Old 12-17-2015, 11:43 AM   #9773
fenton
Originally Posted by Gums View Post
Use a length of cable (or similar) tape the plug/wires to one end and carefully feed it through.
Coat hanger works good for going under the center console too.
fenton is offline   Reply With Quote
Old 12-17-2015, 08:38 PM   #9774
rhythmM
rhythmM's Avatar
Drives: 2014 Subaru BRZ Limited MT - White
Originally Posted by DAEMANO View Post
Congrats indeed!.
Yes that was probably a backfire, nothing to worry about unless you notice very rich, or lean conditions in your logs (check your AFR). Make sure to log the first few days with your kit to ensure everything is healthy. If no anomalies, just enjoy them occasional backfires.
I haven't logged it yet, I'll have to do that soon haha, what should I be watching out for in the AFR? I notice the backfires occasionally happen during shifting and wot, but never when I am just coasting or cruising the highway.
Phantom Super Charged - 2014 BRZ
rhythmM is offline   Reply With Quote
Old 12-17-2015, 10:31 PM   #9775
xsnapshot
Fast enough
Drives: 2013 Subaru BRZ AT
I'll still be following this thread as I love the tech, but you can take me off the list. I'm JRSC'd now
xsnapshot is offline   Reply With Quote
The Following User Says Thank You to xsnapshot For This Useful Post:
fenton (12-18-2015)
Old 12-18-2015, 04:04 PM   #9776
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Which tune are you using??
Installed Mods:
Old 12-18-2015, 06:48 PM   #9777
stevo585
Drives: White 2014 BRZ
I noticed there are batteries out there with much higher CCA. Many for car audio. Would these give an advantage? Just curious money being no option what's the best batteries possible...
Like this:
http://www.sonicelectronix.com/item_...N-SK-BT20.html
850 amps!
stevo585 is offline   Reply With Quote
Old 12-18-2015, 07:21 PM   #9778
KoolBRZ
KoolBRZ's Avatar
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
Will 3 batteries fit though
Like this:
850 amps!
3 of them should just barely fit side-by-side. I measured. I might replace mine with these, and use my old ones for a trolling motor
If I say yes, will that make you think I understand?
KoolBRZ is offline   Reply With Quote
The Following User Says Thank You to KoolBRZ For This Useful Post:
stevo585 (12-18-2015)
Old 12-18-2015, 08:29 PM   #9779
rhythmM
rhythmM's Avatar
I'm using the v2.02 ESC+OFH tune on the OFT website. Is that one okay?
http://www.openflashtablet.com/Autom...ads/index.html
Old 12-18-2015, 08:34 PM   #9780
Sojhinn
Sojhinn's Avatar
Are you auto or manual?
Installed Mods:
Old 12-19-2015, 12:08 AM   #9781
rhythmM
rhythmM's Avatar
I am manual.
Old 12-23-2015, 01:38 PM   #9782
Lord09
Drives: 2015 BRZ
Does anyone know the exact battery tray or size used in the 1.5 kits? Sent an email to Rob, but no response yet.
Unfortunately I purchased a second hand kit and no tray was included. I stopped by PepBoys and they have two trays, one that's ~11.5'' wide and ~14'' wide. The ~11.5'' is *just* barely too narrow, if it were another 1/8-1/4'' wider it'd be perfect. The ~14'' one is just huge.
I can cram all the batteries on the smaller tray, but the starter battery isn't sitting completely level with the tray and rest of the batteries or I could just use the larger tray, but I'd rather have something that provides more support for the batteries.
Any recommendations?
Lord09 is offline   Reply With Quote
Old 12-23-2015, 01:39 PM   #9783
Sojhinn
Sojhinn's Avatar
Any way to mod the tray?
Installed Mods:
Old 12-23-2015, 01:46 PM   #9784
Lord09
Drives: 2015 BRZ
The only thing I can think of is to slice off the right or left edge, but I'd like to retain the lip that supports and holds the batteries to together.
Old 12-23-2015, 03:36 PM   #9785
rhythmM
rhythmM's Avatar
Hey guys, here's my first data log with the ESC installed. I am still getting exhaust backfire during wot sometimes.
My current mods are a drop in filter, lighter crank pulley, OFH, 2.75" header-back exhaust. I'm am not really sure what I should be watching out for, but does everything look okay and safe?
Thanks in advance!
OTS v2.02 tune for ESC+OFH on 91oct.
(three) 3rd gear pulls
http://datazap.me/u/rhythmm/esc-thre...g=0&data=1-2-9
The Following User Says Thank You to rhythmM For This Useful Post:
DAEMANO (12-24-2015)
Old 12-23-2015, 04:55 PM   #9786
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
I did that with my 4 battery setup. I just put it on my table saw and sliced the lip off. I tried to attach a band of metal to the lip on the sides using rivets but they just pulled through, it would probably have worked fine with short bolts/washer/nuts, but I was tired of messing with it and wanted to try out my setup. I ended up just turning the tray so that the open side was the pointing to the passenger side fender and the batteries were taped in sets and haven't had any problem with them moving around.
Phantom ESC, OFH, OFT, K&N Drop in
Target70 is offline   Reply With Quote
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
