Old 03-13-2013, 07:46 PM   #939
NateKthx
Drives: 15' WRX
I searched this thread for 18x7.5 +45... thoughts?
Thanks in advance!
NateKthx is offline   Reply With Quote
Old 03-13-2013, 11:01 PM   #940
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Thanks in advance!
That should fit neatly within the fenders without issue.
Slick is offline   Reply With Quote
The Following User Says Thank You to Slick For This Useful Post:
NateKthx (03-14-2013)
Old 03-14-2013, 01:57 AM   #941
ScionFR-S
ScionFR-S's Avatar
Drives: Raven Scion FR-S
I'm getting these installed Saturday so there's no turning back now, if anyone with tires and wheels close to this can help me out or people with absolute assurance of their answer and not a ballpark that could answer would be awesome....
Running 18x8.5 front 235/40 +38 offset
Rear: 18x9.5 +38 offset 265/35
Will I run into any issues running on stock height and alignment ? Rubbing against springs fenders etc? All I need to know if I would be okay with this setup
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
ScionFR-S is offline   Reply With Quote
Old 03-14-2013, 09:20 AM   #942
ScionFR-S
ScionFR-S's Avatar
Bump
Old 03-14-2013, 09:47 AM   #943
itdansharpe
itdansharpe's Avatar
Not 100% sure about that offset, but I test fitted the following with no issues at all (dropped about 1").
Running 18x8.5 front 245/35 +45
Rear: 18x9.5 +45 offset 265/35
New: 2014 6MT Asphalt Rota Titan 17x9, RS-3 V2, Skunk2 Pro-C, Eibach Sway Bars, Password:JDM Strut Tower Bar, Perrin MCB, StopTech Stainless Lines, Hawk HP+, Nameless 3" Exhaust, VG Sharkfin, FIVE:AD Spoiler, DDM Tuning HID's 5k, HID
Old: 2013 6AT Boosted Firestorm..
itdansharpe is offline   Reply With Quote
Old 03-14-2013, 09:54 AM   #944
Slick
Slick's Avatar
@ScionFR-S:
From ITDan's setup above, you are effectively running 7-8mm outward more. I think you'll just clear in front, back not so sure. You will probably need to dial-in camber either way to make sure the top of the tire dips into the wheelwells.
Have a look at my setup photos higher on this page and you'll see what I mean. I have test fitted 18x9 +35 and it pokes alot up front.
I'll have to install crash bolts and lowering springs to give me the additional camber that I need to bring the rim/tire in enough to make it work. I intend to run a 245 wide all around.
Old 03-14-2013, 10:04 AM   #945
Slick
Slick's Avatar
And don't forget folks that we have a great fitment calculator located here:
http://www.frsproject.com/tire_size.php
Thanks to @itdansharpe for this!
It is even stickied in this Wheels/Tires section!
itdansharpe (03-14-2013)
Old 03-14-2013, 10:09 AM   #946
itdansharpe
Of course inside strut/wheel well clearance is still unknown in my calculations, so please use it as a guide and not a be all end all solution.
Old 03-14-2013, 10:27 AM   #947
ScionFR-S
ScionFR-S's Avatar
Originally Posted by Slick View Post
@ScionFR-S:
Using the calculator as I did before I ordered my stuff it shows to be just flush to the fender but not close to the fender on top.... I'm running a 235/40 in the front and a 265/35 in the rear both with +38 offsets
Old 03-14-2013, 12:20 PM   #948
ScionFR-S
ScionFR-S's Avatar
bump
Old 03-14-2013, 11:54 PM   #949
dokterdewe
dokterdewe's Avatar
Drives: an automatic lightning red 86
Send a message via Yahoo to dokterdewe
A 15mm spacer will effectively make it a +27 offset. It is going to be close but I think you should be inside the fender so slightly.
What size tire are you planning?
Hi thanks for the help.. i am planning to use Dunlop Direzza DZ101 225/40 R18.. or maybe 215/40..
Which one is better option ?
dokterdewe is offline   Reply With Quote
Old 03-15-2013, 09:01 AM   #950
Slick
Slick's Avatar
They are both pretty close so not that much difference and both will work on the wheel width you have.
dokterdewe (03-17-2013)
Old 03-15-2013, 01:03 PM   #951
ScionFR-S
ScionFR-S's Avatar
Front: 18x8.5 +38 with 235/40 are FLUSH
Rear: 18x9.5 +38 with 265/35 poke 1/2 Inch but DO NOT RUB ... no issues with this meaty fitment ... pics coming soon
Love proving some guys wrong that said this setup would def rub and i would need coilovers and cambers .. HA !
Old 03-15-2013, 01:10 PM   #952
itdansharpe
Stock suspension?
Yay for my tire fitment calculator.. you just proved it worked!
fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
