Old 05-19-2014, 10:27 AM   #85
ML
ML's Avatar
Drives: 13 White MT FR-S
If you log before the car is on. the field will have a dash in it, and the program doesnt like that. All the columns except the header have to be numeric.
Old 05-19-2014, 01:25 PM   #86
R2
Originally Posted by vgi View Post
you can do this with OFT?!
Yep, works for me.
R2 is offline   Reply With Quote
Old 05-19-2014, 01:52 PM   #87
ML
ML's Avatar
IDK about the OFT, Im using the openport2 to log. I have mine to trigger on the rpm but for some reason it will start logging with the engine is off but the ignition is on, so yeah.
Old 05-20-2014, 12:42 AM   #88
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
post you log somewhere so I could take a look at. and also the log file.
you want the excel file or jus put it in datazap?
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
Old 05-20-2014, 02:07 AM   #89
Kodename47
Kodename47's Avatar
Drives: UK GT86
If you post a link to the csv log file then that's fine. Datazap is also fine as you can download the csv file anyway. I'll have a quick look for you.
.: Stealth 86 :.
Kodename 47 DJ:
vgi (05-20-2014)
Old 05-20-2014, 10:23 PM   #90
Grip Ronin
The Mechanic
Grip Ronin's Avatar
ok thanks
http://datazap.me/u/grip-hooligan/30...g?log=0&data=1
IG-Joey_Soul
Old 05-20-2014, 11:29 PM   #91
vgi
Drives: frs
the file works fine for me for CL and OL (granted that it doesn't have any WOT pulls)
vgi is offline   Reply With Quote
Old 05-21-2014, 03:20 AM   #92
Kodename47
Kodename47's Avatar
Drives: UK GT86
Make sure that the OL/Status column and filter selection are as above.
If you're still having issues, open the containing folder and delete the config.xml file. If you haven't already you can get the latest update from github. Just delete the MafScaling.jar file and re-sync. That sould clear up any software issues if you are still having them.
.: Stealth 86 :.
Kodename 47 DJ:
Old 05-21-2014, 07:19 AM   #93
Kodename47
Kodename47's Avatar
Drives: UK GT86
Here's a nice easy spreadsheet that I threw together for those with very uneven MAF curves:
https://dl.dropboxusercontent.com/u/...omparison.xlsx
It's designed so that you can paste in your MAF curve and compare differing smoothing factors. It compares your curve against the OEM curve and the smoothing is based on that. It's a little different to the one applied in the java tool as it doesn't take into account your previous MAF scaling, just the original one. The idea is that if you've done multiple re-scales that you can see how it compares to stock.
You can input an auto smoothing function out of the 5 available or create your own curve by copy and paste by picking and choosing what you want.
.: Stealth 86 :.
Kodename 47 DJ:
The Following 3 Users Say Thank You to Kodename47 For This Useful Post:
freerunner (09-13-2016), ML (05-21-2014), steve99 (05-22-2014)
Old 05-21-2014, 08:44 AM   #94
ML
ML's Avatar
How do you get it to paste vertically.
Old 05-21-2014, 09:28 AM   #95
Grip Ronin
The Mechanic
Grip Ronin's Avatar
wth lol all you do is click load log first right? CL you set to 2 and OL about 90% am i missing a step
IG-Joey_Soul
Old 05-21-2014, 09:31 AM   #96
Grip Ronin
The Mechanic
Grip Ronin's Avatar
i just released mine says 1.2v on the top yours is 1.32. i found 1.32 now it loads up fine smh thanks guys.. whats the fastest way to transfer the fuel and voltage scaling tables over?
IG-Joey_Soul
Old 05-21-2014, 10:00 PM   #97
vgi
Drives: frs
version 1.2 works just fine as well. on a background your loaded file. On the front is the selection of the column for status and CL value in that column when I clicked load log button again.
Old 05-21-2014, 10:12 PM   #98
Grip Ronin
The Mechanic
Grip Ronin's Avatar
hmm idk how you did that cause it kept giving me those same errors. i switched the whole folder to 1.32 and loaded up the same log the same way and it worked. i just finished the first pass at CL scaling. its a great program now that i know how to use it lol thanks
IG-Joey_Soul
AFR in Closed Loop Toyota John Software Tuning 39 07-07-2019 08:26 AM
BRZedit Fuel Trims, Closed to Open loop transiton mad_sb Engine, Exhaust, Transmission 32 08-06-2015 03:14 AM
Notes on injector / maf scalining using full time open loop mad_sb Software Tuning 40 03-03-2014 05:49 PM
Screencast: closed loop boost control with RaceRom jamesm Software Tuning 2 02-10-2014 02:23 PM
Screencast: experimenting with full-time closed loop fueling jamesm Software Tuning 2 12-27-2013 10:19 AM
