Old 12-22-2012, 11:20 PM   #85
ShoNUFF
Who's the BADDEST?
ShoNUFF's Avatar
Drives: 2013 BRZ Limited - Crystal Black
Installed my push button start today. Fast reliable order from japan parts!
Thanks guys for the tips on the install!!! It was really easy.
ShoNUFF is offline   Reply With Quote
The Following User Says Thank You to ShoNUFF For This Useful Post:
tripjammer (01-24-2013)
Old 01-15-2013, 08:17 PM   #86
tripjammer
tripjammer's Avatar
Drives: WRB BRZ limited 6MT
U know I am gonna have to install this when I get my BRZ...
tripjammer is offline   Reply With Quote
Old 01-16-2013, 11:35 AM   #87
Beyer Subaru
Drives: 2013 BRZ SWP 6AT Ltd
Yerp. The cost of admission is totally worth the miles of smiles to follow.
Beyer Subaru is offline   Reply With Quote
The Following User Says Thank You to Beyer Subaru For This Useful Post:
Old 02-02-2013, 04:27 PM   #88
tripjammer
tripjammer's Avatar
I popped the passenger side center stack lower cover (below the knee pad) off. Then I reached in from behind and popped the USB connector out (push forward). The next step is to unplug the connection and push the wiring back through the exposed hole. After that reach into the now vacant USB hole with your pointer finger and pull gently. It may require some tugging a bit, but it will eventually pop out.
On another note, I worked a little more on this last night. I also confirmed via the STI part number on my switch that my switch is in fact the one for Impreza models. Japan parts sells the BRZ button, but you have to be sure to select the ZC6 before adding it to your card to have the right one.
Because I get mine elsewhere, I had to be a little creative to get mine to work. Eventually, I just decided to sauter some jumper to the pins on the button and connect them to the female connector. It works and looks great!
I am a little concerned that I cannot get the red LED illumination to go off when the car is shut off. I plugged my stock USDM button in and it did the same thing (stays on even with power off). Since an LED pulls low voltage, Im not too concerned about it. But can someone please confirm for me whether their stock button stays illuminated all the time?
Thanks!
Thanks bro. I followed your directions and it worked perfect!
Painters Tape is your friend!
The Following User Says Thank You to tripjammer For This Useful Post:
clzzical (03-26-2013)
Old 02-02-2013, 05:41 PM   #89
Zgrinch
Zgrinch's Avatar
Drives: 2013 Limited DGM BRZ
Ok I just ordered. I did not see any "drop down" selections on japanparts.com. I just did a search on. ST83031ST020 and ordered it.
Hope I got it right. Looks very cool - can't wait.
BRZGrincherhood
Zgrinch is offline   Reply With Quote
Old 02-02-2013, 05:53 PM   #90
Zgrinch
Zgrinch's Avatar
I just realized the drop down after I placed my order. I sent them an email and asked to change to #20 ZC6
Hope I get an email Monday confirming I'm getting the right one.
BRZGrincherhood
Old 02-02-2013, 07:41 PM   #91
BugeyedWagon
Suby Specialist
BugeyedWagon's Avatar
Glad I could help! Button looks great and the painters tape is a fantastic idea.
Old 02-12-2013, 02:25 PM   #92
Zgrinch
Zgrinch's Avatar
Came in the mail today! 5 minute install and looks awesome.
STI sweetness!
Thanks for the part info and DIY
BRZGrincherhood
Old 02-12-2013, 02:32 PM   #93
OrbitalEllipses
Drives: Attitude
STI sweetness!
Isn't it awesome? My matching shift knob is teh baus. Didn't even mess with painter's tape, no scratches installing mine a few months ago.
Old 02-12-2013, 02:50 PM   #94
Zgrinch
Zgrinch's Avatar
Sweet. I have this knob with a custom engraving coming in about a week.
526 grams!
http://lathewerks.com/shop/popup_ima...ID=260&image=2
BRZGrincherhood
Old 02-12-2013, 02:53 PM   #95
OrbitalEllipses
Drives: Attitude
Eh, couldn't find a WC Lathewerks knob I liked. That's heavy as hell though; I felt a different moving up 80g from the stock knob.
Old 02-12-2013, 02:57 PM   #96
Zgrinch
Zgrinch's Avatar
The added weight will probably effect 0-60 times . What does the stock one weigh?
BRZGrincherhood
Old 02-12-2013, 03:14 PM   #97
OrbitalEllipses
Drives: Attitude
Less than 200g; between 170g and 190g. STI aluminum knob for MT weighs 260-280g. Scale I used wasn't particularly accurate...
Zgrinch (02-12-2013)
Old 04-14-2013, 11:29 AM   #98
CSSer
Drives: Subaru BRZ
I just got my BRZ, and am having tons of trouble taking out the lower console. I've tried removing the lower passenger knee pad, and sticking my fingers/screwdriver in there to help push the lower console, but can't apply enough force to push it out. I can't even get enough grip to pull the lower console out.
I have a Canadian BRZ model, so the USB portion of that console is located in the glovebox instead.
Anyone in Toronto available to help me with this? I don't mind driving around the GTA too. I think I might just have to go to a subaru dealer to get this installed.
CSSer is offline   Reply With Quote
Push button start Symbiont Cosmetic Modification (Interior/Exterior/Lighting) 5 06-17-2012 01:45 PM
push button start standard? sparrowhawk BRZ First-Gen (2012+) — General Topics 2 03-04-2012 03:52 PM
Push button start general question maxeveland Other Vehicles & General Automotive Discussions 9 02-14-2012 10:13 AM
No push button start a good thing? Syldrin Scion FR-S / Toyota 86 GT86 General Forum 130 12-13-2011 07:06 PM
