Old 12-24-2015, 10:46 AM   #9787
WNDSRFR
Drives: FR-S,GTI
Originally Posted by Lord09 View Post
Does anyone know the exact battery tray or size used in the 1.5 kits? Sent an email to Rob, but no response yet.
Unfortunately I purchased a second hand kit and no tray was included. I stopped by PepBoys and they have two trays, one that's ~11.5'' wide and ~14'' wide. The ~11.5'' is *just* barely too narrow, if it were another 1/8-1/4'' wider it'd be perfect. The ~14'' one is just huge.
I can cram all the batteries on the smaller tray, but the starter battery isn't sitting completely level with the tray and rest of the batteries or I could just use the larger tray, but I'd rather have something that provides more support for the batteries.
Any recommendations?
I have an extra V2 battery tray. If you want it, PM me your address and pay for shipping and it's yours. I had my kit upgraded a while back and I didn't use the new tray. My original batteries are almost 2 years old and still going strong.
Do you need the entire tray kit or just the tray itself? Let me know and I'll send you what you need.
Old 12-24-2015, 11:39 AM   #9788
Lord09
Drives: 2015 BRZ
This would be amazing, just sent you a PM.
Lord09 is offline   Reply With Quote
Old 12-24-2015, 12:20 PM   #9789
DAEMANO
Time Traveller
Originally Posted by rhythmM View Post
Hey guys, here's my first data log with the ESC installed. I am still getting exhaust backfire during wot sometimes.
My current mods are a drop in filter, lighter crank pulley, OFH, 2.75" header-back exhaust. I'm am not really sure what I should be watching out for, but does everything look okay and safe?
Thanks in advance!
OTS v2.02 tune for ESC+OFH on 91oct.
(three) 3rd gear pulls
http://datazap.me/u/rhythmm/esc-thre...g=0&data=1-2-9
Your log looks good to me. The AFRs are staying near 12 on your WOT pulls.
With an OFH and 2.75" header back it makes a lot of sense that you're getting backfires. How do I know? Cause I'm running nearly the same setup (TRD drop in filter + catless UEL + Ultimate racing 2.75" FP/OP + TRD USA 2.25" Catback). The backfires happen when exhaust pressures change (especially during gear changes). This is normal with UEL + less restrictive and larger exhaust pipe diameters like we have. If it's bothering you, it's easy enough to switch back to the stock OP/FP, but everything I've learned says we're good. Please though feel free to ask around so that your comfort level reaches acceptable for you. This is important. As an FYI I've been running the setup above for about the last 6 months. No issues. I've considered an e-tune from Shiv to get things completely optimized, but also from what I've heard, differences will be minor.
Old 12-24-2015, 05:08 PM   #9790
rhythmM
rhythmM's Avatar
Drives: 2014 Subaru BRZ Limited MT - White
Thanks for the reply! If the log looks good I won't change it. I actually really like the backfire sound lol. I was only concerned because the car never did that before so was wondering if it was still safe.
Phantom Super Charged - 2014 BRZ
rhythmM is offline   Reply With Quote
Old 12-28-2015, 10:00 PM   #9791
fenton
Merry Christmas ALL! Got great news that there will be 4 kits available in the first two weeks of January. PMs will start going out this week for the next in line.
Sent from my SM-G920W8 using Tapatalk
fenton is offline   Reply With Quote
Old 12-29-2015, 07:39 PM   #9792
Lord09
Drives: 2015 BRZ
Per Rob, the tray used in the kits can be purchased here:
http://www.remybattery.com/plastic-b...y-11-inch.html
It was about 1/8'' wider than the tray I previously purchased.
Finally got the kit installed along with the Procede, wiring cleanup and putting back together the interior.
Still playing around with Procede maps, but so far Sojhinn's V3 feels the smoothest.
I'm very happy with the kit so far and the Procede/partial boost is amazing.
Idle voltage is 28.2 and just using the OFT and the naked eye I've seen a max of 4.5 PSI.
My kit was an early V1.5, so it had a few differences than the current kits. Thanks to the wealth of knowledge in this and the owner's thread as well as a few people who helped me out via PMs, I'm up and running and wanted to extend my thanks and gratitude.
Old 12-29-2015, 08:32 PM   #9793
keen as
keen as's Avatar
Drives: 86 GT MT
If using Procede, you can delete the Drag reduction tube connected from the controller to air intake pipe. The hole can be plugged. I can't remember the size of the fitting to screw in to plug it.
keen as is offline   Reply With Quote
Old 12-29-2015, 08:50 PM   #9794
Lord09
Drives: 2015 BRZ
I've actually never heard of this, mind elaborating why it's not necessary?
Old 12-29-2015, 09:52 PM   #9795
DAEMANO
Time Traveller
IIRC, the PROcede controller and maps will perform the same function as drag reduction in the earlier kits so you can cap the drag reduction tap and remove the tube without issue.
Old 12-30-2015, 08:59 PM   #9796
statlab
Drives: Man
Send a message via ICQ to statlab Send a message via AIM to statlab Send a message via Yahoo to statlab
DIY Aux charger
Just wondering: has anyone had experience with this exact unit that Rob recommended? There are built-in auto shutoff features that make me wonder if it would cause issues for the ESC.
And, 2.5Amps: how much real-world benefit does this equate to?
http://www.batterystuff.com/battery-...ll/MC24EX.html
Make your own AUX charger.
These work great...~20% quicker recharge....add eyelets to input/output and bolt directly from 12V car to 24V dump.
Rob.
statlab is offline   Reply With Quote
Old 01-02-2016, 12:52 AM   #9797
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
Originally Posted by KoolBRZ View Post
Here are my latest tunes for MT's. The AT tunes aren't done yet. They have the newest Tip-in, PFI-DI ratio, Timing Advance and AVCS tuning for ESC to prevent excessive scavenging. This will get over 30 MPG between 60 - 70 MPH on the highway, and yet accelerate well in the city. I also included the "Cool" Procede map that most people liked. There is some advanced timing and enriched Port injection, so you should keep an eye on the A/F Ratio and the IAM.
I will probably install my kit tomorrow or in 2 days so.
this tune is for header+ ESC?
only stock part of exhaust system is header right now.
I have OP, catted FP, Q300
Openflash site indicates that tune is for OFH +ESC (v2.02 download)
Old 01-02-2016, 04:09 AM   #9798
KoolBRZ
KoolBRZ's Avatar
With an MT the tune should work just fine
I recommend logging after a day or so to make sure everything's in the green. The AT's are much harder to tune for. The taller gearing makes every slight imperfection in the tune into a glaring flaw. It simply has to pull hard and steady from low rpm's to work in an AT. A change to one single cell in a table can ruin an otherwise good tune. I've got an AT tune now that pulls strong and steady 1st through 4th, and that's as good as it's going to get for now. I'll be posting what I have for AT's as soon as I get caught up.
If I say yes, will that make you think I understand?
Old 01-02-2016, 09:37 AM   #9799
zc06_kisstherain
Drives: SWP BRZ
I have manual...
should i ask ESC tune minus OFH to Shiv?
Old 01-02-2016, 11:08 AM   #9800
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
I have manual...
For shivs tune it's for everyone. I don't have an aftermarket header but I use it.
Installed Mods:
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
