Old 03-22-2020, 03:58 PM   #85
rixter145
Sleep Chomper
rixter145's Avatar
Originally Posted by 86TOYO2k17 View Post
Ah then you’ll have to weigh your options, but the os giken is supposed to not mess with backlash and need reshiming, could possibly get the 3.9 diff assembly for 3-400$ and swap over the Giken since bearings are already pressed may be pretty easy DIY. Otherwise you’re looking at about 4-500$ just on labor swapping in ring and pinion if you’re pulling assembly yourself. Now if you can DIY everything thats a different story.
Got it. I saw a ring pinion on the 3.9 for ebay at like $150. Might get that, send it to wpc for treatment, get the bearings like you said and swap them over. I don't mind paying for the extra labor
Sent from my H8314 using Tapatalk
rixter145 is offline   Reply With Quote
Final Drive Discussion JimmyMac Engine, Exhaust, Transmission 118 08-07-2017 10:18 PM
Change gear ratio? Afdad120108 Engine, Exhaust, Transmission 61 08-17-2016 10:44 AM
Final Drive Calculations wootwoot Engine, Exhaust, Transmission 34 12-19-2014 04:06 AM
Change FD ratio to 4.56 by changing only pinion peachch Engine, Exhaust, Transmission 1 08-31-2013 01:25 PM
Correcting drive ratio for accurate speed AlexTheGreek Engine, Exhaust, Transmission 25 12-05-2012 01:13 AM
