Old 05-03-2016, 07:53 PM   #897
keen as
keen as's Avatar
Drives: 86 GT MT
Originally Posted by stevo585 View Post
The system should be pulling around 160 amps. 4000W/24V = AMPS
I am not talking about the dump cables (I have edited previous post)
keen as is offline   Reply With Quote
Old 05-03-2016, 07:53 PM   #898
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Whoa... The power cables melted?
Installed Mods:
Old 05-03-2016, 07:57 PM   #899
keen as
keen as's Avatar
Drives: 86 GT MT
No, the melted component was the CONNECTOR I used for the 12V power cable. The rest is fine.
Old 05-04-2016, 11:30 AM   #900
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
Originally Posted by super josh View Post
The elm327 Bluetooth dongle that we use with the torque app to connect to the OBD2 port has a facility to measure and report the battery voltage measured at the adapter (as well as the one measured at the ecu), I just re-purposed it to measure the ESC voltage by connecting the input to the ESC voltmeter to the dongle and reconfiguring the circuit slightly as it wasn't originally designed to measure 30 volts.
Then I created a custom PID in the torque app with an appropriate scalar and voila one ESC display on your phone or tablet.
I use the appradio unchained reloaded to get the torque app displayed on my Pioneer headunit.
What we need now is for Shiv and his team to provide this facility using the PROceed ecu and to output the data with a custom PID onto the car's canbus, then we could get the same functionality that I have shown without having to modify the bluetooth dongle.
If you need any specific details, then just ask
Josh
I have no idea what you're saying
but i like it lol
Old 05-05-2016, 02:54 PM   #901
super josh
Drives: Mazda mx5
If I remember the aux charger that rob recommended was around 80 bucks and was an easy install.
This sounds interesting, do you have any more details?
Josh
super josh is offline   Reply With Quote
Old 05-05-2016, 02:55 PM   #902
Sojhinn
Sojhinn's Avatar
Josh
It's in a post in the original thread let me try to find it.
Installed Mods:
Old 05-05-2016, 03:00 PM   #903
Sojhinn
Sojhinn's Avatar
Josh
http://www.ft86club.com/forums/showp...postcount=9100
Installed Mods:
Old 05-05-2016, 04:03 PM   #904
super josh
Drives: Mazda mx5
I don't appear to be able to 'thank' your post, so 'thanks' anyway
Josh
Old 05-05-2016, 04:52 PM   #905
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
Josh
not until you've got 10 posts!
Old 05-05-2016, 08:49 PM   #906
Algreen
Guest
Posts: n/a
That stinks, but glad you caught it before it caused a fire.
I had to extend the 12v+ lead about 20" and used a hard crimp connector and a 10 gauge wire. Should be ok.
Old 05-05-2016, 08:50 PM   #907
Algreen
Guest
Posts: n/a
What's the purpose of the extra charger when the dump pack is getting charged by the charging circuit in the controller all the time?
Old 05-05-2016, 08:53 PM   #908
Sojhinn
Sojhinn's Avatar
The extra charger helps charge the batteries faster. It also has the added benefit of not overworking the controller and causing it to enter one of its three levels of heat protection.
I have an aux charger and I think it's awesome. Not needed at all but awesome.
Installed Mods:
Old 05-06-2016, 08:40 PM   #909
Algreen
Guest
Posts: n/a
So you run this charger from your cigarette lighter (or hard wired) directly to your dump pack as an auxiliary charger, aiding the controller's charging circuit even though the source (the cars 12v system) is the same? And this reduces heat on the controller and charges the batteries faster between boost? Genius!
Old 05-07-2016, 11:41 AM   #910
super josh
Drives: Mazda mx5
Thanks for the details Sojhinn Just to follow on from Algreen's post, presumably this aux charger runs in parallel to the existing charger to take some of the strain off it and, as you say, stop it going into one of its heat protection modes?
You mention that you are successfully running an aux charger, is it this model or something else?
Thanks again for more insight,
Josh
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6049 06-25-2026 10:40 PM
Full throttle Electric Supercharger Build Thread fenton Forced Induction 11315 04-07-2025 06:42 PM
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
phantom supercharger restrictions? Shinigunz Forced Induction 12 05-13-2014 03:28 AM
Drift-Office : Phantom Supercharger - Tuned! Drift-Office Forced Induction 67 10-25-2013 09:51 AM
