Old 07-10-2014, 04:48 AM   #85
HaDDeS
Touge worship
HaDDeS's Avatar
Drives: Forester STi SG9
Originally Posted by Khánh View Post
i don't know anything about dynos but i'm a bit lost on this .. if dynapack reads at the hub and there is no tire friction, doesn't that equate to dynoing higher than dynoing at the wheel? no friction= less pwertrain loss? am I not thinking correctly?
Indeed you are not, the dynapack itself absorbs energy and you still measure the power after the kinematic chain ... its not a "engine dyno", the gearbox dissipates energy by friction, the prop shaft does, the diff does ... the bearings do, all that kinematic chain from the flywheel to the rear wheels hub dissipates energy in frictions ... and that usually is accepted to be up to 16% itself.
so losses + dynapack loss = that number.
Yes it could be corrected, ajusted so it looks "better" but whoever knows about Dynos, and a given car has been "dynapacked" knows that the raw result will be lower than other solutions. Once again, when you tune a car, the Delta is important, not the absolute raw number ...
HaDDeS is offline   Reply With Quote
The Following User Says Thank You to HaDDeS For This Useful Post:
CSG Mike (07-11-2014)
Old 07-10-2014, 06:03 AM   #86
Calum
That Guy
Drives: 2013 asphalt FRS MT
A dynapack will read lower than an engine dyno but typically higher then a chassis dyno.
Old 07-10-2014, 07:32 AM   #87
HaDDeS
Touge worship
HaDDeS's Avatar
All the dynapacks i know read less than all the other dynos ....
Old 07-10-2014, 07:40 AM   #88
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by nelsmar View Post
If you are familiar with MAHA dyno's they will do a wind down to detect drivetrain loss, you can see my car losing ~58HP at via the drivetrain. A number of OEM's use these dyno's for chasis testing as they can estimate the crank power as well. Given i don't know everything about how the calculation works or the real answer to drivetrain loss but from what I have been told it is fairly accurate. *shrug*
Probably got our wires crossed. I know about wind down loss calculations and anywhere around 50bhp is possible and actually very likely. What I meant was that if there are 50bhp losses at 150whp, does not mean 300whp = 100bhp losses.
.: Stealth 86 :.
Kodename 47 DJ:
Old 07-10-2014, 05:42 PM   #89
scmil95eg
Drives: '95 delSol, '13 EvoX, '14 Leaf
There are fixed drivetrain losses and variable drivetrain losses simultaneously occurring. Combined, they represent an overall percentage of drivetrain loss, which is definitely proportionate to power & speed.
To understand the big picture, you have to understand all the elements occurring on each "side" independently.
4 major elements on the "fixed" side of things are:
transmission gear tooth angles; more angle = more DT loss
final drive gear tooth angles; again more angle = more DT loss
[read: http://www.ehow.com/how_6513778_calc...cal-gear.html]
Trans ratios / FD ratio / tire size; less mechanical leverage = more DT loss
[dyno your car in 1st gear vs. 6th gear to see the effect of mech. leverage)
Rotating mass; more rotating mass requires more energy = more DT loss
[pick up something that weighs 1 lb, then pick up something that weighs 1000 lbs and decide which took more effort]
Gear tooth angles, weights, and ratios don't change over the course of any given RPM band (forget shifting gears) so you can consider these "fixed" or "constant" losses.
The "variable" side of DT loss changes in relation to power & speed:
Friction - input/output shaft bearings, diff bearings, wheel bearings, tire friction - all increase proportionately with speed. Low RPM = lower DT losses / High RPM = higher DT losses
You also have friction between the trans gears and FD gears. And it shouldn't be too hard to understand that the friction between two gears in a 200 HP car will be less than the friction between two gears in a 400 HP car. DT loss will be proportionate to the difference in power. Simply put; the gears are transferring more power, more power = more friction = more DT loss
RPM/Speed goes hand-in-hand with this. Higher speed = more gear tooth engagements within a given period of time = more DT loss. Again, the loss will be proportionate to speed.
There's also centrifugal losses and torque converter losses and one could write a doctorate thesis on the topic as a whole. But I just wanted to give some food for thought because DT loss isn't a fixed value. And you really need some qualifiers before you can say it's just a fixed percentage as well.
scmil95eg is offline   Reply With Quote
The Following 2 Users Say Thank You to scmil95eg For This Useful Post:
6pack (07-10-2014), sato (09-05-2014)
Old 07-10-2014, 09:25 PM   #90
6pack
6pack's Avatar
Drives: GT86
Originally Posted by scmil95eg View Post
There are fixed drivetrain losses and variable drivetrain losses simultaneously occurring...
Great point.
I was about to say that power loss can't be a static value for several reasons.
Acceleration is related to a coefficient. Friction is related to a coefficient. Innertia is related to a coefficient. Distorsion/Dissipation/Rotation/Penetration are related to a coefficient too. All these are factors/coefficients/proportionality.
