Old 04-02-2013, 12:26 PM   #85
CSG Mike
CSG Mike's Avatar
Originally Posted by robispec View Post
yes but I dont know how to get them posted....I'm a chassis guy not your AV service tech...lol
Get me copies and I'll handle that for ya.
Old 04-22-2013, 06:59 PM   #86
YDNA
YDNA's Avatar
Drives: Raven FR-S
jesus how do you track your car so low? how is your suspension set up? kwv3s with swapped springs and gc top hats? what else is going on with your suspension?
YDNA is offline   Reply With Quote
Old 04-22-2013, 07:11 PM   #87
CSG Mike
CSG Mike's Avatar
Robi has custom mounts for both the front and rear that allows for the same shock travel as a stock height car, and they are all available for sale through him. Contact @robispec directly for more info.
We run really high spring rates which reduces the amount of compression travel needed. Two different solutions to the same problem, although Robi's is far more elegant.
Need more low?
Old 04-22-2013, 07:15 PM   #88
robispec
Drives: Black frs project
Robispec
front lower control arms (roll center,anti-dive,castor,camber,track adjustable.
Rear extended travel rear top hats
Whiteline camber correction rear bushings
ROBI's "spec" works REALLY well...lol
ask anyone who has ridden driven the car..does not feel like a stock or even modified frs/brz/gt-86
robispec is offline   Reply With Quote
Old 04-22-2013, 09:53 PM   #89
evilconcarne999
My LFA
evilconcarne999's Avatar
Drives: No Boost
car looks great man, saw you at WSIR this weekend and saw you driving from what i was assuming chuckwalla sunday, you were going the opposite way as me on the freeway before Cathedral City (was in the wifes car), im deffinitely looking forward to getting your Radiator/Oil cooler set up once i get the mulah to grab it, also how did you do the hood vents like you did? i am deffinitely interested in something similar.
WSIR 1:46.023 (Need Better Tires)
My Car Build: 171.9WHP/137WTQ (Mustang Dyno)
http://www.ft86club.com/forums/showthread.php?t=21824
My For Sale Aftermarket and OEM parts
http://www.ft86club.com/forums/showt...484#post998484
evilconcarne999 is offline   Reply With Quote
Old 04-25-2013, 11:52 PM   #90
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Your tires are listed as fitting on up to a 8.5" wheel and working best on a 7.5. Is there a reason for the stretch onto a 9" rim?
Old 04-26-2013, 12:18 AM   #91
robispec
The wider a rim is for a given tire width the better control you have the tread area. You pay a weight penalty but if you have a lot of High G cornering it makes up for it easily.
Old 04-28-2013, 11:57 PM   #92
robispec
NEW products TESTED TOUGH
STREET no sheetmetal triming
Adds 2" rear travel
RACE requires rear sheetmetal trimming
Adds 3" rear travel
Old 04-30-2013, 02:14 PM   #93
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Img no work?
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 04-30-2013, 02:47 PM   #94
DriftEm
DriftEm's Avatar
Originally Posted by OmarGC View Post
Img no work?
pictures are on the first page
DriftEm is offline   Reply With Quote
Old 04-30-2013, 02:49 PM   #95
robispec
Img no work?
fixed
Robi
Old 04-30-2013, 03:41 PM   #96
DriftEm
DriftEm's Avatar
robispec, do you have a picture of these installed?
Old 04-30-2013, 03:56 PM   #97
jamal
jamal's Avatar
Drives: Legacy GT
Hey those are pretty fancy! How does the upper spring perch work with those?
jamal is offline   Reply With Quote
Old 04-30-2013, 07:27 PM   #98
robispec
Spring perch is directly incorporated in the solution.
Spring perch Machined in the end is for or 60 mm spring.
A plastic spring isolator can also be installed for different different spring diameters.
Canu_50's FR-S Time Attack, drift car!! canu_50 Member's Car Journals 28 12-05-2013 02:04 AM
My FR-S In Time Attack Mode!! track_warrior FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 12 09-25-2012 02:13 AM
Ontario Time Attack - TMP July 7th 7thgear CANADA 8 07-07-2012 06:14 PM
Vancouver auto-cross, time attack.. ? EsoBOFH CANADA 4 06-20-2012 03:23 PM
Tsukuba time attack review in the Car Top magazine yajin FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 5 05-18-2012 05:12 PM
