Old 05-28-2014, 03:59 PM   #85
chas3wba0
chas3wba0's Avatar
Drives: Yes
So I should mention that when I installed my Fumoto about 2000 miles ago, I was a bad boy and used a socket on the Hex head instead of a crescent wrench to torque down the valve, despite explicit directions not to.
At first, the Hex head turned with the whole valve, so I though I was good, but once it was torqued down pretty tight, I managed to turn the Hex head a fraction of a degree before realizing it was turning without the valve. I panicked because I thought I had broken something and, according to the Fumoto engineer that I spoke to on the phone, I did.
Notice the threads on the right side fitting, where the nipple would be. Apparently, it is a separate piece that is tightened down to compress the white seals around the ball valve and then held in place with Loctite on the threads. If you torque the Hex head too much, you will likely break the Loctite, like I did.
The Fumoto engineer made it sound like I had completely destroyed the valve, but by my logic, as long as I leave it as is and don't turn the Hex head in either direction any more, the seal should hold. So far, no oil leaks, and I'll see if the lever still turns smoothly during the next oil change.
Has anyone else made this boo-boo?
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
The Following User Says Thank You to chas3wba0 For This Useful Post:
gkubed (02-04-2019)
Old 05-28-2014, 10:32 PM   #86
wheelhaus
wheelhaus's Avatar
I havent, but I got the "s" version with a small stub nipple and don't remember seeing anything to put a hex wrench into... I can certainly see why it would be an issue, though. I would also assume if it doesn't leak and still works OK, you're probably fine unless however, my paranoia manifests itself and the white ring cracks when you're on a long drive and your oil slowly drains out and your engine siezes leaving you stranded in rapecountry. I'm too OCD, just knowing I might have damaged it would be enough incentive to replace it at the next oil change. Another $25 is cheap insurance.
If the white ring just compresses, and the engineer is paranoid about the mushed loctite, then I'd be more inclined to say fugeddaboutit. You could always disassemble it, clean and inspect it, and reassemble with new loctite, but it might be impossible to torque it properly to know the seal is loaded correctly. Eh, now I'm back to $25 is cheap insurance...
Old 05-29-2014, 11:34 AM   #87
Foobar
SLO NO MO
Foobar's Avatar
Yep, I warned folks about it in an earlier post in this thread.
Mine was tight enough that the ball lever no longer moved.
http://www.ft86club.com/forums/showthread.php?p=904491
The Following User Says Thank You to Foobar For This Useful Post:
chas3wba0 (06-23-2014)
Old 05-29-2014, 01:00 PM   #88
sshole
The only things I could think of that would happen from tightening that part:
1. You have cracked the valve seat(s).
2. You have cracked the ball inside the valve.
3. You have elongated the threads, ruining any chances of getting the valve back together.
If it's not leaking and it still turns, though, I'd just leave it as is. If/when it starts to leak, replace with a new one and follow the installation instructions.
sshole is offline   Reply With Quote
Old 05-30-2014, 04:58 PM   #89
uEih
Drives: CBS Subaru BRZ Limited
I don't have a torque wrench so is there anyway to estimate how much the 18lbs of torque is? I don't want to ruin the valve.
uEih is offline   Reply With Quote
Old 05-30-2014, 05:25 PM   #90
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Tight is tight use best judgement and don't go gorilla on it.
That's all I did mine hasn't moved a hair since install months ago.
Old 05-30-2014, 06:40 PM   #91
skyloran
Honeydew old ID
skyloran's Avatar
Drives: GT86
i had my on since 3 months ago..no problem..don't put too much force on it while installing.
Used to owned M3 and Lotus, but love my GT86 the most.
skyloran is offline   Reply With Quote
Old 05-30-2014, 07:34 PM   #92
wheelhaus
wheelhaus's Avatar
18 lb ft of torque is literally 18 lbs of force, one foot away from the center. I know that might not answer your question, but might help you interpret how it's measured.
I don't have crowfeet attachments for my torque wrench, but I also don't remember being able to fit a socket over the whole thing, so I think I just tightened it by hand as well. You'll feel it tighten up, just don't he-man hulk on it.
The Following User Says Thank You to wheelhaus For This Useful Post:
uEih (06-04-2014)
Old 05-30-2014, 09:35 PM   #93
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
I used a crescent wrench on mine.
Obviously not very accurate. Just used my judgment to get it fairly snug but not ridiculously tight.
Haven't had an issue yet.
Old 06-03-2014, 02:28 PM   #94
frs10
Drives: tezla
isnt it just about a little more than hand tight good?
i didnt use a torque wrench and just hand tightened and its been fine for about 6 months
frs10 is offline   Reply With Quote
Old 06-03-2014, 02:36 PM   #95
wheelhaus
wheelhaus's Avatar
I didnt use a torque wrench and just hand tightened and its been fine for about 6 months
Yes and no, "hand tight" is different to everyone, the key is to be sensitive to how it actually feels when you're turning the fastener. It's a nuanced sensation, it's not as simple as just snugging it up, there's different feels and resistances as it gets tighter, and you kinda have to feel when it's about right. Dem feels...
Old 06-03-2014, 02:40 PM   #96
frs10
Drives: tezla
subjective... fml
Old 06-03-2014, 02:44 PM   #97
ZionsWrath
Thanks
ZionsWrath's Avatar
Just did a track day on mine and it almost 2 years old, no problem so far
Old 06-04-2014, 02:46 AM   #98
uEih
Did you go past the tighten point or as soon as there were some resistance you went past that a bit? Most likely I'll do it past when it's tight a bit and if there are leaks i'll tighten it more. But at least knowing that I could tighten it by hand makes it easier to tell how much force is too much.
Installed Perrin shifter bushing & Fumoto oil drain valve zooki Engine, Exhaust, Transmission 23 03-31-2013 05:18 PM
FS: Fumoto quick valve Laika Engine, Exhaust, Bolt-Ons 1 01-08-2013 01:51 PM
Quick Question??? soontobrz BRZ First-Gen (2012+) — General Topics 12 12-16-2012 11:02 AM
Quick question.... be6sti Engine, Exhaust, Transmission 8 11-04-2012 09:53 PM
quick question about the height.. VenomRush Scion FR-S / Toyota 86 GT86 General Forum 13 12-22-2009 10:42 PM
