Old 07-28-2015, 02:23 PM   #85
TurboBRZ
TurboBRZ's Avatar
Drives: 2013 BRZ Limited
Originally Posted by Top-Secret View Post
im looking forward to seeing if this kit holds up or not. make sure when doing pulls for the tune you are filming it just incase of some huge failure for us all to see
LoL - Will Do!
With my luck so far on this car it may just explode
The BlueBaru Turbo Rebuild: http://www.ft86club.com/forums/showthread.php?t=90382
I Rebuild BRZ's for Breakfast.
TurboBRZ is offline   Reply With Quote
The Following User Says Thank You to TurboBRZ For This Useful Post:
raven1231 (07-28-2015)
Old 07-28-2015, 06:00 PM   #86
Top-Secret
Drives: FRS monogram
hey, when things break it is just an excuse to go buy nicer replacment parts. atleast that is what i tell myself when i need to feel better about breaking random things and wasting countless amounts of money on things i shouldnt be.
AND
if it blows up that will make for a very awesome video
Top-Secret is offline   Reply With Quote
The Following 3 Users Say Thank You to Top-Secret For This Useful Post:
CrispyCheddar (07-28-2015), raven1231 (07-28-2015), TurboBRZ (07-28-2015)
Old 07-31-2015, 10:40 AM   #87
Top-Secret
http://www.ft86club.com/forums/showthread.php?t=74391
i did just stumble across this build which im reading now. but he was running a CX turbo kit with i imagine little to no issues soo we have hope that it may not explode
Old 07-31-2015, 10:51 AM   #88
raven1231
Yeah, I mentioned him earlier in the thread. He's is now going with an LS1 swap that cx racing is also making a kit for. He told me the kit was pretty solid as is.
Old 07-31-2015, 10:58 AM   #89
Top-Secret
yea im slowly reading into that, you would think after blowing the motor twice with what im assuming was the CX kit that he would not go with CX again. but pretty sure they are a sponsor so i hope they are atleast covering all the bills
The Following User Says Thank You to Top-Secret For This Useful Post:
raven1231 (07-31-2015)
Old 07-31-2015, 11:03 AM   #90
raven1231
That's the conclusion I came too. He has to be getting reimbursed by them, or works for them in some form or another.
Old 07-31-2015, 01:21 PM   #91
TurboBRZ
TurboBRZ's Avatar
Or if you know the mechanics of how all this stuff works - the motor blew because of countless reasons related to air fuel/temp, oil, etc... The motor isn't going to blow because of what brand turbo is pushing air into it. It might blow because too much air is blowing into it, but not because of what label is slapped on the outside.
While the CX kit may not be a true pro quality kit, it can be for a small extra fee - about $600. $100 to machine the flanges on the manifold, $250 for a tial wastegate, $200 for a BOV and $50-$100 for a better air filter. Throw in $10 for some better bolts and you have a very nice kit. And no - I'm not sponsored by anyone but Visa lol.
Old 07-31-2015, 07:20 PM   #92
migueralliart
migueralliart's Avatar
Drives: 2013 Firestorm FRS
I'm very interested in the cxracing manifold plus downpipe combo. Why would you machine the flange? The tial f38 fits right in and it is a proven wastegate. I might have to get this and start gathering my parts and the intercooler kit.
The build is looking good !
migueralliart is offline   Reply With Quote
Old 07-31-2015, 07:23 PM   #93
TurboBRZ
TurboBRZ's Avatar
The flange that bolts up to the motor on either side (to the exhaust ports on the heads) is poorly milled and looks like someone tried to give it a flat surface with a grinder at some point... So when you install it (in my case at least) without silicon RTV sealant on top of the crush gasket, there is a small gap between the flange and the engine that can allow exhaust to leak out.
I decided to remove the light weight crank pulley as I've heard too many horror stories on this motor, which required me to remove the turbo manifold - so I had the flanges milled to a nice flat surface for re-installation.
The downpipe is nice and fitment is really good. I got the downpipe wrapped finally too. Putting most if not all of it back together tonight.
Old 07-31-2015, 11:47 PM   #94
TurboBRZ
TurboBRZ's Avatar
So here are the newly milled Turbo manifold flanges (no RTV sealant any more - perfect fit):
And here is a picture of everything coming back together again now that the stock crank pulley is back in place. New additions: Tial wastegate (purple for some contrast) and Greddy FV BOV + blue silicone vacuum lines.
At this time I can't modify the oil pan and drain line from the turbo, but will likely do so after my first oil change to eliminate the slight upward bend the oil must take to return to the oil pan. Gravity does put it in there and when I took the oil line off the turbo the oil was a good 5" down the tube (not backed up to the turbo), but just to be safe as other members have pointed out I will move it the next time it makes sense to do so.
Tomorrow the new Koyo radiator goes in and it's ready for the first (non-tuned) test drive with the MAF disconnected. Then next week at some point it's time to get tuned.
Old 08-01-2015, 11:26 PM   #95
TurboBRZ
TurboBRZ's Avatar
I hate intercooler piping
I think just about the hardest part of any turbo install is the damn intercooler piping... If I never have to install a FMIC again it will be too soon.
Blitz filter, Tial wastegate, Greddy BOV, Koyo radiator and factory crank pulley installed.
Tomorrow the coolant gets put in and I bleed the brakes. Hopefully I will get to drive it tomorrow for the first time...?
2nd gear is dead - Perrin bushing and Megan Racing trans mount didn't remedy the issue.
raven1231 (08-02-2015)
Old 08-02-2015, 12:48 AM   #96
migueralliart
Did you have to modify the be radiator fans or the crash bar to fit the turbo or intercooler?
What diameter is the downpipe then it merges with the oem piping?
I'm pulling the trigger on the manifold pretty soon. How much did you mill off? 1/32"?
Sorry for all the ?'s
Old 08-02-2015, 09:48 AM   #97
TurboBRZ
TurboBRZ's Avatar
With a factory radiator I didn't have to modify the fan shroud, but with the Koyo I had to cut off 1 of the 4 "arms" that hold the fan in position to clear the turbo. I think the turbo they include with the kit is one of the biggest you can fit within the area it sits.
The downpipe is 3" internal diameter where it meets the factory exhaust.
I believe they only milled about 1/32" - nothing much but it made a huge difference on fitment. You'll be happy with their manifold, just get it milled like I did so you have no issues. And use the oem gaskets.
Old 08-02-2015, 07:09 PM   #98
TurboBRZ
TurboBRZ's Avatar
Took the car out for the first test drive today:
I'm thinking about painting the intercooler black to give it a true "Sleeper" look.
The Following 4 Users Say Thank You to TurboBRZ For This Useful Post:
hmong337 (08-03-2015), raven1231 (08-02-2015), srizzors25 (08-11-2015), Travisty75 (08-02-2015)
brz cx racing turbo, brz rebuild, brz turbo
Ultimate Racing Turbo Kit sweetfrs Forced Induction 34 12-17-2015 11:25 AM
Ultimate Racing Turbo Kit ganz954 Forced Induction 19 11-13-2014 10:34 PM
91 MR2 Turbo with KO Racing GT35R Turbo Kit Unleashed Cars for Sale/Trade 2 02-21-2013 05:18 PM
91 MR2 Turbo with KO Racing GT35R for sale/trade for FR-S turbo kit Unleashed Cars for Sale/Trade 8 02-20-2013 06:26 PM
