Old 04-10-2014, 03:52 PM   #85
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
Originally Posted by Crawford Performance View Post
Sounds like it died from detonation, different rods will not take care of that issue.
You will need to lower the compression or run E85 / higher octane fuel to avoid the detonation with your current setup.
Wait what...? You're going to give the man the recommendation of running lower compression or ethanol without knowing ANYTHING else about the situation that caused the failure? You have no idea what his AFR or boost level was under WOT. You have have no idea if he was running premium fuel. You have no idea if the kit was installed correctly.
I think it's a little irresponsible to make such a drastic conclusion based on the little amount of information given, especially from a respectable shop.
2011 BMW M3 (No torque dip)
2013 Subaru BRZ - SOLD - Build Thread
Acree is offline   Reply With Quote
Old 04-10-2014, 03:59 PM   #86
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Seems par for the course to me. If you want more power than a set of billet power blocks will give you, then you need a Crawford short block with new rods and pistons.
The Following 4 Users Say Thank You to King Tut For This Useful Post:
Acree (04-10-2014), Dipstik-sportech (04-10-2014), sw20kosh (04-10-2014), whitefrs (04-10-2014)
Old 04-10-2014, 04:37 PM   #87
sw20kosh
Drives: 2013 Black FR-S
QFT
Really, if you are going to increase the power of this motor at all you need a built shortblock and lower compression as the compression from the factory is way too high even with DI being a factor.
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 09:46 AM
2013 FR-S Full Blown Motorsports Stage1 Turbo kit. Mustang Dyno results. Infamous Performance Forced Induction 10 07-03-2013 08:52 PM
FINAL RESULTS: Taking Full Blown Stage 1 To The MAX! @Pure Automotive (Dyno Inside!) Pure Automotive Forced Induction 57 03-27-2013 11:41 PM
The Results Are In!! Full Blown Stage 1 Kit @ Pure Automotive Performance! Pure Automotive Forced Induction 181 03-12-2013 02:11 PM
The Results Are In!! Full Blown Stage 1 Kit @ Pure Automotive Pure Automotive Mid-Atlantic 22 02-12-2013 10:13 AM
