Old 05-19-2020, 05:00 PM   #953
mrjj
Drives: GT86 2013
Originally Posted by brz2000 View Post
blah blah blah ... "Stg-2-Plus-E85-v4.03-LC-FSS-ZA1JN10C.bin", blah blah ... thanks
The tune you are referring to, N10C, is "calid hacked" to work with OFT. Now that you have a Tactrix you should only use native roms (NOT hacked), since the hacked ones confuse EcuFlash.
So, you should either flash your native stock rom, N10C, or a K00G tune from OFT.
When flashing with EcuFlash, you can use the definitions I recently posted in this thread (post #948). Those definitions work with both N10C and K00G files.
You don't not need to convert the OFT RomRaider definitions to EcuFlash format.
Don't forget to correct the checksums in EcuFlash.
mrjj is offline   Reply With Quote
Old 05-19-2020, 10:54 PM   #954
brz2000
Drives: 2018 BRZ
thanks
brz2000 is offline   Reply With Quote
Old 05-22-2020, 04:03 PM   #955
brz2000
Drives: 2018 BRZ
flashed to the K00G e85 map without any issues and will flash to the gas map when the tank is empty.
very appreciative of this forum, especially this thread and mrjj response, no longer stuck on e85. thank you
The Following 2 Users Say Thank You to brz2000 For This Useful Post:
mrjj (05-22-2020), steve99 (05-22-2020)
Old 06-27-2020, 10:29 PM   #956
lightning
Drives: 2014 BRZ
Hi all, new here and new to flashing. I've been struggling with getting an OFT OTS tune to work in ecuflash. I was able to read my stock rom, a ZA1JB01C. I'm trying to flash a v4.03 stage 2+ because I recently installed a catless header. I've tried all the relevant xml and 32bit base files I've been able to find including the ones mrjj posted on the last page. I mostly get visibly corrupted tables, but sometimes I cant even open any tables. I can view the OTS rom in romraider with the OFT definitions and everything looks fine. Is this OFT tune one of the calid hacked roms? I'm using a B01C OFT tune. It seems like a definition issue, but I'm running in circles here. Any help is appreciated.
lightning is offline   Reply With Quote
Old 06-29-2020, 08:21 PM   #957
steve99
Drives: FT86
OFT V4 B01C tune is actually an A01G tune internally
If your using tactrix just flash an A01G version tune as they are not hacked ues A01G tune and defs
solidsnake11 (06-30-2020)
Old 07-04-2020, 05:20 AM   #958
gt7877
Drives: turbo frs
Dear all
Can I use
ZA1JB01C for ZA1JA02G???
gt7877 is offline   Reply With Quote
Old 07-04-2020, 06:53 PM   #959
steve99
Drives: FT86
Originally Posted by gt7877 View Post
Dear all
Can I use
B01C car is usa\canada they have full evap emmissions system fitted. A01G is a euro\australian car they dont have full evap emmisdions system.
If you put a B01C rom in an euro\australian A02G car then its going to get a few DTC error codes re the missing evap system.
will work the other way round though ie putting an A02G in aB01C car will work fine as AA02G doesnt care about evap emission s system
gt7877 (07-04-2020)
Old 07-09-2020, 09:34 PM   #960
lightning
Drives: 2014 BRZ
Thanks for the response, but I'm having the same issue after switching over to A01G files. Using the metadata zip that mrjj posted recently. I can't open any tables in ecuflash, but everything looks fine in romraider. I tried using the OFT xml and the rom wouldn't open at all (in ecuflash).
Below is the relevant part of my log. The last line doesn't make sense to me, does this look normal?
[21:20:28.759] opening rom file C:/Users/bshak/Downloads/Stg-2-Plus-v4.03-LC-FSS-ZA1JA01G.bin
[21:20:28.847] ZA1JA01G (0 tables) inheriting 32BITBASE (1237 tables)
[21:20:28.887] 1310720 byte image read.
[21:20:31.549] using metadata XML ID ZA1JA01G from file C:/Users/bshak/Desktop/EcuFlash/rommetadata/subaru/BRZ/ZA1JA01G.xml
which inherits XML ID 32BITBASE from file C:/Users/bshak/Desktop/EcuFlash/rommetadata/subaru/Bases/32BITBASE.xml
[21:20:31.549] ---notes for 32BITBASE---
2014/06/20 [Tactrix] Tactrix definition auto cleaned|merged w/ RomRaiderGitHubAlphaMay2014.
Old 07-09-2020, 11:09 PM   #961
steve99
Drives: FT86
ecuflash and romraider defs are completly different not interchangeable
just use A01G tunes and defs, ecuflash comes eith A01G def
edit in romraider flash with ecuflash
Old 07-10-2020, 01:20 AM   #962
Compelica
Compelica's Avatar
Drives: 86 GT
@steve99 just to clarify - you won't need the definitions converted from RR to ECUFlash only if we are flashing the ROM? Since if we are able to create flash-only definitions for stock ROMs which aren't defined, and we aren't editing the ROMs in ECUFlash?
I'm seeing people doing the RR to ECUFlash conversion before flashing to their ECU but based on your instructions at first page it's not required.
Compelica is offline   Reply With Quote
Old 07-10-2020, 01:30 AM   #963
steve99
Drives: FT86
you dont need to convert rom
just edit in romraider then just use ecuflash to flash only
Compelica (07-10-2020)
Old 07-10-2020, 08:40 AM   #964
lightning
Drives: 2014 BRZ
I guess I should've been more clear, I was using the OFT xmls in romraider, in ecuflash I was using the metadata zip that mrjj posted here.
I got it working with a def from the github link in the first post of the thread. Thanks for all the help.
The Following User Says Thank You to lightning For This Useful Post:
steve99 (07-11-2020)
Old 09-20-2020, 10:49 PM   #965
Andrew862017
Drives: My17 gt86
Hey guys, not sure if it has been said here yet, but I am looking for the ZA1JK00P def file, can't find it anywhere, I am new to tuning so sorry if I'm just being a noob
Andrew862017 is offline   Reply With Quote
Old 09-22-2020, 06:29 AM   #966
steve99
Drives: FT86
There is no K00P opensource definitin file
However you can use a K00G rom as substitute in you car
ecuflash, tactrix, taxtrix, tuning
ECUFlash - Getting close! xjohnx Software Tuning 698 03-22-2015 12:10 PM
EcuTek Flash finished but now it shows only a Partial Flash... Cross Software Tuning 32 02-12-2014 10:55 AM
Tactrix Openport jamesm Engine, Exhaust, Bolt-Ons 1 01-28-2014 08:27 PM
Visconti Tuning - Latest BRZ Flash Info Visconti Software Tuning 6530 12-24-2013 10:18 PM
Overboost Protection With OFT/EcuFlash? FrX Software Tuning 9 10-23-2013 07:27 AM
