#897 | |
Drives: 2022 Subaru BRZ Limited 6MT
I'm not new to stick shift cars but kind of new to heel/toe, the thing I didn't get until recently is you need to lift up your whole foot, use the ball of your foot on the brake then kind of angle out your heel and roll over onto the accel pedal. At least that's what's worked for me.
#898 |
Drives: 2018 BRZ
In my experience there are two main ways to heel and toe:
I used method 1 in my Focus ST, but switched to method 2 in my BRZ. |
#899 | |
Drives: '23 BRZ Limited
It was really difficult on a sportbike before they started using slipper clutches. My bike years ago did not have one. Don't get it right and you lock up the rear going into a corner. |
#900 |
Drives: 2020 BRZ tS
Method #1 for me also.
#901 |
Drives: 2022 BRZ
I installed my SRP pedal cover. I have been using their wider gas pedals in most of my cars.
#902 |
Drives: 2022 BRZ Ltd, 2025 Ascent Touring
On my first cars, heel and toe was more double-clutch shifting. Some of my cars did not have a synchro first gear and the other gears had synchronizers that were total crap and would only work if you took your time between gears or were good at heel and toe. My later cars had full synchro gearboxes with floating synchro rings and not the press-on-the gear hub type. We affectionately call our transmissions "Crash Boxes". One time I missed a shift from second to third on my Triumph and knocked a tooth off the cluster gear. I still had a first gear if I needed it, but it went thunk, thunk, thunk. Those of you that were born after the first Moon Landing won't know of those joys.
The ants are our friends, theyre blowing in the wind, that ants are blowing in the wind.
#903 |
Drives: 2022 crystal white BRZ
Cleaned the ole beast. I've gotten most of the stuff done and settled, that I want to do right now, so I've been driving it around town mostly.
#904 |
You're fitment and stance look great! Details?
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
#905 | |
my feet aren't big enough for #1, I'm stuck with #2 as my only option and even then I have to lift my foot up and angle it almost 45 degrees to reach the accel pedal...but I'm a women's size 8.5
#906 | |
TRACKBREAD
The Cusco pedal cover may help you: https://www.counterspacegarage.com/c...s-toyota-gr-86 |
#907 |
#908 |
Drives: 22 BRZ limited
Do you think the rears would clear with a bit less camber? -1.7 or so?
#909 |
Probably so, I ran the wheels/tires for a couple weeks with some 3mm spacers up front on stock suspension and didn't have any rubbing. It pokes a little bit out the top without negative camber.
#910 |
Drives: '22 BRZ
Going to be a fun weekend... Straight from Japan.
| WHAT DID YOU DO TO YOUR FRS TODAY? | KalbiCool88 | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 11-04-2015 10:36 PM |
| Do you know what today is? | Yruyur | Off-Topic Lounge [WARNING: NO POLITICS] | 26 | 01-21-2015 02:51 PM |
| just got my OFT today...help please! | carlitosway6891 | Software Tuning | 9 | 02-20-2014 10:05 PM |
| TODAY, TODAY, I GET IT TODAY!!!! :D | Trashed675 | Scion FR-S / Toyota 86 GT86 General Forum | 54 | 02-14-2013 01:16 AM |
| sat in a BRZ today | NESW20 | BRZ First-Gen (2012+) General Topics | 8 | 03-31-2012 08:53 AM |
