#953 | |
Drives: GT86 2013
The tune you are referring to, N10C, is "calid hacked" to work with OFT. Now that you have a Tactrix you should only use native roms (NOT hacked), since the hacked ones confuse EcuFlash. So, you should either flash your native stock rom, N10C, or a K00G tune from OFT. When flashing with EcuFlash, you can use the definitions I recently posted in this thread (post #948). Those definitions work with both N10C and K00G files. You don't not need to convert the OFT RomRaider definitions to EcuFlash format. Don't forget to correct the checksums in EcuFlash. |
#954 |
Drives: 2018 BRZ
thanks
#955 |
Drives: 2018 BRZ
flashed to the K00G e85 map without any issues and will flash to the gas map when the tank is empty.
very appreciative of this forum, especially this thread and mrjj response, no longer stuck on e85. thank you |
#956 |
Drives: 2014 BRZ
Hi all, new here and new to flashing. I've been struggling with getting an OFT OTS tune to work in ecuflash. I was able to read my stock rom, a ZA1JB01C. I'm trying to flash a v4.03 stage 2+ because I recently installed a catless header. I've tried all the relevant xml and 32bit base files I've been able to find including the ones mrjj posted on the last page. I mostly get visibly corrupted tables, but sometimes I cant even open any tables. I can view the OTS rom in romraider with the OFT definitions and everything looks fine. Is this OFT tune one of the calid hacked roms? I'm using a B01C OFT tune. It seems like a definition issue, but I'm running in circles here. Any help is appreciated.
#957 | |
OFT V4 B01C tune is actually an A01G tune internally If your using tactrix just flash an A01G version tune as they are not hacked ues A01G tune and defs |
| The Following User Says Thank You to steve99 For This Useful Post: | solidsnake11 (06-30-2020) |
#958 |
Drives: turbo frs
Dear all
Can I use ZA1JB01C for ZA1JA02G??? |
#959 |
B01C car is usa\canada they have full evap emmissions system fitted. A01G is a euro\australian car they dont have full evap emmisdions system. If you put a B01C rom in an euro\australian A02G car then its going to get a few DTC error codes re the missing evap system. will work the other way round though ie putting an A02G in aB01C car will work fine as AA02G doesnt care about evap emission s system |
| The Following User Says Thank You to steve99 For This Useful Post: | gt7877 (07-04-2020) |
#960 | |
Drives: 2014 BRZ
Below is the relevant part of my log. The last line doesn't make sense to me, does this look normal? [21:20:28.759] opening rom file C:/Users/bshak/Downloads/Stg-2-Plus-v4.03-LC-FSS-ZA1JA01G.bin [21:20:28.847] ZA1JA01G (0 tables) inheriting 32BITBASE (1237 tables) [21:20:28.887] 1310720 byte image read. [21:20:31.549] using metadata XML ID ZA1JA01G from file C:/Users/bshak/Desktop/EcuFlash/rommetadata/subaru/BRZ/ZA1JA01G.xml which inherits XML ID 32BITBASE from file C:/Users/bshak/Desktop/EcuFlash/rommetadata/subaru/Bases/32BITBASE.xml [21:20:31.549] ---notes for 32BITBASE--- 2014/06/20 [Tactrix] Tactrix definition auto cleaned|merged w/ RomRaiderGitHubAlphaMay2014. |
#961 | |
ecuflash and romraider defs are completly different not interchangeable just use A01G tunes and defs, ecuflash comes eith A01G def edit in romraider flash with ecuflash |
#962 | |
Drives: 86 GT
I'm seeing people doing the RR to ECUFlash conversion before flashing to their ECU but based on your instructions at first page it's not required. |
#963 | |
you dont need to convert rom just edit in romraider then just use ecuflash to flash only |
| The Following User Says Thank You to steve99 For This Useful Post: | Compelica (07-10-2020) |
#964 | |
Drives: 2014 BRZ
I got it working with a def from the github link in the first post of the thread. Thanks for all the help. |
| The Following User Says Thank You to lightning For This Useful Post: | steve99 (07-11-2020) |
#965 |
Drives: My17 gt86
Hey guys, not sure if it has been said here yet, but I am looking for the ZA1JK00P def file, can't find it anywhere, I am new to tuning so sorry if I'm just being a noob
#966 | |
There is no K00P opensource definitin file However you can use a K00G rom as substitute in you car |
| Tags |
| ecuflash, tactrix, taxtrix, tuning |
| ECUFlash - Getting close! | xjohnx | Software Tuning | 698 | 03-22-2015 12:10 PM |
| EcuTek Flash finished but now it shows only a Partial Flash... | Cross | Software Tuning | 32 | 02-12-2014 10:55 AM |
| Tactrix Openport | jamesm | Engine, Exhaust, Bolt-Ons | 1 | 01-28-2014 08:27 PM |
| Visconti Tuning - Latest BRZ Flash Info | Visconti | Software Tuning | 6530 | 12-24-2013 10:18 PM |
| Overboost Protection With OFT/EcuFlash? | FrX | Software Tuning | 9 | 10-23-2013 07:27 AM |
