Old 10-30-2013, 10:49 PM   #85
diss7
Drives: AE86, 2x GT86, TE27
After seeing the RC spec wheels didn't fit this kit, I spent today hunting for an alternative. Figured there would be a few Subaru options, but I like the fact my car is a Toyota, so looked here first. Didn't have to look long..
2001 - 2005 Toyota Celica 16"x6.5" +39 offset. Simple 5 spoke design. 15lbs. Found some at a local wreckers, 4 wheels and 205/50/16 tyres for $180. (For all four!)
Went and checked before commiting. Maths seemed right, as the RC wheel is the same size but +48.
Put template in wheel, a good 4-5mm clearance from caliper to spoke. About 13mm clearance at the top.
Clearances are from template too, which already had some clearance built into it.
Will put pics up later.
diss7 is offline   Reply With Quote
The Following User Says Thank You to diss7 For This Useful Post:
Anthony (10-31-2013)
Old 11-01-2013, 03:58 PM   #86
moomoopanda
moomoopanda's Avatar
Drives: Argento FRS
What's the point of a smaller wheel if it weighs the same as my 17x9 TC105?
This looks interesting, although I don't really need a brake upgrade.
moomoopanda is offline   Reply With Quote
Old 11-01-2013, 05:16 PM   #87
diss7
They were extremely cheap, $180 for 4, with tyre.
I don't have to care about them getting scratched, because cheap to replace.
They will have a smaller circumference, so acceleration will be improved.
They're an OEM wheel, so extremely strong.
Nothing stopping me getting you model wheel in 16x7, which will weigh much less than a 17x9. Off the top of my head, ssr type c 16x7 weighs 12lbs; I know because there's a set for sale in another city here, I'm just waiting for the seller to get me a shipping cost.
Old 11-01-2013, 06:23 PM   #88
moomoopanda
Drives: Argento FRS
Strong points. Carry on. haha.
Old 11-02-2013, 12:06 AM   #89
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Also, even if a set of smaller wheels weighs the same as a larger set, the rim of the smaller wheels is closer to the center of the wheel, so it takes less energy to spin it.
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
The Following User Says Thank You to Anthony For This Useful Post:
diss7 (11-02-2013)
Old 11-02-2013, 10:14 AM   #90
swift996
swift996's Avatar
Small Update
I installed the new rotors and the Carbotech XP-10 pads. I bled the brakes properly and took it for a spin. The XP-10s seem like the perfect pad for my street use. They don't bite as hard as the Wilwood BP-30s but are quiet and once they bite down, they have a good amount of torque and stop the car pretty quickly. Very happy with them so far. I didn't have an extensive drive, just enough to bed the brakes in and a short cruise.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
The Following 4 Users Say Thank You to swift996 For This Useful Post:
Anthony (11-03-2013), CSG David (11-02-2013), DAEMANO (11-25-2014), diss7 (11-03-2013)
Old 11-03-2013, 01:51 AM   #91
diss7
http://www.wilwood.com/BrakeKits/Bra...%2c+except+STI
Is this the kit that would be recommended for the rear, to suit the front? I realise that up until now we've just been talking about the front replacement kit only, but I'm looking to replace the rears as well because I have the lower spec 86, which came with solid rear discs; but also, I'm all about that reducing unsprung weight.
Cheers.
Old 11-03-2013, 02:15 AM   #92
Anthony
Weight Nazi
Anthony's Avatar
How would you determine if this would be compatible with our parking brake? Or are parking brake systems pretty much universal?
Old 11-03-2013, 02:32 AM   #93
diss7
That's the part I'm stuck in too aye. Although now I'm sitting here questioning whether I could live without the handbrake - I think I could because it would save a shit ton of weight.
And, I'm thinking about this kit...
http://pandlmotorsports.com/shop/pl-...ght-brake-kit/
It has disclaimers about heat sink etc, but I imagine that's more aimed towards sti guys; we're a fair bit lighter than they are.
industrial (11-03-2013)
Old 11-03-2013, 03:02 AM   #94
Anthony
Weight Nazi
Anthony's Avatar
I don't ever leave cars in gear when I turn them off, it's always neutral with the handbrake pulled. Habits can be changed though.
Old 11-03-2013, 03:43 AM   #95
diss7
Especially because it's rotational weight on the driveline, so dat response.
Old 11-03-2013, 04:19 AM   #96
Anthony
Weight Nazi
Anthony's Avatar
@diss7, are you going to be buying front and rear brakes soon?
Old 11-03-2013, 04:24 AM   #97
diss7
As soon as I'm comfortable with my choices.
Old 11-03-2013, 05:18 AM   #98
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Doesn't robispec run a similar setup from the brakeman in the rear? Nice find btw. I think I'm going this way for the rear and I'm still a little torn about the front. Probably end up with the wilwood lightweight set too.
industrial is offline   Reply With Quote
The Following User Says Thank You to industrial For This Useful Post:
diss7 (11-03-2013)
Wilwood Big Brake Kit Installed msile Suspension | Chassis | Brakes -- Sponsored by 949 Racing 52 03-03-2014 03:00 PM
FS: WISC. BNIB Wilwood Front BBK Scooby South Brakes, Suspension, Chassis 4 03-10-2013 04:22 PM
Wilwood BBK Slartibartfast Suspension | Chassis | Brakes -- Sponsored by 949 Racing 59 01-08-2013 10:12 PM
help on Wilwood brakes brackets Turbo Den Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 10-01-2012 09:14 PM
