Old 08-05-2015, 08:36 PM   #953
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by MAPerformance View Post
So sadly it wasn't that actual engine that hit it's weak point unfortunately. We were messing around with external throttle body injectors controlled by a separate fuel box which failed to shut off the fuel during a dyno run and actually caused it to hydro lock itself, causing a rod to escape. Oh well, these things happen in testing.
And, approximately what power level were you at?
Old 08-06-2015, 01:33 AM   #954
meWant
Drives: '16 BRZ Limited
this is crucial information
meWant is offline   Reply With Quote
Old 08-06-2015, 01:42 AM   #955
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Uh, im reaaaaallllly interested in how much this engine weighs, thanks in advance
Old 08-06-2015, 07:17 AM   #956
Calum
That Guy
I'm just gonna go out on a limb and say, less than an FA20.
Old 08-06-2015, 10:59 AM   #957
MAPerformance
Drives: Asphalt FRS
I don't know the exact number, but somewhere north of 510whp.
MAPerformance is offline   Reply With Quote
The Following User Says Thank You to MAPerformance For This Useful Post:
Calum (08-06-2015)
Old 08-06-2015, 12:49 PM   #958
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I wouldnt be surprised
Old 08-06-2015, 01:17 PM   #959
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
I was interested...
At what point, if ever, does trying to pop the stock block go from fun to "Seriously, what the hell?!?"
That being said, I had absolutely no interest in an Ecoboot Mustang and have still been religiously following this thread. Had no interest, past tense. Well done!
I've been interested since I first heard they were going back to a 2.3l turbo 4 cyl. I would really love for them to switch to the 3.5 ecoboost, but the performance gains from a SOHC 2.3 ford turbo from the 80's were almost on par with what they're getting from this one.
If this one proves to be close to as bullet proof as that one, I'll really like it.
I may even consider swapping it into my twin.
Jaden
Jaden is offline   Reply With Quote
Old 08-06-2015, 01:55 PM   #960
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
Just read this thread based on @Bergen23 commenting on the gains, holy shit
Showing my EB 'Stang buddy
drewbot is offline   Reply With Quote
Old 10-01-2015, 10:57 AM   #961
MAPerformance
Drives: Asphalt FRS
Sorry for the lack of updates. We have been busy with the WRX and Fiesta ST projects as well. But we haven't given up on the EBM! We decided to pull the engine out and build it for some bigger power. We went with a full sleeve, I-beam rod set up. Still using stock compression ratio. The cylinder head is still stock at this time for now. We have upgraded to a 6266 and a larger "race intercooler". Here are the current numbers as of last night. We hit the limit of the stock 3-bar map sensor at 27psi. We are going to be installing a 4-bar and shooting for 35psi shortly which should get it into the mid 600's.
Here is one of the earlier pulls from the day
[ame="https://www.youtube.com/watch?v=Kf5V_zqTEZA&sns=fb"]MAPerformance AdamTuned 530whp/475wtq Ecoboost Mustang Pull - YouTube[/ame]
The Following 5 Users Say Thank You to MAPerformance For This Useful Post:
Calum (02-23-2016), kch (10-01-2015), kmbkk (10-01-2015), raven1231 (10-07-2015), roddy (10-01-2015)
Old 10-06-2015, 11:46 AM   #962
bfrank1972
Drives: 2013 FR-S Argento
Just thought I'd revive this thread a bit - I have to say, I've always been on the fence about Mustangs, but this thing might just sway me over. Could be my next automotive investment - just tremendous bang for the buck. I know it's still early but anyone drive one of these yet?
bfrank1972 is offline   Reply With Quote
Old 10-06-2015, 12:39 PM   #963
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I can't wait to drive one next Tuesday at Sebring. Then to ask when they are doing the same with the Focus RS!
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following 2 Users Say Thank You to Dave-ROR For This Useful Post:
Diode Dynamics (10-07-2015), WolfpackS2k (10-07-2015)
Old 10-06-2015, 01:38 PM   #964
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Probably not raw enough for you.
Be sure to post your impressions.
