Old 03-31-2014, 11:48 AM   #85
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
What is ghost cams? Is it compatible with spooky rockers?
- AdrianG
AdrianG is offline   Reply With Quote
The Following 3 Users Say Thank You to AdrianG For This Useful Post:
fuddbutter (06-18-2014), leicaboss (03-31-2014), shif7i7down (03-31-2014)
Old 03-31-2014, 04:39 PM   #86
gonzo
Drives: frs
- AdrianG
Causes exhaust and intake valves to overlap at idle so that they're both open at the same time. It causes a rough idle which makes the car sound like it has racing cams at idle.
And yes, it's compatible with spooky rockers
gonzo is offline   Reply With Quote
Old 04-03-2014, 10:05 AM   #87
HSayaovong
HSayaovong's Avatar
Drives: blk;2dr;rwd;fun
Any update or progress on the ghost cams?
Life is like taking a dump, sometimes it's easy and other times its hard. But it always stinks
HSayaovong is offline   Reply With Quote
Old 04-03-2014, 10:25 AM   #88
bee_are_zee
bee_are_zee's Avatar
Drives: GBS BRZ
I haven't had a chance to look at it again. I will give it another shot after work today. I now understand why some people were unhappy with how long the oft takes to flash. It is a slow process making small changes.
bee_are_zee is offline   Reply With Quote
The Following User Says Thank You to bee_are_zee For This Useful Post:
gonzo (04-04-2014)
Old 04-04-2014, 10:39 AM   #89
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
i dont belive ghost cam is possible in a 4ugse. our variable timing is far from the mustangs style
IG-Joey_Soul
Old 04-04-2014, 10:39 AM   #90
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Its been done, lemme pull the link
Sent from my IBrick
Old 04-04-2014, 10:42 AM   #91
SmsAlSuwaidi
Boosted
[ame]https://m.youtube.com/watch?v=I15ONURLT7E[/ame]
Sent from my IBrick
The Following User Says Thank You to SmsAlSuwaidi For This Useful Post:
gonzo (04-04-2014)
Old 04-04-2014, 12:56 PM   #92
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Originally Posted by SmsAlSuwaidi View Post
Sent from my IBrick
you sure thats in a custom ground cam?
IG-Joey_Soul
Old 04-04-2014, 01:04 PM   #93
SmsAlSuwaidi
Boosted
Weird thing is my buddy has a set of cams in has and the car wont lobe at all, the ecu adjusts the rpms straight away and raises it
Sent from my IBrick
Old 04-04-2014, 01:23 PM   #94
bee_are_zee
Drives: GBS BRZ
DIY Rom tuning for exhaust pops and backfires W/ romraider
Was his car tuned for those cams? It's possible to tune out the lobe on cams just as we are trying to put it in. And it's definitley possible to induce timing overlap with our vvt system I was able to to it, just not at true idle.
Edit tune out timing not lift
Old 04-04-2014, 01:38 PM   #95
Jrdad
Jrdad's Avatar
Drives: 2013 Scion FR-S 6M Argento
Would it be possible to set it up in such a way that the exhaust popping only occurs above a certain rpm? ie 4500?
Jrdad is offline   Reply With Quote
Old 04-04-2014, 01:42 PM   #96
bee_are_zee
Drives: GBS BRZ
I haven't personally done it but only dropping the timing above 4500 should do the trick.
Jrdad (04-04-2014)
Old 04-04-2014, 02:02 PM   #97
Grip Ronin
The Mechanic
Grip Ronin's Avatar
yes you just set them at the rpm you want when adjusting the map in tunerpro. mine are between 3-7k
Sent from my IBrick
not aggressive enough? whats the specs
IG-Joey_Soul
Old 04-04-2014, 07:06 PM   #98
gonzo
Drives: frs
Mine is set between 3800 and 5k. It got rid of the popping while cruising on the freeway.
rom tuning for pops and backfires andrew5826 Software Tuning 110 12-23-2016 04:39 AM
First romraider defs are up jamesm Software Tuning 95 01-13-2015 05:29 AM
Transient Ignition Retard Tables from RomRaider Ralph Spoilsport Issues | Warranty | Recalls / TSB 31 05-24-2014 07:48 AM
OFT-Help with Romraider/FFS and Launch Control-issues continuecrushing Software Tuning 9 04-17-2014 11:07 PM
Possible backfires Bg8780 Engine, Exhaust, Transmission 0 05-22-2013 02:12 PM
