Old 08-11-2014, 11:09 AM   #967
FrX
Drives: 2013 Scion FR-S, 1993 Lexus SC300
Originally Posted by protpibe View Post
After spending another 2 hours of my time determined to find out where the blowing exhaust is coming from, I confirmed that it was the turbo to header flange
I had the same deal happen recently. I blew out the gasket during a track day at the end of June. The lock nuts were only finger tight. I know for sure that they were checked before going into the car. I assume they lost their temper or just weren't suited to the heat expansion cycles. I put it all back together with some nord-lock washers and some 2100F threadlocker (Resbond 907). If that doesn't hold, I will invest in some tooling to safety wire the sucker together.
FrX is offline   Reply With Quote
Old 08-11-2014, 11:37 AM   #968
Maximal
Maximal's Avatar
Drives: Dodge Stealth
Figured some of you guys might be interested in our new oil cooler kit..
http://store.maximalperformance.com/...i-1981916.aspx
/shameless plug
Maximal is offline   Reply With Quote
Old 08-11-2014, 11:54 AM   #969
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Jeez, after seeing two of these blown, I wonder if that is where my exhaust leak is really coming from.....
Well, when I work on the clutch, guess I can drop the whole header/turbo assembly and check everything.
Old 08-11-2014, 12:00 PM   #970
protpibe
protpibe's Avatar
I'm 99% sure I'm going to be going back to re-do it, when I do I'm going to do the same setup as you (nord loc washers, threadlocker, etc). I put it back together with permatex copper, which I'm sure won't last, but I used cone nuts and torqued it down after the gasket had time to setup.
Any thoughts on using no gasket at all? I've heard of people using no gasket between the turbo and header with success since the extreme heat seals the two flanges together. They obviously have to be perfectly flat.
Also, has anyone here used alcohol or meth injection? I just recently picked up a bad batch of 94 oct here in Winnipeg and it put a bit of scare in me. Woudln't mind setting up a small alcohol injection system as a safeguard.
Old 08-11-2014, 12:50 PM   #971
sweetfrs
sweetfrs's Avatar
Drives: 2013 FRS
kind of an off topic question guys, i want the avo turbo but I'm wondering if you can use any aftermarket cai with it other than the perrin?
sweetfrs is offline   Reply With Quote
Old 08-11-2014, 01:11 PM   #972
Draco_PR23
Fiebru
Draco_PR23's Avatar
Drives: Scion FR-S and Integra Type R
The Mishimoto CAI should work with the kit.
Current Cars:
2017 White Platinum Ford Fiesta ST
2013 Raven Scion FR-S
2012 Spruce Mica Toyota Tacoma TRD Off-Road
2000 Phoenix Yellow Acura Integra Type R
Draco_PR23 is offline   Reply With Quote
Old 08-11-2014, 01:38 PM   #973
protpibe
protpibe's Avatar
Like Draco said, the Mishimoto should work but I haven't seen one to say 100 percent. What's wrong with the perrin?
Old 08-11-2014, 01:50 PM   #974
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
Hows everyone dealing with spark plugs? Im getting sold on this kit but coming from 2 bolt on turbo cars, plugs get changed alot which iant a 5min job on this car
IG-Joey_Soul
Old 08-11-2014, 01:51 PM   #975
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
My friend ran meth in his 600whp WRX. He called it the biggest PTA he has ever dealt with.. He suggested I de-tune before considering meth injection. But we do live in Saskatchewan so everything was shipped, custom built, etc, so I am sure that caused more headaches too.
Old 08-11-2014, 02:16 PM   #976
sweetfrs
sweetfrs's Avatar
Drives: 2013 FRS
nothing wrong with perrin, just doing supporting mods and was wondering what my options were
Old 08-11-2014, 02:34 PM   #977
protpibe
protpibe's Avatar
Ah OK that makes sense, I was gonna a say the perrin is a really nice intake.
Unless you're doing it for the sound, an upgraded panel filter is more than enough. Just a heads up
Old 08-11-2014, 03:58 PM   #978
solus
Drives: 2014 Scion FRS (Ultramarine)
question... is an oil cooler necessary for DD?
solus is offline   Reply With Quote
Old 08-11-2014, 04:02 PM   #979
solus
working with Drift Office to get a AVO kit? Here is my list of items...
AVO Stage 1.5 Kit
8 PSI Actuator
3 Bar Map Sensor
Stage 3 Clutch (Comp Clutch, SSC with OEM Throwout Bearing)
AVO 2.5 inch OP / FP Combo
Perrin 3 Inch Exhaust
Anything else I'm missing?
Oil cooler?
Catch Can?
Gauges? boost, wideband, AFR...
Its been awhile since I had a turbo'd car... and trying to get back into it. This is a DD for sure though and I want to stress reliability
Old 08-11-2014, 04:20 PM   #980
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by solus View Post
Oil cooler? YES
Catch Can? YES
Gauges? boost, wideband, AFR... YES
See above in red.
avo, avoturboworld
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 10:58 PM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
OFF TOPIC: Spotted a Gallardo markmatley Hawaii 4 02-24-2013 04:26 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
