#85 |
#86 |
Drives: Raven FR-S
jesus how do you track your car so low? how is your suspension set up? kwv3s with swapped springs and gc top hats? what else is going on with your suspension?
#87 |
Robi has custom mounts for both the front and rear that allows for the same shock travel as a stock height car, and they are all available for sale through him. Contact @robispec directly for more info.
We run really high spring rates which reduces the amount of compression travel needed. Two different solutions to the same problem, although Robi's is far more elegant. Need more low?
#88 |
Drives: Black frs project
Robispec
front lower control arms (roll center,anti-dive,castor,camber,track adjustable. Rear extended travel rear top hats Whiteline camber correction rear bushings ROBI's "spec" works REALLY well...lol ask anyone who has ridden driven the car..does not feel like a stock or even modified frs/brz/gt-86 |
#89 |
My LFA
Drives: No Boost
car looks great man, saw you at WSIR this weekend and saw you driving from what i was assuming chuckwalla sunday, you were going the opposite way as me on the freeway before Cathedral City (was in the wifes car), im deffinitely looking forward to getting your Radiator/Oil cooler set up once i get the mulah to grab it, also how did you do the hood vents like you did? i am deffinitely interested in something similar.
WSIR 1:46.023 (Need Better Tires)
My Car Build: 171.9WHP/137WTQ (Mustang Dyno) http://www.ft86club.com/forums/showthread.php?t=21824 My For Sale Aftermarket and OEM parts http://www.ft86club.com/forums/showt...484#post998484 |
#90 |
Dismember
Drives: 2013 Red Scion FR-S
Your tires are listed as fitting on up to a 8.5" wheel and working best on a 7.5. Is there a reason for the stretch onto a 9" rim?
#91 |
The wider a rim is for a given tire width the better control you have the tread area. You pay a weight penalty but if you have a lot of High G cornering it makes up for it easily.
#92 |
NEW products TESTED TOUGH
STREET no sheetmetal triming Adds 2" rear travel ![]() RACE requires rear sheetmetal trimming Adds 3" rear travel Last edited by robispec; Yesterday at 10:50 PM. Last edited by robispec; 04-30-2013 at 02:49 PM. |
#93 |
My FR-S has 5 gears
Drives: FRS/280z/Tundra
Img no work?
Omar GC
2JZ - 6870 - stock block - 1000whp? Instagram: 2jzus |
#94 |
#95 |
#96 |
robispec, do you have a picture of these installed?
#97 |
Drives: Legacy GT
Hey those are pretty fancy! How does the upper spring perch work with those?
#98 | |
Spring perch Machined in the end is for or 60 mm spring. A plastic spring isolator can also be installed for different different spring diameters. |
| Canu_50's FR-S Time Attack, drift car!! | canu_50 | Member's Car Journals | 28 | 12-05-2013 02:04 AM |
| My FR-S In Time Attack Mode!! | track_warrior | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 12 | 09-25-2012 02:13 AM |
| Ontario Time Attack - TMP July 7th | 7thgear | CANADA | 8 | 07-07-2012 06:14 PM |
| Vancouver auto-cross, time attack.. ? | EsoBOFH | CANADA | 4 | 06-20-2012 03:23 PM |
| Tsukuba time attack review in the Car Top magazine | yajin | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 5 | 05-18-2012 05:12 PM |
