#86 |
My Other Ride's a Jeep
Drives: 2013 BRZ Limited
#87 |
A good tune and a high reading dyno.
#88 |
Drives: 2013 Black FR-S
#89 |
Junior
Drives: a car
forged internals yes, but I wouldnt choose off the shelf pistons and rods. I would have custom pistons made for this motor.
After that the motor and tune arent the problem anymore, it becomes the clutch, tranny, axles and diff that need to be worried about at a 400 whp daily. And there you have it, $20k of imaginary money spent just like that.
#90 | |
Drives: 2014 FRS
I switched from mbc to standalone ebc and have everything from 6 to 11psi at the push of a button.... but I always end up at 11 because, it goes to 11. ![]() Sent from my SGH-T999 using Tapatalk |
#91 | |
Boosted Member
Drives: 2013 Subaru BRZ
Map1: wastegate pressure (sees between 6.8-8psi) Map2: 8psi gears 1-2, 12psi gears 3-6 Map3: 12psi gears 1-2, 16psi gears 3-5, 21psi gear 6 Map4: 21psi. I keep it on map 1 until the car is warmed up 100% and has been for a few miles. I would say 70% of the time I just use map 3 because it is more streetable. Map 4 is mostly just to see the reactions on friends faces when it throws them back into the seat even at "highway speeds" in 6th gear. The car sees 20+ psi almost every time I drive it.. unless I am just going to the store real quick and not getting out of the city area. I would have to dig up the dyno, but at 16psi the car made 365hp and I forget how much torque (I think 280?) It is also worth noting that my boost is limited in how quickly it lets it ramp up right now in the low-mid range.
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG 2011 Honda CBR1000RR 2010 Subaru Impreza WRX PRM SSM |
| The Following User Says Thank You to woode For This Useful Post: | onzippy (06-07-2014) |
#93 | |
Boosted Member
They are a pretty awesome shop, they do a ton of work on pretty much any and every tuner and modern muscle car out there.. hence why they aren't really super active on these forums I am guessing. I know some prefer hitting up a tuner that is more specialized in our platform (can't blame them) but R/T worked out great for me.
#94 |
Drives: 2014 FRS
You're happy, the motor's happy, sounds all good... But didn't you move?
Is e-turning your future at that psi? Sent from my SGH-T999 using Tapatalk |
| The Following User Says Thank You to onzippy For This Useful Post: | woode (06-07-2014) |
#95 |
Boosted Member
I'm about 4 hours from them now. I won't etune. I am planning an engine build over the summer/fall and will go from there. More than likely will stick with R/T.
#96 | |
Drives: 2014 FRS
![]() @ LOL. I can't figure out how to mention them... R/T Tuning |
#97 |
Drives: 2013 all stock frs
Isn't e85 bad for valves long term? Does this sound like a safe way to make 400whp? Fbm shortblock, stage 2 clutch, fbm turbo stage 1premium and fbm oil cooler. Would I need to upgrade and tranny parts? I just want 400whp DD!!! Lol
#98 |
in orbe terrum non visi
Drives: violent
No, yes and it depends on how much traction you have. No traction, no broken transmission.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
I have E85 where there isn't E85, that's my secret.
http://www.ft86club.com/forums/showt...t=reaper+build |
| 400HP Toyota GT86 GT4 Racer by GPRM | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 46 | 04-10-2015 09:31 PM |
| Nissan 400hp 88lb turbo 3 banger | Anthony | Other Vehicles & General Automotive Discussions | 3 | 01-27-2014 11:51 PM |
| 400hp build and other turbo questions. | Ludacrits | Forced Induction | 22 | 10-26-2013 09:01 AM |
| 400HP Firestorm Red FBM Kit | FullBlown | Forced Induction | 166 | 10-16-2013 05:54 PM |
| E85 400hp mark | Fabron757 | Forced Induction | 26 | 06-20-2013 01:41 PM |
