#85 | |
I Love custom Turbo kits
Drives: Limited BRZ
At this point I will just assume that no, there is nothing in your training with which to conclude 5w30 is too thick. Last edited by Sportsguy83; 02-27-2013 at 01:19 AM. |
#86 |
Drives: Attitude
This thread is about pcasso's engine, not 20valve's training (or lack thereof depending on the poster). Let's keep it that way folks.
| The Following 3 Users Say Thank You to OrbitalEllipses For This Useful Post: |
#87 | |
Drives: 2013 FRS/01 Tacoma
"Which is fine I'm not knocking anyone choice of oil and I never told anyone which oil to use I just stated my choice. Also training doesn't tell use what oil to use that's up to the customer to decide. When I was referring to training I was backing up my statement of the crank pulley not effecting the check engine light and that it was most likely the VVTI gear. I was also stating that because I know some people were wondering where the crank position sensor was and I said it was on the back on the flywheel side" |
#88 |
Drives: Black frs project
everybody LET IT GO...lol enough already.
| The Following 5 Users Say Thank You to robispec For This Useful Post: | 20valvewynn83 (02-27-2013), Sportsguy83 (02-27-2013), suaveflooder (04-05-2013), SubieNate (03-01-2013), Touge Monster (03-05-2013) |
#89 | |||||
Reverse Burnouts
Drives: 2013 Argento FRS
![]() dont have to worry about cold start my garage stays at a nice 55 degrees F at its coldest yes Quote:
the current STI engine can handle about 450whp on the stock block where ours (with higher compression and lower volume can make at least 520 whp without blowing up )open deck design helps cooling a LOT Quote:
ie. i got a vacuum leak on my other car saying the gas cap wasn't sealing, it ended up being a charcoal canister being clogged up.... i bet one of the plugs fouled, as someone stated before, and it isn't firing at full strength because or contamination of a plug, a oil catch can helps with this but doesn't prevent it ohh yeah... and... BE QUIET FFS... damn.. Quote:
![]() 2000 Carbon Blue Toyota Celica GTS 152000 miles (wont forget you) 2013 Argento Scion FR-S 2011 Infiniti G37x Last edited by carbonBLUE; 02-27-2013 at 02:42 AM. |
| The Following 2 Users Say Thank You to carbonBLUE For This Useful Post: | Gords_zenith (03-02-2013), Sportsguy83 (02-27-2013) |
#90 |
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
Wow.. Love all the Internet auto techs on here.. Hope the OP gets his car fixed properly, As a ASE tech I know better then throwing out diagnostic ideas based on a short video and a couple codes, like carbon said one code could be caused by a numbers or different problems,
Funny thing, my only track day, after one of my sessions, pulling into the "pits" my engine was sounding like a heavy misfire, had that boxer rumble and all.. Was barely idling, no codes or CEL, after shutting it off and letting it cool, starting up for my next session 40 mins later or so it was hard to start, but once I'd did,it ran fine.. Just every once in awhile it will give that really rough idle.. Luckly my car has not presented any of the problems I have read on here, idle dip or anything.. But maybe four times in the 12k miles I've owned her. She seems to get a little pissy Please OP, keep us up to date |
#91 | |
Drives: Attitude
#92 | |
Reverse Burnouts
or what's the chance that a first year motor had no problem accepting THAT amount of boost, open deck is great for cooling, but at the same time it is a toss up for wall rigitity. any impurities in the metal could cause the entire cylinder to skew in any direction when under THAT much pressure and heat the only thing holding the cylinder straight is the head and open deck boxer motors are more susceptible for lifting at the heads when under a lot of boost but if you can pull 540whp at 8.5k rpms... im going to go and say i trust it for at least 400 here's some good examples FA20 OPEN DECK ![]() EJ20 OPEN DECK (not as open) but more rigid ![]() and for fun EJ25 ![]() I STILL SAY A PLUG IS FOULED!!!!
![]() 2000 Carbon Blue Toyota Celica GTS 152000 miles (wont forget you) 2013 Argento Scion FR-S 2011 Infiniti G37x |
#93 | |
Drives: 2013 raven black fr-s
The first problem with that last pic is that they are trusting a fram filter haha |
#94 |
Drives: SSM LT MT BRZ
its clear that engine failed because they used hose clamps that were not factory specified,
#95 |
Drives: fr-s and tc2
any updates?
#96 |
Drives: 2013 Scion FR-S, 1993 Lexus SC300
Just skimming through the thread...Those images scared me a bit! I wasn't really reading closely and thought they were pcasso87's motor.
#97 |
Track Junkie
Drives: Faster than the Stig!
Ok guys well according to a toyota tech one of my pistons has a huge hole, my ecu could also be faulty which could have caused the engine to fail. I will have more information today or tomorrow. This is extremely weird, i really cant explain it my self. Hopefully the tech will diagnose it better so we can have a better idea as to what failed.
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
| The Following User Says Thank You to track_warrior For This Useful Post: | Surok (02-28-2013) |
#98 | |
Drives: '15 STi Ltd
![]() Probably your super thick oil mixing with the wrong gas... /Amiright //I'llshowmyselfout |
| Scion/Toyota broke 3rd brake light applying tint | Lefty | Cosmetic Modification (Interior/Exterior/Lighting) | 32 | 10-31-2019 07:23 PM |
| How to wash your car in an hour or less, make it look like a pro, and not go broke... | seven | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 141 | 01-30-2015 12:32 PM |