Old 10-06-2015, 02:37 PM   #965
juliog
juliog's Avatar
Drives: 86
I drove the car a while ago. Reposting from another forum:
I only did 3 laps on the GT350R, it was my first time at Laguna Seca IRL, and I'm an average HPDE driver. My impressions:
- I expected to be pinned into the back seat smashing the throttle on 2nd gear but, somehow the car didn't actually feel 500HP fast to me. Very smooth power delivery with no drama, probably thanks to the massive tires and the 3750lbs curb weight with two persons in it. Mind you, I got the same feeling when driving the F8x M3. You don't realize how fast you're going until you look at the speedo.
- Power seemed to peak well before the 8200rpm redline. I don't know, last few hundred RPMs felt a bit underwhelming. But I'm used to peaky NA cars (S2000, FR-S)..
- Engine and exhaust sounded amazing, I'll give it that. It's actually not that loud inside the car... sounds better outside than inside
- I liked the Recaro seats a lot. But you're sitting so low (for a Mustang), and the hood is so high, that it's very hard to place the front tires with confidence and accuracy. Not a big problem in most corners, but going down the corkscrew was scary, not knowing how close I was to putting tires off the track. I assume more seat time in the Mustang and familiarity with Laguna Seca would alleviate this. Again, I'm used to cars with great forward visibility.
- Steering felt good. I was surprised by how small the steering wheel was. Wish steering ratio was faster (but I say this of most cars).
- Nice shifter, relatively long clutch travel with no feel for engagement point. But overall intuitive and very easy to drive. I remember heel and toeing was easy too (much better relative pedal placement than my FR-S).
- Tons of grip. 295F and 305R tires, honestly I didn't come close to exploring the lateral grip limits of the car. Neither did my instructor, who seemed to go barely 6/10ths on my ride along lap (still much faster than me!).
- Handling wise, it had the classic FR balance, very predictable and easy to drive.
- I'm not sure what the damper settings were, but the ride was extremely smooth and going over the the rumbled strips, you would get more feedback from the steering wheel than from the chassis.
- Great stopping power, although I didn't work the brakes as hard as I could have, out of respect for the instructor . But this was one area that was certainly confidence inspiring. Braking was never a worry.
- Car does looks great in person.
- Drove with TC on, it kicked in a couple times, in a rather obvious way. I remember the M3/M4 electronics being way more subtle, allowing for some small, controlled slip angle and making you feel like a hero.
Overall, a very fast, obviously track ready car. Even though I felt connected to the car, it felt physically big to me and the poor front visibility made me slow down in many places to ensure I didn't put wheels off. I personally like smaller cars. It's funny because when I drove the F8x M3, I got the opposite reaction: the car felt smaller and lighter than it really was.
For sure, the best muscle/pony car I've ever driven.
(We were not allowed to record video inside the car. Bummer.)
juliog is offline   Reply With Quote
The Following 4 Users Say Thank You to juliog For This Useful Post:
avishenoy1 (10-06-2015), bfrank1972 (10-07-2015), BRZPDX (10-07-2015), phobos512 (10-07-2015)
Old 10-06-2015, 03:07 PM   #966
avishenoy1
avishenoy1's Avatar
Drives: 2015 FR-S Release Series 1.0
http://www.caranddriver.com/ford/mustang-shelby-gt350
Oh god this car looks incredible. 0-60 in 3.7, 1/4 mile in 12s flat.
No boost, no problem.
avishenoy1 is offline   Reply With Quote
2015, couldhavehadav8, ecoboost, ford, mustang
Mustang at it again! (Shelby GT350) FX86 Off-Topic Lounge [WARNING: NO POLITICS] 18 10-26-2016 09:46 PM
2013 Mustang GT or wait for 2015 Mustang GT or new model 370Z (390Z)...??? JayNutter Other Vehicles & General Automotive Discussions 48 01-13-2013 11:03 PM
1966 Ford Mustang T-5R Wes B. Other Vehicles & General Automotive Discussions 33 12-11-2012 10:38 PM
2011 Shelby Mustang Enhancement Detail OTD Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 5 05-24-2012 07:24 PM
Your thoughts of the Ford Mustang Abflug Other Vehicles & General Automotive Discussions 31 08-25-2011 11:15 AM
