Old 07-03-2012, 01:47 PM   #85
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Hahaha... I literally JUST emailed Apexi USA to get information.... but I will add this to the list right now...
Old 07-03-2012, 03:09 PM   #86
DarrenDriven
NW Region Moderator
Updated Eibach spring info...
Originally Posted by Jackson View Post
Pro-Kit (82105.140)
Front: lowers 1" | rate 148-200lbs/in
Rear: lowers 1" | rate 103-274lbs/in
Sportline (4.10582)
Front: lowers 1.4" | rate 120-211lbs/in
Rear: lowers 1.4" | rate 86-296lbs/in
Both kits are progressive in design but that initial rate doesn't mean much. Even at static height the spring will already be into the upper end of the progessive rate.
Old 07-03-2012, 03:15 PM   #87
Jackson
Jackson's Avatar
Drives: E46 M3 (daily) / EG Civic (track)
Jackson is offline   Reply With Quote
Old 07-03-2012, 04:52 PM   #88
SubaruOnlineParts.com
Drives: Sidewayz
Please Update Subaru BRZ OEM springs
Part no's MSRP's
Manual Front 20330CA010 79.70
Manual Rear 20380CA010 79.70
Auto Front 20330CA020 79.70
Auto Rear 20380CA010 79.70
Also included sways if interested in adding
Front Sway Bar 20401CA000 148.67
Rear Sway Bar 20451CA010 118.93
Thanks, Benny
Last edited by SubaruOnlineParts.com; 07-03-2012 at 04:56 PM. Reason: added msrp's
SubaruOnlineParts.com is offline   Reply With Quote
Old 07-03-2012, 07:58 PM   #89
harajukukei
Drives: MB c230k
Espelir Springs 10-15mm drop
rates are 3.2/5
http://www.espelir.co.jp/img/new_ite...ota/zn6-86.pdf
harajukukei is offline   Reply With Quote
Old 07-03-2012, 10:16 PM   #90
DarrenDriven
NW Region Moderator
I added the OEM Subaru info and also the Espelir springs. I estimated the Espelir drop that is listed as 10-15mm as 0.5", which is somewhere in the middle.
Old 07-04-2012, 09:32 AM   #91
BadCompany235
#TrackAddicts
BadCompany235's Avatar
Drives: The Dipped Car
didn't read the whole thread but i didn't see anything about JRZ... a very reliable source told me that they are developing RS series coilovers for the BRZ/FRS... and i don't have my car for a few weeks...
BadCompany235 is offline   Reply With Quote
Old 07-04-2012, 12:58 PM   #92
DarrenDriven
NW Region Moderator
Emailed them... will wait for their reply.
Old 07-04-2012, 05:23 PM   #93
harajukukei
Drives: MB c230k
Ohlins BTO model coilovers
http://ohlins.czj.jp/auto/Item/BTO-ZN6_DFV_HAL.html
Old 07-05-2012, 02:56 PM   #94
harajukukei
Drives: MB c230k
RSR downsus and TI2000 springs, 10-15mm drop and rates are F 2.82/ R 4.49
"super down" coming soon will be 25-35mm drop and rates will be 3.16/4.49
Old 07-05-2012, 03:05 PM   #95
harajukukei
Drives: MB c230k
RSR Sport coilovers will be offered in 3 different spring rates with or without pillow mounts. 24 way adjustable damping force.
normal rates will be 6/7
soft rates will be 5/6
hard rates will be 7/8
Max adjustment is +15, -40 for the front, +30, -80 for the rear
Old 07-05-2012, 08:23 PM   #96
DarrenDriven
NW Region Moderator
Added Ohlins and RS-R info, thanks!
What is the difference between RS-R Down and Ti2000 Down springs, since they have the exact same drop and spring rate? Same with Super Down and Ti2000 Super Down. Confused.
Also, I think that I need to add two more columns with Y/N/O (optional) values for Pillowball (P/B) and Camber Adjustment (C/A). This means that I have to go through everything again to check...
Old 07-06-2012, 08:50 PM   #97
DarrenDriven
NW Region Moderator
Added KSport Kontrol Pro coilovers which are scheduled to be available in August. No specs yet.
Old 07-07-2012, 10:27 PM   #98
harajukukei
Drives: MB c230k
Darren, I think the TI2000 are possibly titanium and lighter. Either way they cost double what the regular downsus springs cost.
brz aftermarket coilovers, brz aftermarket springs, brz coilover, brz coilovers, brz lowering springs, brz springs, brz suspension, fr-s coilover, fr-s coilovers, fr-s lowering springs, fr-s springs, fr-s suspension, frs coilover, frs coilovers, frs lowering springs, frs springs, frs suspension, scion fr-s coilover, scion fr-s coilovers, scion fr-s springs, subaru brz coilovers, subaru brz foru, subaru brz forums, subaru brz springs
Adjustable shocks+ springs vs Coilovers CyberFormula Suspension | Chassis | Brakes -- Sponsored by 949 Racing 44 06-08-2013 03:59 PM
Canadian FR-S options VS U.S.A's options? Tino Scion FR-S / Toyota 86 GT86 General Forum 15 11-06-2012 10:07 PM
coilovers or springs? koyv90 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 45 04-01-2012 08:49 PM
Gearing Options and Diff options airboy808 Engine, Exhaust, Transmission 26 12-25-2011 01:11 PM
Subaru BRZ different suspension / springs tuning ahausheer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 35 12-06-2011 12:52 PM
