Old 11-13-2015, 03:38 AM   #967
steve99
Originally Posted by riboyster View Post
Not sure that it's learning or active. The only indication I have that it is active is that it's transmitting a single value for the duration. It won't move on my trouble areas yet, so there's definitely nothing to learn.
From what i have observed flkc and fbkc are always active as is stft , however untill i suspect the coolant is up to a certain temp the stft corrections dont alter ltft and the iam wont be altered either till car warms
up.
Their may also be some learning or calibraton of knock sensors after an ecu reset
some info below on knock strategy its for 16bit ecu but most appears to apply to 32bit ecu like we have
http://www.romraider.com/forum/topic1840.html
Old 11-13-2015, 12:23 PM   #968
JB86'd
JB86'd's Avatar
Drives: JAWS
From Wayno's guide:
2.2 DISCLAIMERS FOR ADJUSTING TIMING YOURSELF
Your worst enemy here is making adjustments on false data.
Gotcha's:
- Your ECU will not record knock immediately after flashing
- Your ECU will record knock due to fuel not having sufficient time to adapt
- Your ECU will record knock based on fluke knock or external sounds
This is why I asked how many miles you had on that flash before doing the WOT run, just to be sure it was given a bit of time to learn.
Old 11-13-2015, 02:44 PM   #969
steve99
I'm not certian these statements are completely true
Use your OFT tuning alerts and set up knock alerts
FLKC < -0.7
Knock Correction < -0.7
IAM < 0.9
Ive recorded knock 500m down the road after flash
If you maf scaling is good it wont need time to adapt, also in closed loop its adapting all the time and very quickly (stft)
Yes in open loop stored ltft need to be learnt and applied but these should be minimal if maf scaling is good.
This is certainly possible, but unless you have exhaust hitting on chassis or loose nuts/bolts or something else creating "noise" at the correct frequencys to effect knock sensor readings it should not be a problem for most people.
Old 11-21-2015, 03:08 AM   #970
riboyster
riboyster's Avatar
Drives: 2013 Scion FRS
Here's a question:
Pulling Timing in trouble areas = good.
Advancing Timing in flkc > 0 areas = ?
ScreamingElectron - SnakeShit
riboyster is offline   Reply With Quote
Old 11-21-2015, 03:59 AM   #971
steve99
Here's a question:
If your on petrol you could add a bit of timing in areas showing no knock.
If you seeing positive flkc values it means ecu is returning timing pulled last time it went through that rpm/load range.
you also need to be careful that the timing you add does not cause knock in all circumstances like hot/cold conditions light load heavy load. When car rearly hot like at track or sustained hard driving. Dont just rely on one or two runs.
most tuners will find the max timing then back it off a bit.
You can also add fuel to reduce knock and finding max power is a balance between timing fueling and intake/exhaust cam timing etc.
On E85 you rarely need a dyno as it may go past MBT without knock
Old 11-21-2015, 04:03 AM   #972
riboyster
riboyster's Avatar
Okay so I was predominantly talking about positive flkc values. Interesting. So flkc kinda acts as a running average that governs IAM.
I think I'll not advance timing then. I'd imagine wayno has got it pretty good at the current point.
Old 11-21-2015, 04:30 AM   #973
Kodename47
Kodename47's Avatar
Drives: UK GT86
FLKC is can only be positive when IAM is less than 1.
.: Stealth 86 :.
Kodename 47 DJ:
Old 11-21-2015, 04:33 AM   #974
riboyster
riboyster's Avatar
Good to know.
Old 11-28-2015, 05:26 PM   #975
riboyster
riboyster's Avatar
Almost there with the 89oct tune!! Take a look guys! Just working on the final timing issues at loads of 0.9, 1.1 and 1.0.
Will have virtual dyno later on this week when my corrected log is learned.
http://www.datazap.me/u/riboyster/kn...data=1-4-10-11
Old 12-02-2015, 11:39 AM   #976
riboyster
riboyster's Avatar
Okay Steve, I've got something for ya. How do I get my car to make positive flkc readings? Right now it only does in the 4000rpms at moderate load, which makes me look like a speedy asshole.
Old 12-02-2015, 11:56 AM   #977
steve99
like @Kodename47 said FLKC will only be positive if the IAM is less than one.
FLKC positive is the ecu returning timing and testing if it can increment the IAM back towards one.
What your aiming for is to have the iam at one most of the time. the odd drop to 0.9 occasionally is ok as is the odd bit of negative flkc or fbkc of -1 or so, especially on low grade 89 fuel.
Old 12-02-2015, 12:02 PM   #978
riboyster
riboyster's Avatar
Is there any way to instigate it?
Old 12-02-2015, 12:24 PM   #979
Kodename47
Kodename47's Avatar
Drives: UK GT86
Instigate what?
.: Stealth 86 :.
Kodename 47 DJ:
Old 12-02-2015, 05:36 PM   #980
riboyster
riboyster's Avatar
What conditions do I need in order to have my car raise the IAM? Since my last correction (pulling timing in troubled areas), my IAM has dropped to 83 and is probably still dropping.
OpenFlash Tablet v1.42b maps now available Shiv@Openflash Software Tuning 159 09-13-2016 12:29 AM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 05:23 PM
OpenFlash Tablet: v1.60 OTS Maps (beta)-- USDM testers wanted Shiv@Openflash Software Tuning 142 07-22-2014 10:21 PM
Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) Shiv@Openflash Software Tuning 255 02-15-2014 04:43 AM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 08:45 PM