...aaaaanyway, just timed it tonight with DashCommand: 0-60 4.0 secs!
6pack is offline   Reply With Quote
The Following User Says Thank You to 6pack For This Useful Post:
troek (07-30-2014)
Old 07-11-2014, 02:20 PM   #91
6pack
6pack's Avatar
Drives: GT86
Some sound of my 86:
[ame="https://www.youtube.com/watch?v=uCxxMBUN4kc"]MONSTAKA GT-86 / BRZ HKS V2 SUPERCHARGER - YouTube[/ame]
The Following 11 Users Say Thank You to 6pack For This Useful Post:
*KID* (08-08-2014), azian_advanced (07-22-2014), CxG (08-03-2015), Efferalgan (07-11-2014), GhostOp86 (01-04-2015), illmatic (07-11-2014), JonAvalon (07-13-2014), MVLSCROWNZ (07-15-2014), R2RO (08-31-2014), RUNAMUK (07-11-2014), troek (07-30-2014)
Old 07-11-2014, 04:08 PM   #92
RUNAMUK
#Rememberthebuster
RUNAMUK's Avatar
Drives: 2013 Raven Scion Fr-s
RUNAMUK is offline   Reply With Quote
Old 07-11-2014, 04:31 PM   #93
This
Old 07-12-2014, 05:52 PM   #94
parkthetiger
parkthetiger's Avatar
Drives: 2014 Forester XT, Porsche 944
Stock : 200hp: 148WHP
Stage 1
Stock + HKS Premium Suction Kit: 206hp: 152WHP
Stock + HKS Premium Suction Kit + Invidia Q300 + Invidia Resonated Front-Pipe: 210hp: 156.0WHP
Stock + HKS Premium Suction Kit + Invidia Q300 + Invidia Resonated Front-Pipe + Tune : 227hp: 168.0WHP
Stock + HKS Premium Suction Kit + Invidia Q300 + Invidia Resonated Front-Pipe + Tune + HKS MANIFOLD : 238hp: 176WHP
Stage 2
Stock + HKS Compressor Kit V1 + HKS Manifold (stock intake & stock cat-back): 305hp: 226WHP
Stock + HKS Compressor Kit V1 + Invidia Q300 + Invidia Resonated Front-Pipe + Tune + HKS MANIFOLD : 348hp: 258WHP
Stage 3
Stock + HKS Compressor Kit V2 + HKS High Power cat-back + Invidia Resonated Front-Pipe + Tune + HKS MANIFOLD : 380hp: 281WHP
You all know that WHP is the number that counts (actually not even that, is the delta from the previous setup) so the hp values are what they are.
The Dynapack is severe, and I like that, and so is my tuner.
Aside from not using a restrictor, did you have to upgrade your injectors or fuel pump? Sorry if you've already answered this question but I didn't see any mention of it in the thread.
parkthetiger is offline   Reply With Quote
Old 07-14-2014, 02:17 AM   #95
HaDDeS
Touge worship
HaDDeS's Avatar
I think i can answer for them, no they didn't upgrade yet its still running on the stock fuel injection system.
Old 07-21-2014, 07:05 AM   #96
6pack
6pack's Avatar
Drives: GT86
Correct. Thanks HaDDeS.
Old 07-21-2014, 02:42 PM   #97
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
I was thinking the same thing...
Originally Posted by Kodename47 View Post
@6pack, how are the drivetrain losses going from 52hp to 101hp!? Something's not right there, the calculated flywheel hp is definitely not right. WHP figures look good though.
I was thinking exactly the same thing there...
If the Dyno is reading low, then do what other people do and state that, don't give the correct flywheel horsepower and the low read wheel hp together, it just gets confusing, either give the flywheel horsepower with an estimated correct BHP or just give the BHP with the caveat that the actual BHP is probably higher...
Jaden
Jaden is offline   Reply With Quote
Old 07-21-2014, 06:07 PM   #98
Skept
Drives: Subaru BRZ
I would really like to find out more about getting my hands on one of these kits.
Skept is offline   Reply With Quote
North America to get Subaru version but not Toyota version? Ground N Pound BRZ First-Gen (2012+) — General Topics 42 05-29-2014 01:23 AM
Hot Version Vol.116 ft. 86 & BRZ larryw BRZ Photos, Videos, Wallpapers, Gallery Forum 3 08-05-2013 03:14 AM
Hot Version Vol. 122 quik1987 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 5 06-12-2013 11:03 AM
New hot version 4agze Other Vehicles & General Automotive Discussions 19 03-07-2012 10:08 PM
Do you think we are going to see a trd version or 5axis version of the FRS next week DIG1992 Scion FR-S / Toyota 86 GT86 General Forum 9 01-04-2012 07:59 AM
