Old 06-27-2015, 08:04 PM   #85
Koa
Originally Posted by jsimon7777 View Post
@Koa
Best notice when people post. You're responding to 11-month-old posts. If his car has been in the body shop for 11 months, @TruRace has bigger problems to deal with.
no fucks given I'm drnk
The Following 6 Users Say Thank You to Koa For This Useful Post:
chaoskaze (08-31-2017), EAGLE5 (06-27-2015), IBill4You (06-28-2015), kch (06-29-2015), Kenny_LongWrench (12-11-2017), NoChance (06-30-2015)
Old 06-27-2015, 08:25 PM   #86
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Thumbs up Ahhhhhh yeah!
Post of the decade.
The Following 2 Users Say Thank You to EAGLE5 For This Useful Post:
Koa (06-27-2015), NoChance (06-30-2015)
Old 06-27-2015, 09:47 PM   #87
philooo
Drives: 13' Scion FRS Track car
So how do you deal with E85 in the tank when the car sits ? just add some additive to it ? I am planning this for my race car and my car does sit most of the time of course... so what's the best thing to do ? fill it up with regular 93 octane at the end of the track day ? pain in the butt.
philooo is offline   Reply With Quote
Old 06-27-2015, 10:18 PM   #88
steve99
Heaps of guys run E85 full time with no flex kit if your NA, just straight E85 tune. You can get away with a fair bit of variance in your E% NA using ECU standard fueling compensations.
FI different story unless you monitoring and controlling your fuel E%. ie have a guaranteed source of constant E% fuel. you will need a flex kit.
If your fuel is in a sealed container you will be fine, modern fuel tank systems are sealed.
If you letting it sit for months then maybe add some ethanol fuel treatment.
but a few weeks is fine.
i run e85 full time no flex kit
The Following 2 Users Say Thank You to steve99 For This Useful Post:
chaoskaze (08-31-2017), guybo (09-02-2017)
Old 06-30-2015, 05:53 AM   #89
killerkid08
Cool Stuff
killerkid08's Avatar
Drives: Cool Car
Is anyone running a fuel lubricant to prolong the life of the components in the tank? Like redlines alcohol fuel lube or premixing like rotaries ?
killerkid08 is offline   Reply With Quote
Old 08-31-2017, 11:24 AM   #90
Somerandom18
Drives: 2017 manual BRZ
Is the OEM heat range spark plug fine for e85? Would it be better to go one step colder?
Somerandom18 is offline   Reply With Quote
Old 08-31-2017, 09:04 PM   #91
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
the problem is fuel separation. As ethanol and gasoline sit they stratify over time. I don't think a month or 2 would be a problem but longer storage requires fuel treatment or when you go to re-start the car after sitting it'll get a huge gulp of ehtanol or even water (http://fuelschool.blogspot.com/2009/...l-blended.html)
Old 09-01-2017, 07:28 AM   #92
steve99
No ned to change plugs for e85
Somerandom18 (09-01-2017)
Old 12-11-2017, 05:15 AM   #93
Harjotdhanota
Drives: 2017 BRZ Limited
I've heard that it's somewhat necessary to change your oil to an e85 compatible oil. Is this true? Because I'll be tuning my car to run e85 this coming week. My car only has 1,100 miles on it
Harjotdhanota is offline   Reply With Quote
Old 12-11-2017, 03:53 PM   #94
toyubie
Drives: none
E85 will leech and dilute into the oil quicker. You'll need to double the frequency of oil changes. steve99's post has all the information you'll need.
toyubie is offline   Reply With Quote
The Following User Says Thank You to toyubie For This Useful Post:
Harjotdhanota (12-11-2017)
Old 12-11-2017, 04:00 PM   #95
Teseo
Drives: frs
What about fuel filter?
Old 12-11-2017, 04:06 PM   #96
toyubie
Drives: none
IIRC only one track car had an issue with the fuel filter and it was never proven to be caused by running E85. Again, hundreds if not thousands of BRZs/STIs/ WRXs run E85 with no changes to the fuel system (save for FI upgrades).
The Following 2 Users Say Thank You to toyubie For This Useful Post:
Harjotdhanota (12-11-2017), Teseo (12-11-2017)
Is my Cusco catch can correctly installed? wbradley Engine, Exhaust, Transmission 9 02-24-2014 09:49 PM
