#85 |
Drives: AE86, 2x GT86, TE27
After seeing the RC spec wheels didn't fit this kit, I spent today hunting for an alternative. Figured there would be a few Subaru options, but I like the fact my car is a Toyota, so looked here first. Didn't have to look long..
2001 - 2005 Toyota Celica 16"x6.5" +39 offset. Simple 5 spoke design. 15lbs. Found some at a local wreckers, 4 wheels and 205/50/16 tyres for $180. (For all four!) Went and checked before commiting. Maths seemed right, as the RC wheel is the same size but +48. Put template in wheel, a good 4-5mm clearance from caliper to spoke. About 13mm clearance at the top. Clearances are from template too, which already had some clearance built into it. Will put pics up later. |
| The Following User Says Thank You to diss7 For This Useful Post: | Anthony (10-31-2013) |
#86 | |
Drives: Argento FRS
This looks interesting, although I don't really need a brake upgrade.
ig: @potatoglasses // @toastedbiscuits |
#87 | |
I don't have to care about them getting scratched, because cheap to replace. They will have a smaller circumference, so acceleration will be improved. They're an OEM wheel, so extremely strong. Nothing stopping me getting you model wheel in 16x7, which will weigh much less than a 17x9. Off the top of my head, ssr type c 16x7 weighs 12lbs; I know because there's a set for sale in another city here, I'm just waiting for the seller to get me a shipping cost. |
#88 | |
Drives: Argento FRS
#89 |
Weight Nazi
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Also, even if a set of smaller wheels weighs the same as a larger set, the rim of the smaller wheels is closer to the center of the wheel, so it takes less energy to spin it.
| The Following User Says Thank You to Anthony For This Useful Post: | diss7 (11-02-2013) |
#90 |
Small Update
I installed the new rotors and the Carbotech XP-10 pads. I bled the brakes properly and took it for a spin. The XP-10s seem like the perfect pad for my street use. They don't bite as hard as the Wilwood BP-30s but are quiet and once they bite down, they have a good amount of torque and stop the car pretty quickly. Very happy with them so far. I didn't have an extensive drive, just enough to bed the brakes in and a short cruise.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) ![]() |
#91 |
http://www.wilwood.com/BrakeKits/Bra...%2c+except+STI
Is this the kit that would be recommended for the rear, to suit the front? I realise that up until now we've just been talking about the front replacement kit only, but I'm looking to replace the rears as well because I have the lower spec 86, which came with solid rear discs; but also, I'm all about that reducing unsprung weight. Cheers. |
#92 |
Weight Nazi
How would you determine if this would be compatible with our parking brake? Or are parking brake systems pretty much universal?
#93 | |
And, I'm thinking about this kit... http://pandlmotorsports.com/shop/pl-...ght-brake-kit/ It has disclaimers about heat sink etc, but I imagine that's more aimed towards sti guys; we're a fair bit lighter than they are. |
| The Following User Says Thank You to diss7 For This Useful Post: | industrial (11-03-2013) |
#94 |
Weight Nazi
I don't ever leave cars in gear when I turn them off, it's always neutral with the handbrake pulled. Habits can be changed though.
#95 |
#96 |
Weight Nazi
@diss7, are you going to be buying front and rear brakes soon?
#97 | |
| The Following User Says Thank You to diss7 For This Useful Post: | Anthony (11-03-2013) |
#98 | |
Add lightness!
Drives: 17' WRX
| The Following User Says Thank You to industrial For This Useful Post: | diss7 (11-03-2013) |
| Wilwood Big Brake Kit Installed | msile | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 52 | 03-03-2014 03:00 PM |
| FS: WISC. BNIB Wilwood Front BBK | Scooby South | Brakes, Suspension, Chassis | 4 | 03-10-2013 04:22 PM |
| Wilwood BBK | Slartibartfast | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 59 | 01-08-2013 10:12 PM |
| help on Wilwood brakes brackets | Turbo Den | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 10-01-2012 09:14 PM |
