#85 |
Drives: Yes
So I should mention that when I installed my Fumoto about 2000 miles ago, I was a bad boy and used a socket on the Hex head instead of a crescent wrench to torque down the valve, despite explicit directions not to.
At first, the Hex head turned with the whole valve, so I though I was good, but once it was torqued down pretty tight, I managed to turn the Hex head a fraction of a degree before realizing it was turning without the valve. I panicked because I thought I had broken something and, according to the Fumoto engineer that I spoke to on the phone, I did. ![]() Notice the threads on the right side fitting, where the nipple would be. Apparently, it is a separate piece that is tightened down to compress the white seals around the ball valve and then held in place with Loctite on the threads. If you torque the Hex head too much, you will likely break the Loctite, like I did. The Fumoto engineer made it sound like I had completely destroyed the valve, but by my logic, as long as I leave it as is and don't turn the Hex head in either direction any more, the seal should hold. So far, no oil leaks, and I'll see if the lever still turns smoothly during the next oil change. Has anyone else made this boo-boo?
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
#86 |
I havent, but I got the "s" version with a small stub nipple and don't remember seeing anything to put a hex wrench into... I can certainly see why it would be an issue, though. I would also assume if it doesn't leak and still works OK, you're probably fine unless however, my paranoia manifests itself and the white ring cracks when you're on a long drive and your oil slowly drains out and your engine siezes leaving you stranded in rapecountry. I'm too OCD, just knowing I might have damaged it would be enough incentive to replace it at the next oil change. Another $25 is cheap insurance.
If the white ring just compresses, and the engineer is paranoid about the mushed loctite, then I'd be more inclined to say fugeddaboutit. You could always disassemble it, clean and inspect it, and reassemble with new loctite, but it might be impossible to torque it properly to know the seal is loaded correctly. Eh, now I'm back to $25 is cheap insurance... |
#87 |
SLO NO MO
Yep, I warned folks about it in an earlier post in this thread.
Mine was tight enough that the ball lever no longer moved. http://www.ft86club.com/forums/showthread.php?p=904491 Sent from my Nexus 5 using Tapatalk |
#88 | |
1. You have cracked the valve seat(s). 2. You have cracked the ball inside the valve. 3. You have elongated the threads, ruining any chances of getting the valve back together. If it's not leaking and it still turns, though, I'd just leave it as is. If/when it starts to leak, replace with a new one and follow the installation instructions. |
#89 |
Drives: CBS Subaru BRZ Limited
I don't have a torque wrench so is there anyway to estimate how much the 18lbs of torque is? I don't want to ruin the valve.
#90 |
Just a dude
Drives: Scion FR-S 2013
Tight is tight use best judgement and don't go gorilla on it.
That's all I did mine hasn't moved a hair since install months ago.
#91 |
Honeydew old ID
Drives: GT86
i had my on since 3 months ago..no problem..don't put too much force on it while installing.
Used to owned M3 and Lotus, but love my GT86 the most.
#92 | |
I don't have crowfeet attachments for my torque wrench, but I also don't remember being able to fit a socket over the whole thing, so I think I just tightened it by hand as well. You'll feel it tighten up, just don't he-man hulk on it. |
#93 |
Drives: Neptune GR86
I used a crescent wrench on mine.
Obviously not very accurate. Just used my judgment to get it fairly snug but not ridiculously tight. Haven't had an issue yet.
#94 |
Drives: tezla
isnt it just about a little more than hand tight good?
i didnt use a torque wrench and just hand tightened and its been fine for about 6 months |
#95 |
Yes and no, "hand tight" is different to everyone, the key is to be sensitive to how it actually feels when you're turning the fastener. It's a nuanced sensation, it's not as simple as just snugging it up, there's different feels and resistances as it gets tighter, and you kinda have to feel when it's about right. Dem feels...
#96 | |
Drives: tezla
#97 |
Thanks
Just did a track day on mine and it almost 2 years old, no problem so far
#98 | |
| Installed Perrin shifter bushing & Fumoto oil drain valve | zooki | Engine, Exhaust, Transmission | 23 | 03-31-2013 05:18 PM |
| FS: Fumoto quick valve | Laika | Engine, Exhaust, Bolt-Ons | 1 | 01-08-2013 01:51 PM |
| Quick Question??? | soontobrz | BRZ First-Gen (2012+) — General Topics | 12 | 12-16-2012 11:02 AM |
| Quick question.... | be6sti | Engine, Exhaust, Transmission | 8 | 11-04-2012 09:53 PM |
| quick question about the height.. | VenomRush | Scion FR-S / Toyota 86 GT86 General Forum | 13 | 12-22-2009 10:42 PM |
