Old 05-28-2013, 06:27 PM   #85
tonytduc
tonytduc's Avatar
watching
tonytduc is offline
Old 05-28-2013, 06:30 PM   #86
Splat
Drives: FR-S ultramarine
Originally Posted by FR-S Matt View Post
This is exactly why I didn't jump on putting e85 in a car that wasn't originally intended for it. Good catch though and good knowledge for people that do use e85. Looks like I'll be sticking with good ole' 93 oct.
I doubt the E10 is affecting the filter. There would be a mass recall coming if that is the case.
Work blocks the pictures.
Why would there be a recall, the recommended gas is 93 octane ? They cant recall because somebody put snicker bars in their tank.
Splat is offline
The Following User Says Thank You to Splat For This Useful Post:
mike2100 (06-09-2013)
Old 05-28-2013, 06:31 PM   #87
Visconti
Drives: 05 STi
Originally Posted by Don@Accelerated View Post
So what exactly had you prematurely cutting the filter open. Maybe I missed the initial problem.
For the sake of argument I went and cut my factory filter housing up. I have 4k+ only E85 Miles basically. I have no signs of any degredation to the filter. Now it is true that over time the paper gasket will now allow heavy enough flow for the E85. I haven't run into that scenario yet. It can't be a sitting issue either because mine sat the entire winter here. I wasn't able to put many miles on it.
Have you been/or ever have used an octane booster in the car? Fuel Supplement Additive? It looks crystaline in that picture. E85 is not going to cause that.
I have pictures of my filter and it looks nothing like yours, and doesn't show the slightest sign of any issues yet. My car sat all winter with
Lets discuss further
Just as I expected..
I wasn't surprised for one second when your filter looked like this.
John
Visconti is offline
The Following User Says Thank You to Visconti For This Useful Post:
Carwhisperer (05-28-2013)
Old 05-28-2013, 06:38 PM   #88
Carwhisperer
Drives: A lot of supercars.
The Godzilla Tamer Has Returned!
Carwhisperer is offline
The Following User Says Thank You to Carwhisperer For This Useful Post:
King Tut (05-29-2013)
Old 05-28-2013, 06:41 PM   #89
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
John
Man, I'd lay low till this is figured out if I were you. Flex fuel cars use stainless mesh filters. I *assumed* this car did the same as I'm sure everyone else did. I'm assuming that if anyone had an idea that this car had cellulose filters they would've recommended they be changed before running e85 or it may turn into a negligence issue.
industrial is offline
Old 05-28-2013, 06:42 PM   #90
Subzero
Old...
Subzero's Avatar
Drives: Subaru
Just to throw this out there---did any of Toyotas other designs come with D4s featuring flex fuel usage? Might be worth it to look and check parts cross-compatibility. I Googled for a little bit and didn't find anything.
I use a Magnafuel 7008 with a cleanable element on my E85 scoob. It doesn't look easy to mod and fit in your fuel pickup, though.
Subzero is offline
Old 05-28-2013, 06:43 PM   #91
s2d4
s2d4's Avatar
John
Why not?
s2d4 is offline
Old 05-28-2013, 06:44 PM   #92
dabocx
dabocx's Avatar
Drives: Scion FRS
I for one wonder why manufacturers make things non replaceable to begin with.
dabocx is offline
Old 05-28-2013, 06:45 PM   #93
reeves
psh.. i'm not afraid of blowing my motor on E85. I'll keep running it until I do too.. a few fuzzy pictures from a heavily tracked car isn't enough to scare me. Gott PAY to PLAY!
7K E85 miles & counting....
And thanks @Don@Accelerated for cutting up your filter!
reeves is offline
The Following 5 Users Say Thank You to reeves For This Useful Post:
2forme (05-29-2013), brichard0625 (05-28-2013), Carwhisperer (05-28-2013), Sensisnow (05-28-2013), Visconti (05-28-2013)
Old 05-28-2013, 06:45 PM   #94
Visconti
Drives: 05 STi
Originally Posted by s2d4 View Post
Why not?
Because this isn't my first time to see a cut open filter after E85 use
Nothing to lay low from.
I have several cars running this type of filter with no issues.. my Subaru included !
Not saying there isn't better filters out there
This was looked into back when I first started offering Ethanol Calibrations.
-John
Visconti is offline
The Following 3 Users Say Thank You to Visconti For This Useful Post:
brichard0625 (05-28-2013), JiB (05-28-2013), Sensisnow (05-28-2013)
Old 05-28-2013, 06:45 PM   #95
brichard0625
brichard0625's Avatar
Drives: 2013 Scion Frs(Scarlet)
brichard0625 is offline
The Following 5 Users Say Thank You to brichard0625 For This Useful Post:
2forme (05-29-2013), Calum (05-28-2013), enouf (05-28-2013), Pete (05-28-2013), Visconti (05-28-2013)
Old 05-28-2013, 06:54 PM   #96
JerryMichaels7
Drives: Whiteout FRS
so John and Don why do you think his did that and don's car shows no sign of anything? I am weary now cuz i was about to get the e85 n/a tune next check.
JerryMichaels7 is offline
Old 05-28-2013, 06:55 PM   #97
Carwhisperer
Should be all set!
Just DONT mix any Lucas Fuel Injector Cleaner in that puppy. Your car will HATE you.
Old 05-28-2013, 07:00 PM   #98
brichard0625
didnt take into consideration that robispec tracks his car alot..wondering if that played a key role...still would like a better filter for the e85, just so i can feel better in the future
drama, e85, santa loses it
Bluetooth fix for Android/Samsung users inimitable Electronics | Audio | NAV | Infotainment 27 05-10-2013 06:52 AM
Marginally good use for BeSpoke users! Mandy Electronics | Audio | NAV | Infotainment 12 02-15-2013 09:07 AM
E-85 users thread Crossover Auto Engine, Exhaust, Transmission 41 11-16-2012 07:21 PM
Warning light came on, what could it be? whtchocla7e Issues | Warranty | Recalls / TSB 13 10-21-2012 04:20 PM
Rwd toyota users here? aphxero Other Vehicles & General Automotive Discussions 14 12-23-2009 09:34 PM
