Old 05-07-2014, 05:58 PM   #85
Jason@DSG
Jason@DSG's Avatar
Drives: 1997 Eagle Talon TSi AWD
Originally Posted by BRZPDX View Post
awesome info man, thank you. How long does it take to revalve/shipping it back? Should I expect about a 2week downtime on my car?
Also how would the DDability be affected so much for stage2 if it is just an added aggressive shift change from 4 to 6? Won't the 1 to 4 more commonly used during DD? Once its slapped in 5th or 6th, you don't shift gears too often..
I would say 4-5 business days tops to get it done, but 2 weeks to be safe (just in case they're backed up).
Also, if there's one in-stock on the shelf they'll just send you that one and keep your core so it would be a couple days tops.
For the gears, I just like everything shifting properly. I'm a stickler for proper shifting and we're only talking $100 or so difference to get the full setup.
Jason@DSG is offline   Reply With Quote
Old 05-07-2014, 09:33 PM   #86
Captain Insano
Can you or SSP do it in 1-2 days if I drive there and pay you labor?
Old 05-07-2014, 09:35 PM   #87
FastWhite
Drives: Subaru BRZ Limited M/T
Now everyone is talking about the up shift. How does it affect the downshift?
FastWhite is offline   Reply With Quote
Old 05-08-2014, 11:32 AM   #88
Jason@DSG
Jason@DSG's Avatar
Yep! I can definitely have you do it directly at SSP. The only issue is, if it's a core situation they have to pull it out and redo the whole valvebody which can take a couple days by itself. The actually install is very quick (probably only a few hours in and out).
If anyone wants to do an install directly at SSP, that works. They're in MN which is a pretty chill place so you could have a little mini vacay or something
Old 05-08-2014, 11:38 AM   #89
FastWhite
I thought they had a shop in Houston?
Old 05-08-2014, 12:04 PM   #90
Jason@DSG
Jason@DSG's Avatar
Good question! My bad actually, I never mentioned it
The downshifts aren't AS aggressive, they're a bit tighter but not like the upshifts.
The shifts are calculated by load so pedal position and amount of torque determine how hard the shifts are so redline will be all out, just cruising will be nice and tight.
They handle more painting and small installs, not really an all-out shop. The MN location is where manufacturing and more involved installs are done.
Old 05-08-2014, 12:09 PM   #91
FastWhite
Like you said, take a vacation. My wife would love area. Go hiking or canoeing.
It is doable.
Old 05-08-2014, 12:18 PM   #92
FastWhite
Jason@DSG, what fluid is used in the BRZ AT? I have researched this and found inconsistencies. Stock is ATF WS. A Dexron 6 type fluid. I can find Redline, Enoes, and Amsoil equivalents. When I go to the Motul site it lists both of there AT fluids as comparable.
I ask as no one has given me an answer. I called the Houston store and was told to use the MT fluid. The 75w90. By mistake I assume.
Can you answer this for me please.
Old 05-08-2014, 12:22 PM   #93
Dum11567
Dum11567's Avatar
Drives: Argento FR-S 6AT
would small installs include the torque converter and trans-cooler and exclude the valve body??
BRZ spoiler, Colin taillights, Valenti 4th brake light, GReddy Intake, OFT Stg 2 93 uel, JDL UEL catless headers, Motiv overpipe&HFC, Megan Black series CBE 5:AD S:7F 19x8.5, Tein Flex Z
Dum11567 is offline   Reply With Quote
Old 05-08-2014, 02:10 PM   #94
Captain Insano
I was thinking of paying the big price (no core) however long they need before I drive up.... then when the core is ready I drive up, they install, keep my original parts as core, discount me for the core, I drive away.... another happy customer.
I gotta save up the coin first though.
Old 05-08-2014, 03:45 PM   #95
kavanagh
Fat on Corn Syrup
*snip*
*snip*
I'm glad to hear this, so we can just cruise around at quarter throttle and shift below 3k and it will be relatively smooth? Firmer than stock, but not DCT hardcore?
I like firm shifts too, but since we DD and commute it's also nice to be able to sip coffee while driving...
and then crack our necks at the track!
Old 05-08-2014, 04:03 PM   #96
Jason@DSG
Jason@DSG's Avatar
So I just checked in with the Houston shop!
Good news, they're definitely equipped to do the install and as a bonus, they will give everyone a discount on the labor rate for us -- just say DSG referred you and you should get 20% off the labor rate
So anyone in the great Texas area and surrounding states, get 'er done at SSP Houston location and make sure to mention DSG to get your labor discount!
Motul ATF!! We and SSP have filled quite a few AT's with it already
It's load based so cruising will be tight, but not overkill. Redline and full load shifts actually shoot you forward, it's pretty crazy stuff man. you guys are going to really like it
Old 05-08-2014, 04:24 PM   #97
JonAvalon
SCBYD0
JonAvalon's Avatar
Drives: 18 BRZ (WRB)
Perfect thanks! I've been planning on taking a trip down to the Houston shop whenever i was ready to have the Torque converter and Valve body installed.
JonAvalon is offline   Reply With Quote
Old 05-08-2014, 04:43 PM   #98
Jason@DSG
Jason@DSG's Avatar
Good man! I'll have it all arranged for you that the parts are there and labor rate is discounted when you're ready. Just hit me up a week or two before (to give SSP time to put everything together).
Cheers!
Jason
Need Transmission Upgrades for Turbo? Admired Forced Induction 26 11-10-2013 02:48 PM
All Possible Car Upgrades? pwnisher Scion FR-S / Toyota 86 GT86 General Forum 31 07-23-2013 12:27 PM
Transmission moving after upgrades? Sniper2606 Engine, Exhaust, Transmission 2 07-10-2013 01:54 AM
GPS Map Upgrades? Enemies Electronics | Audio | NAV | Infotainment 0 04-20-2013 04:18 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
