), Sportsguy83 (04-11-2018)
Old 04-12-2018, 12:45 PM   #984
DustinS
DustinS's Avatar
Got the positive terminal installed and brackets painted. Finished up for now.
The Following 5 Users Say Thank You to DustinS For This Useful Post:
BRX (04-13-2018), gtpvette (04-12-2018), ILLSMOQ (04-12-2018), Sportsguy83 (10-08-2018), zeal86 (04-12-2018)
Old 04-12-2018, 02:24 PM   #985
ILLSMOQ
Drives: 2017 WR BLUE BRZ
That looks like it worked out well
ILLSMOQ is offline   Reply With Quote
The Following User Says Thank You to ILLSMOQ For This Useful Post:
DustinS (04-12-2018)
Old 04-12-2018, 04:22 PM   #986
DustinS
DustinS's Avatar
Old 04-13-2018, 12:49 PM   #987
DustinS
DustinS's Avatar
Well I got a tiny bit of work done yesterday. I popped open the fuel tank to see if I could figure out my fueling issue. Runs out of fuel around 1/4 tank. I couldn't find anything. Thought the tank was SUPER full. Seems my car always breaks/gets taken off the road right after filling the tank.
Ground Strap finished up
I am going to make a few of these to ground the engine and alternator to the frame. I also got the AMP power wire removed as I no longer need it to go to the front of the car.
Engine will be here Tuesday. I think we will just try and stab it in tuesday after work as well. Shouldn't be too much longer till it's running. Though I still have a lot parts to order haha.
Old 04-13-2018, 12:55 PM   #988
BRX
BRX's Avatar
Drives: Toyota GT86
I might have missed it but what's your fuel setup? I've probably taken out my fuel pump more times than I should in a lifetime and might be able to help you figure it out.
Sent from my Pixel 2 XL using Tapatalk
BRX is offline   Reply With Quote
Old 04-13-2018, 01:00 PM   #989
DustinS
DustinS's Avatar
DW300c, VitViper FPR Bypass, -6an Feed/Return. Fuel returned into fuel bucket, Looking at getting some submersible fuel line to make sure it's not just the returning fuel causing issues. Car just straight runs out of fuel at 1/4 tank.
Old 04-13-2018, 01:06 PM   #990
BRX
BRX's Avatar
Drives: Toyota GT86
That's almost exactly what I'm running but I removed the VitViper FPR. Try going back to the stock FPR and see how it goes. I think the Venturi system doesn't perform as well with a blank FPR.
Other than that I only had the same issue with the FBM walbro kit. It was simply not sealing properly with their adapter no matter what I did, first it would run out of fuel at half, then 1/3 and the best I could do was 1/4 before I went back to the DW300c.
The Following User Says Thank You to BRX For This Useful Post:
DustinS (04-13-2018)
Old 04-13-2018, 01:13 PM   #991
DustinS
DustinS's Avatar
What are you doing for fuel pressure?
Old 04-13-2018, 01:18 PM   #992
BRX
BRX's Avatar
Drives: Toyota GT86
I have another OEM regulator on the fuel rails. Does its job even with the other regulator in the tank.
Old 04-17-2018, 10:26 AM   #993
DustinS
DustinS's Avatar
Battery Relocation pretty much finished up.
Carefully drilled out some rivnuts as mounts for the battery ties. Still need a main fuse on this side of the positive wire. Using the old battery tray holder as the Battery bracket as it will keep the trunk mat thing from falling on the battery.
gtpvette (04-17-2018), ILLSMOQ (04-17-2018), Sportsguy83 (04-17-2018)
Old 04-17-2018, 12:04 PM   #994
DustinS
DustinS's Avatar
Woo! Ready to get this in.
I am going to see about getting the oil pan modified today before dropping it in. This would get rid of the oil bypass valve for the DOD and allow me to run the front sway bar.
The Following 2 Users Say Thank You to DustinS For This Useful Post:
-Phil (04-17-2018), Sportsguy83 (04-18-2018)
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 11:54 PM
Ls or 2jz swap? sgoldberg01 BRZ First-Gen (2012+) — General Topics 13 03-22-2016 04:07 PM
Rod Swap protpibe Engine, Exhaust, Transmission 6 10-22-2015 12:38 AM
AT-->MT swap AlwaysSideways Want-To-Buy Requests 3 12-15-2014 12:14 PM
Should I swap? michaelahess BRZ First-Gen (2012+) — General Topics 8 06-12-2012 08:32 PM
