Old 06-06-2014, 11:32 PM   #85
jc1993
Drives: 2013 all stock frs
What kind of set up would allow u to make 400whp safely?
jc1993 is offline   Reply With Quote
Old 06-06-2014, 11:40 PM   #86
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
Originally Posted by cdrazic93 View Post
Why /5250?
A very good tune. Seriously, this is the most important part.
Luckrider is offline   Reply With Quote
Old 06-06-2014, 11:42 PM   #87
xwd
A good tune and a high reading dyno.
Old 06-07-2014, 01:05 AM   #88
sw20kosh
Drives: 2013 Black FR-S
Safely? E85 or race gas and big turbo. Forged internals.
Old 06-07-2014, 03:27 AM   #89
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
forged internals yes, but I wouldnt choose off the shelf pistons and rods. I would have custom pistons made for this motor.
After that the motor and tune arent the problem anymore, it becomes the clutch, tranny, axles and diff that need to be worried about at a 400 whp daily.
And there you have it, $20k of imaginary money spent just like that.
Old 06-07-2014, 04:26 PM   #90
onzippy
Drives: 2014 FRS
Originally Posted by woode View Post
Still going strong, almost 8k miles later!
Aside from blowing several vacuum lines off, zero issues.
Recently moved so depending on how quickly I get settled in I plan on starting to build the engine and try to start getting some track time in.
How much time do you spend on the 7psi map vs. the insanity map?
I switched from mbc to standalone ebc and have everything from 6 to 11psi at the push of a button.... but I always end up at 11 because, it goes to 11.
Sent from my SGH-T999 using Tapatalk
onzippy is offline   Reply With Quote
Old 06-07-2014, 07:32 PM   #91
woode
Boosted Member
woode's Avatar
Drives: 2013 Subaru BRZ
Send a message via MSN to woode
My maps are currently as follows:
Map1: wastegate pressure (sees between 6.8-8psi)
Map2: 8psi gears 1-2, 12psi gears 3-6
Map3: 12psi gears 1-2, 16psi gears 3-5, 21psi gear 6
Map4: 21psi.
I keep it on map 1 until the car is warmed up 100% and has been for a few miles. I would say 70% of the time I just use map 3 because it is more streetable. Map 4 is mostly just to see the reactions on friends faces when it throws them back into the seat even at "highway speeds" in 6th gear. The car sees 20+ psi almost every time I drive it.. unless I am just going to the store real quick and not getting out of the city area.
I would have to dig up the dyno, but at 16psi the car made 365hp and I forget how much torque (I think 280?)
It is also worth noting that my boost is limited in how quickly it lets it ramp up right now in the low-mid range.
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline   Reply With Quote
The Following User Says Thank You to woode For This Useful Post:
onzippy (06-07-2014)
Old 06-07-2014, 07:38 PM   #92
onzippy
Drives: 2014 FRS
Wow! R/t tuning has you dialed in.
Thanks.
Old 06-07-2014, 07:56 PM   #93
woode
Boosted Member
woode's Avatar
Thanks.
Ya.. my car was on the dyno for hours.. I don't even know how long. I spent several full days there with it on the dyno. Andy, one of the tuners there, has also been back n forth with my logs and sending me tweaked tunes for a few months anytime I think I feel something haha.
They are a pretty awesome shop, they do a ton of work on pretty much any and every tuner and modern muscle car out there.. hence why they aren't really super active on these forums I am guessing. I know some prefer hitting up a tuner that is more specialized in our platform (can't blame them) but R/T worked out great for me.
Old 06-07-2014, 08:09 PM   #94
onzippy
Drives: 2014 FRS
You're happy, the motor's happy, sounds all good... But didn't you move?
Is e-turning your future at that psi?
The Following User Says Thank You to onzippy For This Useful Post:
woode (06-07-2014)
Old 06-07-2014, 08:20 PM   #95
woode
Boosted Member
woode's Avatar
I'm about 4 hours from them now. I won't etune. I am planning an engine build over the summer/fall and will go from there. More than likely will stick with R/T.
Old 06-07-2014, 08:38 PM   #96
onzippy
Drives: 2014 FRS
Good to hear.. Keep going bigger. I love this thread.
LOL. I can't figure out how to mention them... R/T Tuning
woode (06-07-2014)
Old 06-07-2014, 09:06 PM   #97
jc1993
Isn't e85 bad for valves long term? Does this sound like a safe way to make 400whp? Fbm shortblock, stage 2 clutch, fbm turbo stage 1premium and fbm oil cooler. Would I need to upgrade and tranny parts? I just want 400whp DD!!! Lol
Old 06-07-2014, 11:39 PM   #98
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
No, yes and it depends on how much traction you have. No traction, no broken transmission.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
400HP Toyota GT86 GT4 Racer by GPRM Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 46 04-10-2015 09:31 PM
Nissan 400hp 88lb turbo 3 banger Anthony Other Vehicles & General Automotive Discussions 3 01-27-2014 11:51 PM
400hp build and other turbo questions. Ludacrits Forced Induction 22 10-26-2013 09:01 AM
400HP Firestorm Red FBM Kit FullBlown Forced Induction 166 10-16-2013 05:54 PM
E85 400hp mark Fabron757 Forced Induction 26 06-20-2013 01:41 PM
