Old 10-02-2014, 04:09 PM   #85
el-92
el-92's Avatar
Drives: 2014 ASPHALT FR-S MT
@steve99 alright can't wait till I'm off work to give it a try thanks again
el-92 is offline   Reply With Quote
Old 10-02-2014, 08:36 PM   #86
el-92
el-92's Avatar
OK whats the name of the file Romraider file im supposed you to be able to see LC in the tables ?
Old 10-02-2014, 09:16 PM   #87
steve99
download the v2 tunes from the openflash downloads site unzip, there will be bin files these are the tune files find the one you need for usa it wil be C for manual D for auto then select appropiate tune file stage 1/2 el headers ect
their is also a xml file directory thisis the romraider definition files when you open romraider go to definition files and point romraider to the correct definition file for your tune which will be the rom or calid for your original tune something like za1ja01c or similar, then open the appropiate tune file you downloaded.
Old 10-02-2014, 09:28 PM   #88
el-92
el-92's Avatar
@steve99 I got it I had to delete all the files start from scratch I have the v2 files now you were right thank you I'm going to go flash the car now I set it up to so it can launch at 4k thank you @steve99 for walking me threw the process
Old 10-24-2014, 12:23 AM   #89
unlimited86
Drives: s2000
read the OFT TIPS thread below its all in there
better still read all the links
ignore the checksum error message when you save rom it will be corrected and oft corrects the checksum anyway.
When it says calculate new checksum when saving do I click yes or no?
unlimited86 is offline   Reply With Quote
Old 10-24-2014, 01:41 AM   #90
steve99
yes you can correct the checksum. the oft will correct it anyway.
if you editing an OFT rom make certian your using the definitions from the OFT site else ecu = brick. Always check a couple of tables like base timing B an OL fuel tables to make sure everything look ok. just to be sure you have correct efinitions an definitions for v2tunes are different to the older v1.5 tunes must use orrect ones for your tune
Old 10-24-2014, 02:26 AM   #91
AlexBinJackson
Drives: 2015 Brz Blue Series Pearl White
D00C cal update
Anyone know when the lc and ffs will be available for d00C cals just got oft today and cant wait to tune.
AlexBinJackson is offline   Reply With Quote
Old 11-10-2014, 12:35 PM   #92
WHTEBRZ
Drives: BRZ Limited
^Yes! and same for B01c. i bought the oft thinking i would already have these features.
WHTEBRZ is offline   Reply With Quote
Old 11-12-2014, 04:03 AM   #93
KslayFRZ
KslayFRZ's Avatar
Drives: 2013 Frs asphalt
It's available for the bo1c. I just updated my maps about a month ago and it was added on.
Then I had to come back to this page and find out how to lower the limiter lol
I think it was at 6500 and I dropped it to 4
KslayFRZ is offline   Reply With Quote
Old 11-12-2014, 11:23 PM   #94
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
nevermind had an issue with romraider that couldnt be found online but some random poking for and hour and i fixed it
IG-Joey_Soul
Old 12-10-2014, 04:18 PM   #95
acj47
acj47's Avatar
I am using the v2.06 Stg2_EL_E85_A01C.bin map.
When I am using launch control, the engine will rev to two different RPM values based on the transmission in neutral vs. in gear (tested with 1st gear).
EDIT: all testing values below are at rest, i.e. 0 mph.
For example, I have tested it with (3) separate LC RPM Delta values.
(Launch Control Disable Speed is set to the default value (6), and Flat-Foot Shift RPM Delta is set to the default value (0) for all tests.
Launch Control RPM Delta value set at 3600 (7600-3600=4000 RPM)
- clutch off, neutral: RPM=3600
- clutch on, neutral: RPM=3600
- clutch on, 1st gear: RPM=4000
Launch Control RPM Delta value changed from 3600 to 3100 (7600-3100=4500 RPM)
- clutch off, neutral: RPM=4100
- clutch on, neutral: RPM=4100
- clutch on, 1st gear: RPM=4500
Launch Control RPM Delta value changed from 3100 to 2600 (7600-2600=5000 RPM)
- clutch off, neutral: RPM=4600
- clutch on, neutral: RPM=4600
- clutch on, 1st gear: RPM=5000
It seems that no matter the setpoint, with the transmission in neutral the RPM value = LC delta - 400 RPM. Has anyone else noticed this, and/or is it an expected behavior? It doesn't do any harm, I'm mostly just curious why it happens more than anything.
acj47 is offline   Reply With Quote
Old 12-12-2014, 10:32 AM   #96
acj47
acj47's Avatar
Has anyone else experienced the 400 rpm delta? Just curious if there's an explanation for why it happens.
Old 02-18-2015, 07:25 PM   #97
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
When you upload your edited tune to the oft (I changed the rpm on the launch control) is it supposed to say "The checksum of the file has been corrected" like it does with the off the shelf ones?
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Old 02-18-2015, 07:52 PM   #98
steve99
depends if you corrected the checksum with rom raider when you edited rom.
as per romraider tips link below always check some tables in the rom like ol fuel and base timing B to see all is ok.
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
Is Openflash tablet detectable? Boofneenee Software Tuning 25 05-02-2014 10:03 PM
WTB Openflash Tablet Vlady Want-To-Buy Requests 0 10-25-2013 12:10 AM
racerom flat foot shifting ft86me Engine, Exhaust, Transmission 10 07-25-2013 03:02 PM
EcuTek RaceRom Flat Foot Shifting ! Visconti Engine, Exhaust, Transmission 79 11-14-2012 09:36 PM
