Old 02-17-2014, 03:35 PM   #85
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by rb6freak View Post
So, did you ever try this pin 10 for Ill? I'm in the middle of connecting my gauge and I'm looking to connect this last wire.
And FYI to others - D48 grey wire is Pin 12, not 17.
My Failsafe is connected to the ILL cable and it dims.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
rb6freak (02-17-2014)
Old 02-17-2014, 03:37 PM   #86
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
Great news, here I go :-)
rb6freak is offline   Reply With Quote
Old 02-17-2014, 03:43 PM   #87
Sportsguy83
Drives: Limited BRZ
Take note to see if your gauge requires + to dim or ground.
If +, go to the ILL+ cable and ground, go to the ILL- cable.
If its the Failsafe don't worry, it can be configured for either/or.
Old 02-17-2014, 03:54 PM   #88
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
I have the same part number as you, 30-4900. The instructions are not clear, but if you say it works in either, then I will just do pin 10 as mentioned. Thanks again.
The Following User Says Thank You to rb6freak For This Useful Post:
Sportsguy83 (02-17-2014)
Old 02-17-2014, 04:00 PM   #89
Sportsguy83
Drives: Limited BRZ
Yea with the Failsafe don't worry. connect it to pin 10. If when you try it the results are opposite (Dims on light OFF and bright on lights ON), then just connect it to the computer and configure it. Best gauge BTW.
Old 02-25-2014, 03:11 AM   #90
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
Showing some snap shots of my install and a brightness demonstration.
For the dimming feature - I tapped into the stereo harness. Purple wire with silver stripes on bottom right of photo (pin 10 of 10). It worked first try.
[ame]http://youtu.be/O1vnNh4W0bs[/ame]
The Following 2 Users Say Thank You to rb6freak For This Useful Post:
post_break (04-23-2014), Sportsguy83 (02-25-2014)
Old 04-25-2014, 12:04 PM   #91
mrfish
I just wired my failsafe gauge in last night. Here's what worked for me:
Illumination - connected to the violet (purple) wire coming off the dimmer switch on the dash. Works fine.
Tach signal - my car didn't have the "certified ECU box" described earlier in this thread. My car is a BRZ premium trim (no push button start, etc), and I think this is the commonality with the other member who didn't have this additional ECU box as well. I found the set of 4 pink wires (injectors) coming off the main ECU and tapped into the the one that was easiest to reach. Everything works fine. I had to set the pulses/rev in the SW to 1/2.
mrfish is offline   Reply With Quote
The Following User Says Thank You to mrfish For This Useful Post:
xkalelx (10-26-2015)
Old 05-08-2014, 03:04 PM   #92
FyeaFRS
Drives: 1992 Nissan Skyline GTS-t Type-M
Okay, so...running two gauges: AEM wideband A/F and Auto Meter Vacuum/Boost. AEM needs 12v for power and the Auto Meter just needs it for the backlight. Looking for a simple splice location that I can use quick tap connectors or the like.
Gauge pod is a custom vent pod that uses the driver's side angled dash vent. all wires running down behind where dimmer/trunk release button is.
So any tips for some quick 12v to power these?
FyeaFRS is offline   Reply With Quote
Old 09-19-2014, 06:39 AM   #93
xbb1024
Drives: Toyota 86 GTS
Hi guys, I'm installing my own buttons. Does anyone know what the luminosity of the OEM button backlight LEDs are? I want to match the same intensity.
Edit: 1500 mcd to match the power window buttons, probably 2100 mcd for the dash buttons (although couldn't get the dimmer thing to work)
xbb1024 is offline   Reply With Quote
Old 09-20-2014, 12:06 PM   #94
xbb1024
Followup question, does anyone know if the B-W PWM wire is inverted (like longer pulses if i turn the dial dimmer)? or is it fine to splice into to power my LEDs?
Edit: nope, doesn't work. Seems to be inverted (when full brightness, shorter pulses, but can't confirm because I have a cheaper multimeter). Spliced the purple wire instead.
Old 10-03-2014, 12:27 AM   #95
simpleisbest
Senior Citizen
Drives: Scion FR-S
Originally Posted by Lonely Sushi View Post
Well!
Got my tach signal... its strange that my car doesnt have the certified ECU assembly on there, I see the mounting you are talking about but there was nothing on it. do you guys have the "Smart Entry & Start System" ? I re-checked the wiring diagram and it might be that my FRS doesnt have it so it didnt come with that assembly (just a guess)?
anyways, initially when I found the A35 pin 15 connector to be an empty pin with no wires coming out of it, I didnt want to just hook it up and see if it works without checking it. So today I finally pulled out my oscilloscope and checked that pin to find a nice clean signal coming out of it. Found some pins laying around and hooked that wire up to my IQ3 and there we have it! tach signal
Great information!! I am also looking to pull tach signal from A35-15 for a shifter buzzer. Can you please confirm what size pin is needed? I will need to see what I can find to get the job done without damaging anything
simpleisbest is offline   Reply With Quote
Old 11-16-2014, 03:20 PM   #96
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
I'd like to zombie this thread for some help as I'm stumpt.
I'm trying to get my Tanabe oled gauges to dim.
Here is the wiring off the gauges.
Red- Constant Power (Fused) +12v
White- Ignition Switch (Accessory) +12v
Black- Ground (-)
Oragne- Illumination +12v
I have the gauges all wired up except for the orange illumination wire and the gauges are running FULL Brightness. I've tried tapping into the radio dimmer (purple wire/pin10 on the 10-pin connector) wire and when I connect the gauges they dim ever so slightly, however there is no change if I toggle the headlights or interior dimming.
Do I have the wrong wire?
Thanks
Old 11-25-2014, 07:56 AM   #97
chewbacca
Drives: Frs-t
FRS ecu wires
Originally Posted by ecko04 View Post
I can't be any more explicit than this
hello,
Nice of you to help with the ecu visuals. This helped me find the starting line to get the apexi avcr installed; however, im not sure which wire to tap for the speed, throttle, 2xground, power/ignition. Can these be shown?
thank you much
chewbacca is offline   Reply With Quote
Old 07-03-2015, 03:17 PM   #98
hirollaz
Drives: 2013 Scion FRS 10 Series
So if I were installing a Autometer Tach or External Shift light I would tap into the Pink wire correct?
hirollaz is offline   Reply With Quote
dash, gauge, gaugle cluster, pod
What is that blinking dash light when the car is off? JayNutter Scion FR-S / Toyota 86 GT86 General Forum 7 02-03-2014 10:59 AM
WTB: FRS instrument cluster jabbajaw99 Interior Parts (Incl. Lighting) 3 02-14-2013 01:31 PM
surprised at how much MORE i like the frs dash cluster pr086 Scion FR-S / Toyota 86 GT86 General Forum 26 12-07-2012 09:09 PM
Flashing Security Light in Dash? ravenMTgirl Electronics | Audio | NAV | Infotainment 8 11-21-2012 03:25 PM
Scratches on my Cluster. Superhatch BRZ First-Gen (2012+) — General Topics 5 08-21-2012 07:50 AM
