#85 |
Drives: 13 White MT FR-S
If you log before the car is on. the field will have a dash in it, and the program doesnt like that. All the columns except the header have to be numeric.
#86 |
#87 |
IDK about the OFT, Im using the openport2 to log. I have mine to trigger on the rpm but for some reason it will start logging with the engine is off but the ignition is on, so yeah.
#88 |
The Mechanic
Drives: Civic Turbo,FR-S
you want the excel file or jus put it in datazap?
#89 |
Drives: UK GT86
If you post a link to the csv log file then that's fine. Datazap is also fine as you can download the csv file anyway. I'll have a quick look for you.
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | vgi (05-20-2014) |
#90 | |
The Mechanic
http://datazap.me/u/grip-hooligan/30...g?log=0&data=1
#91 | |
Drives: frs
#92 |
Drives: UK GT86
Make sure that the OL/Status column and filter selection are as above.
If you're still having issues, open the containing folder and delete the config.xml file. If you haven't already you can get the latest update from github. Just delete the MafScaling.jar file and re-sync. That sould clear up any software issues if you are still having them.
.: Stealth 86 :.
#93 |
Drives: UK GT86
Here's a nice easy spreadsheet that I threw together for those with very uneven MAF curves:
https://dl.dropboxusercontent.com/u/...omparison.xlsx It's designed so that you can paste in your MAF curve and compare differing smoothing factors. It compares your curve against the OEM curve and the smoothing is based on that. It's a little different to the one applied in the java tool as it doesn't take into account your previous MAF scaling, just the original one. The idea is that if you've done multiple re-scales that you can see how it compares to stock. You can input an auto smoothing function out of the 5 available or create your own curve by copy and paste by picking and choosing what you want.
.: Stealth 86 :.
| The Following 3 Users Say Thank You to Kodename47 For This Useful Post: |
#94 |
How do you get it to paste vertically.
#95 |
The Mechanic
wth lol all you do is click load log first right? CL you set to 2 and OL about 90% am i missing a step
#96 |
The Mechanic
i just released mine says 1.2v on the top yours is 1.32. i found 1.32 now it loads up fine smh thanks guys.. whats the fastest way to transfer the fuel and voltage scaling tables over?
#97 | |
Drives: frs
#98 |
The Mechanic
hmm idk how you did that cause it kept giving me those same errors. i switched the whole folder to 1.32 and loaded up the same log the same way and it worked. i just finished the first pass at CL scaling. its a great program now that i know how to use it lol thanks
| AFR in Closed Loop | Toyota John | Software Tuning | 39 | 07-07-2019 09:26 AM |
| BRZedit Fuel Trims, Closed to Open loop transiton | mad_sb | Engine, Exhaust, Transmission | 32 | 08-06-2015 04:14 AM |
| Notes on injector / maf scalining using full time open loop | mad_sb | Software Tuning | 40 | 03-03-2014 06:49 PM |
| Screencast: closed loop boost control with RaceRom | jamesm | Software Tuning | 2 | 02-10-2014 03:23 PM |
| Screencast: experimenting with full-time closed loop fueling | jamesm | Software Tuning | 2 | 12-27-2013 11:19 AM |
