Old 08-17-2015, 12:12 AM   #9227
LucidMomentum
No Money, No Problems
LucidMomentum's Avatar
Alright everyone, I know have @tyrantcf's ESC and OFT in my posession, so before I start doing the install tomorrow, do I need a special tune on the OFT if I'm just using the on/off pedal switch for now? Does the stage 1 tune work with the ESC? The only mods I have are a TRD Exhaust.
Old 08-17-2015, 12:23 AM   #9228
KoolBRZ
KoolBRZ's Avatar
Congratulations! Don't use stg 1 tunes, they can't handle the pressure and timing changes. Download the OFT ESC tunes from the OFT website. Remember, you have to click on site map to find the current downloads. I'm still testing changes to the OFT map, but they work pretty good. I can't change them very much, before I've gone too far. I'm also adding @Wayno's additions to my tunes except for pressure and timing related tables.
Old 08-17-2015, 12:34 AM   #9229
KoolBRZ
KoolBRZ's Avatar
Originally Posted by Sojhinn View Post
Tried helping @j_Zer0 today with his procede install through text messages. We got everything running except the procede doesn't seem to be sending voltage to the phantom.
Anyone have a suggestion? All the Taps look good and the box is moving on the procede software.
Is the ESC getting power to the readout? Can he take a picture of the battery and ESC controller connections?
Old 08-17-2015, 12:46 AM   #9230
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
He's reconnected the foot switch and its fine. So it looks like voltage isn't coming out of the procede
Installed Mods:
Old 08-17-2015, 01:00 AM   #9231
KoolBRZ
KoolBRZ's Avatar
Does he have the 4 wire foot switch? If so, he needs to connect the Procede black wire to the foot switch connector's red wire.
Old 08-17-2015, 01:11 AM   #9232
KoolBRZ
KoolBRZ's Avatar
Also, if the RPM tap isn't working, it will show movement sideways, but not up and down, and the ESC won't boost. Does the Procede show RPM's moving up and down?
Old 08-17-2015, 01:36 AM   #9233
GT86meMR2
GT86meMR2's Avatar
Drives: MR Spyder/GT86
Is It possible to post an updated list? Just to know somewhat when It's our turn so i know around what Time It's Time to pay for It :p
GT86
Current Mods: Ace Header with 350 OP-Berk Frontpipe-Miltek Resonated Catback-OFT-k&n drop in filter
GT86meMR2 is offline   Reply With Quote
Old 08-17-2015, 02:54 AM   #9234
gtfapollo
gtfapollo's Avatar
Drives: Velocity Orange
Blaze it!
gtfapollo is offline   Reply With Quote
Old 08-17-2015, 08:42 AM   #9235
Sojhinn
Sojhinn's Avatar
Yes to the four wire connector and yes to all the movement.
No dice still. That's why I decided to ask since it was unlike anything else I have helped with.
Installed Mods:
Old 08-17-2015, 10:56 AM   #9236
LucidMomentum
That's the one for the ESC + OFH, right? I don't have the header so I was wondering if I should go with that one or the Stage 1 tune. Thanks for the head's up!
My rule of thumb is "mild acceleration/cruise up to 2500 RPMs, with almost no boost, and real acceleration/showing off with up to full boost from about 3500 RPMs on up. I can send you what I have so far. What is your CAL ID? I hope it's A00D, otherwise I'll need to change like 20+ tables. I took the stage 2 91 Oct ESC tune, added @Wayno's additions, (except timing), massaged the AVCS normal and safe tables a bit, and called it good.
Also I just found out last night when I read the ECU and such that my CAL ID is D00D. Hope that doesn't make it too much of a pain to get a version of your a/t tunes for the OFT and Procede?
Old 08-17-2015, 07:17 PM   #9237
j_Zer0
Drives: Asphalt FRS 2014
Technically, I have a three wire connector. Wires are black, red and orange.
ESC+OFH | Borla Axleback | Helix clear side markers | Opti-coat | Beatsonic v2 Sharkfin antenna | TRD lowering springs | TRD sway bars | 18" Enkei Kojins + PSSs
j_Zer0 is offline   Reply With Quote
Old 08-17-2015, 07:48 PM   #9238
j_Zer0
Looks like I got a bad Procede unit. Yesterday I was getting data but no boost. Today the Procede won't even go online. Reaching out to the guys at Open Flash.
Old 08-17-2015, 08:27 PM   #9239
KoolBRZ
KoolBRZ's Avatar
D00D is doable. I've got the def file.
I'll send you a PM when it's ready.
Old 08-17-2015, 08:39 PM   #9240
KoolBRZ
KoolBRZ's Avatar
Sounds like you have some loose connections, unless you soldered them. You're sure the Procede black wire is connected to the ESC to foot switch connector red wire, right? If the Procede is unresponsive you may have a bad power or ground connection.
I used the included wiretaps, but first I stripped back the insulation, then I squirted some dielectric tune-up grease into the tap's metal bits to prevent oxidation ruining the connections. Then I crimped them down hard with pliers till they clicked.
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
