Old 11-27-2012, 11:58 PM   #925
tuckdaddy
Because Racecar
tuckdaddy's Avatar
Drives: 2013 Asphalt FRS
gourgeous pics! i wish i had my car.....
I got an update on my CEL issue and more tests are apparently needed bfore toyota is willing to ship parts to fix the issue and was told by my service advisor that it was actually recomended by toyota technical that the car be given back to me to just see if i would have another code CEL code thrown. hoping this get fixed soon as i miss this car! just fustrated with toyota that all though there is an obvious issue coperate insists on performing the same test yet again to come to the same conclusion.
tuckdaddy is offline   Reply With Quote
Old 11-28-2012, 01:10 AM   #926
FRSatx
Drives: UltraMarineFRS-MT
Scared to take my car in since the CEL light is still showing today. Did not get a chance to take it today. @tuckdaddy What dealership is you car currently at?
FRSatx is offline   Reply With Quote
Old 11-28-2012, 01:37 AM   #927
tuckdaddy
Because Racecar
tuckdaddy's Avatar
It's currently at Toyota of Boerne and they're taking good care of me.
I'd be more scared to drive with the light on than getting it fixed. If there is a real mechanical issue.
Do you know what codes your throwing? Did your traction slip light come on too?
Old 11-28-2012, 01:47 AM   #928
FRSatx
The slip light came on also but turned off shortly afterward. How do you know what code is showing up. Like I said so far the car is acting completely normal. I will be taking it in tomorrow hopefully...
Old 11-28-2012, 02:08 AM   #929
tuckdaddy
Because Racecar
tuckdaddy's Avatar
Originally Posted by tuckdaddy View Post
Attachment 20816
Threw three codes today after filling up
P0011
C1201
B1410
I had the camshaft get out of sync/position
Had all the traction and abs systems fail
And the transponder in the key go haywire
When I had the codes pulled I was told the car is good to drive after the CEL went away and everything reset itself before heading to the dealer after letting it sit. Hoping it really isn't something major... Been running smoothly for the past hour
I had the dealer pull the codes on tech stream and wipe them to see if I threw them again before i could get back to Boerne since I know the guys who work on my car and am nothing but pleased with them. But the codes above are what I pulled both times in both Boerne and San Marcos's dealers
Old 11-28-2012, 09:49 AM   #930
Dynotronics1
Have they updated the latest ecu calibration?
Dynotronics1 is offline   Reply With Quote
Old 11-28-2012, 09:52 AM   #931
Dynotronics1
Btw, to make ya'll drool a bit; e85 testing has shown an increase of 20 whp so far!
And speed density tuning is in beta as of today. If I can get Napoleon to leave his track car with me a few days more ill have results from the SD files to share
Old 11-28-2012, 09:58 AM   #932
tuckdaddy
Because Racecar
tuckdaddy's Avatar
I was told I have it and we even thought hell maybe I just needed a reflash. But it looks like a new ECU and the cam assembly
Once the car is problem free I may have to look into that e85 tune
Old 11-28-2012, 10:44 AM   #933
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
How are you compensating for air density changes caused by the air temperature? I know normally that isn't factored into a MAP based system, but it is for MAF.
Is there some sort of compensation map that is plotted to take care of that?
Ranatsu is offline   Reply With Quote
Old 11-28-2012, 12:16 PM   #934
Dynotronics1
There are new VE tables for the SD as well as some compensation features. You can also run in a hybrid set up with SD and MAF if you really dont wanna change the MAF to larger. We can also easily scale for the bigger housings if you like
Old 11-28-2012, 12:49 PM   #935
dpgdave
Has anyone had issues with the Tire Pressure Indicator Light after swapping rims? Mine lit up after an Enkei RFP1 install with factory valves and tires. The TMPS light wouldn't go off after the install so I took it up to Universal Toyota. I waited there 3 hrs to hear they need to order new sensors. Warrantied luckily. I'm 4 days into the wait for the parts to arrive...
dpgdave is offline   Reply With Quote
Old 11-28-2012, 01:16 PM   #936
tuckdaddy
Because Racecar
tuckdaddy's Avatar
those sensors are sensitive i cant tell you how many i broke on my tacoma wheeling or had fall off
Old 11-28-2012, 02:48 PM   #937
Ranatsu
Cone basher
TXIC - Weekly Thursday Night Meet
Where: Red Robin (281/1604 area)
When: 7:30pm
Reservation under: Kiff or Subaru Car Club
For those interested in coming out tonight:
Full details can be found on the FB event page (link). If possible, confirm attendance there as it really helps me and ensures we have enough seats. (Note: you need to be apart of the FB TXIC SA group (link) to see the event - A few of us can add you)
Old 11-28-2012, 05:24 PM   #938
Dynotronics1
When: 7:30pm
I might swing by to chat if you guys don't object to me driving a non BRZ!!
Official What are you listening to thread? TRDMAN Off-Topic Lounge [WARNING: NO POLITICS] 2322 09-15-2026 06:05 AM
Official FT-86 Specs / Info Thread Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 203 09-09-2019 10:43 PM
The official hand drawn thread. LexusFman FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 12 04-06-2013 05:11 AM
Official 2011 WRC Season Thread 4agze Other Vehicles & General Automotive Discussions 4 04-01-2011 04:13 PM
