Old 10-04-2013, 01:53 PM   #939
DJCarbine
Thupercharged
DJCarbine's Avatar
Just replaced tensioner, belt (with gates racing), and pulley near the supercharger. The Gates 38006 does need the bearing pressed another 2-3mm into the pulley for the belt to sit centered, very easy with a shop press or even a large vice.
The ACDELCO 38006 has the exact same bearing as the GATES 38006, however the metal pulley is MUCH nicer on the gates. The ACDELCO pulley had imperfections in the pulley that did not sit well with me (almost looked like a raised weld seam in the middle, not cool).
No more chirps!
2013 FRS
Vortech V3 11psi
Old 10-04-2013, 02:59 PM   #940
Dezoris
Dezoris's Avatar
No more chirps!
How much performance did you gain? Are you going to do a smurf blue engine dress up kit now?
Old 10-04-2013, 03:01 PM   #941
DJCarbine
Thupercharged
DJCarbine's Avatar
I gained approx 4psi @ 2500rpm, and my gauges also turned blue
2013 FRS
Vortech V3 11psi
Old 10-04-2013, 03:25 PM   #942
ft86me
ft86me's Avatar
Drives: 2013 FRS
Does anyone know the diameter for the hose going to the bypass that needs to go onto the new race blow off ? I may need some more for extension purposes because I trimmed some a while back for my aem boost gauge for routing purposes and may not have enough in terms of length
ft86me is offline   Reply With Quote
Old 10-04-2013, 03:35 PM   #943
Rick@Vortech
Drives: Scion FR-S
5/32 vacuum hose. You're better off just running to your local auto parts store & buying about 4ft (or however much you think you'll need) of hose so you have plenty to work with. Better than using a bunch of hose menders.
Rick@Vortech is offline   Reply With Quote
The Following User Says Thank You to Rick@Vortech For This Useful Post:
ft86me (10-04-2013)
Old 10-04-2013, 03:35 PM   #944
ft86me
ft86me's Avatar
Drives: 2013 FRS
Originally Posted by Rick@Vortech View Post
5/32 vacuum hose. You're better off just running to your local auto parts store & buying about 3ft-4ft of hose so you have plenty to work with. Better than using a bunch of hose menders.
Life saver for sure. Thanks dude!!!
Old 10-04-2013, 03:45 PM   #945
ft86me
ft86me's Avatar
Drives: 2013 FRS
Well looks like I had six ft of that at my shop. Looks like I'm good to go!!
The Following User Says Thank You to ft86me For This Useful Post:
Rick@Vortech (10-04-2013)
Old 10-04-2013, 10:30 PM   #946
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
Oil fed supercharger is here. Awe yeahhh
Nolan
pheoxs is offline   Reply With Quote
Old 10-04-2013, 11:28 PM   #947
ft86me
ft86me's Avatar
Drives: 2013 FRS
ok just for my reference what belt and pulley should I get for my backup? i see things about a blue belt and a regular and something about our OE pulley or a replacement? can you guys point me in the right direction. I want to buy one of each for just in case (pulley and belt)
Old 10-05-2013, 01:21 AM   #948
Rick@Vortech
Drives: Scion FR-S
Check page 42, I believe.
ft86me (10-05-2013)
Old 10-05-2013, 01:29 AM   #949
ft86me
ft86me's Avatar
Drives: 2013 FRS
you guys don't sell replacements?
Old 10-05-2013, 01:37 AM   #950
DJCarbine
Thupercharged
DJCarbine's Avatar
Gates 38006 Pulley
Gates K060975RB belt
The pulley is a somewhat common steel pulley to replace the plastic pulley people have issues with (me included), the belt is the blue "racing belt" from gates. Supposed to last longer, and perform better under high stress
2013 FRS
Vortech V3 11psi
The Following User Says Thank You to DJCarbine For This Useful Post:
ft86me (10-05-2013)
Old 10-05-2013, 01:38 AM   #951
ft86me
ft86me's Avatar
Drives: 2013 FRS
Gates 38006 Pulley
The pulley is a somewhat common steel pulley, the belt is the blue "racing belt" from gates. Supposed to last longer, and perform better under high stress
Life saver thanks dude !!! Anything special to do with that pulley or simple business?
Old 10-05-2013, 11:10 AM   #952
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
Gates 38006 Pulley
Any one know if this is the belt to run the 3.0 pully? Or is that one a different size?
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there.
please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback
Adeets is offline   Reply With Quote
Vortech Supercharger denverizzles Forced Induction 176 10-19-2013 07:48 PM
New Vortech Supercharging System Information... Brian@Vortech Forced Induction 306 11-08-2012 06:49 PM
Supercharging the GT86 Billy2224 Engine, Exhaust, Transmission 13 06-05-2012 04:58 PM
Turbo/Supercharging Your FRS BoostJunkie Engine, Exhaust, Transmission 123 05-18-2012 07:26 PM
Supercharging: the forgotten form of FI madfast Engine, Exhaust, Transmission 76 03-02-2012 06:06 PM
