#85 | |
Touge worship
Drives: Forester STi SG9
so losses + dynapack loss = that number. Yes it could be corrected, ajusted so it looks "better" but whoever knows about Dynos, and a given car has been "dynapacked" knows that the raw result will be lower than other solutions. Once again, when you tune a car, the Delta is important, not the absolute raw number ... |
| The Following User Says Thank You to HaDDeS For This Useful Post: | CSG Mike (07-11-2014) |
#86 | |
That Guy
Drives: 2013 asphalt FRS MT
#87 |
Touge worship
#88 | |
Drives: UK GT86
.: Stealth 86 :.
#89 |
Drives: '95 delSol, '13 EvoX, '14 Leaf
There are fixed drivetrain losses and variable drivetrain losses simultaneously occurring. Combined, they represent an overall percentage of drivetrain loss, which is definitely proportionate to power & speed.
To understand the big picture, you have to understand all the elements occurring on each "side" independently. 4 major elements on the "fixed" side of things are: transmission gear tooth angles; more angle = more DT loss final drive gear tooth angles; again more angle = more DT loss [read: http://www.ehow.com/how_6513778_calc...cal-gear.html] Trans ratios / FD ratio / tire size; less mechanical leverage = more DT loss [dyno your car in 1st gear vs. 6th gear to see the effect of mech. leverage) Rotating mass; more rotating mass requires more energy = more DT loss [pick up something that weighs 1 lb, then pick up something that weighs 1000 lbs and decide which took more effort] Gear tooth angles, weights, and ratios don't change over the course of any given RPM band (forget shifting gears) so you can consider these "fixed" or "constant" losses. The "variable" side of DT loss changes in relation to power & speed: Friction - input/output shaft bearings, diff bearings, wheel bearings, tire friction - all increase proportionately with speed. Low RPM = lower DT losses / High RPM = higher DT losses You also have friction between the trans gears and FD gears. And it shouldn't be too hard to understand that the friction between two gears in a 200 HP car will be less than the friction between two gears in a 400 HP car. DT loss will be proportionate to the difference in power. Simply put; the gears are transferring more power, more power = more friction = more DT loss RPM/Speed goes hand-in-hand with this. Higher speed = more gear tooth engagements within a given period of time = more DT loss. Again, the loss will be proportionate to speed. There's also centrifugal losses and torque converter losses and one could write a doctorate thesis on the topic as a whole. But I just wanted to give some food for thought because DT loss isn't a fixed value. And you really need some qualifiers before you can say it's just a fixed percentage as well. |
#90 | |
Drives: GT86
I was about to say that power loss can't be a static value for several reasons. Acceleration is related to a coefficient. Friction is related to a coefficient. Innertia is related to a coefficient. Distorsion/Dissipation/Rotation/Penetration are related to a coefficient too. All these are factors/coefficients/proportionality. ...aaaaanyway, just timed it tonight with DashCommand: 0-60 4.0 secs!
| The Following User Says Thank You to 6pack For This Useful Post: | troek (07-30-2014) |
#91 |
Drives: GT86
Some sound of my 86:
[ame="https://www.youtube.com/watch?v=uCxxMBUN4kc"]MONSTAKA GT-86 / BRZ HKS V2 SUPERCHARGER - YouTube[/ame] |
| The Following 11 Users Say Thank You to 6pack For This Useful Post: | *KID* (08-08-2014), azian_advanced (07-22-2014), CxG (08-03-2015), Efferalgan (07-11-2014), GhostOp86 (01-04-2015), illmatic (07-11-2014), JonAvalon (07-12-2014), MVLSCROWNZ (07-15-2014), R2RO (08-31-2014), RUNAMUK (07-11-2014), troek (07-30-2014) |
#93 |
#94 | |
Drives: 2014 Forester XT, Porsche 944
#95 | |
Touge worship
its still running on the stock fuel injection system.
#96 |
Drives: GT86
#97 | |
Road-hole
Drives: 2013 Whiteout FR-S
I was thinking the same thing...
If the Dyno is reading low, then do what other people do and state that, don't give the correct flywheel horsepower and the low read wheel hp together, it just gets confusing, either give the flywheel horsepower with an estimated correct BHP or just give the BHP with the caveat that the actual BHP is probably higher... Jaden |
#98 |
Drives: Subaru BRZ
I would really like to find out more about getting my hands on one of these kits.
| North America to get Subaru version but not Toyota version? | Ground N Pound | BRZ First-Gen (2012+) — General Topics | 42 | 05-29-2014 12:23 AM |
| Hot Version Vol.116 ft. 86 & BRZ | larryw | BRZ Photos, Videos, Wallpapers, Gallery Forum | 3 | 08-05-2013 02:14 AM |
| Hot Version Vol. 122 | quik1987 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 5 | 06-12-2013 10:03 AM |
| New hot version | 4agze | Other Vehicles & General Automotive Discussions | 19 | 03-07-2012 09:08 PM |
| Do you think we are going to see a trd version or 5axis version of the FRS next week | DIG1992 | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 01-04-2012 06:59 AM |
