Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 04-27-2022, 12:54 AM   #897
diga
Drives: 2022 Subaru BRZ Limited 6MT
Originally Posted by joemysterio View Post
Awesome!
I never learned to heel toe and when I tried for the first time the other day, I struggled mightily and also learned that I have small feet because I would miss most of the time LOL. Maybe my technique was off... but in any case, I'm going forward with getting this pedal. Thanks!
I'm not new to stick shift cars but kind of new to heel/toe, the thing I didn't get until recently is you need to lift up your whole foot, use the ball of your foot on the brake then kind of angle out your heel and roll over onto the accel pedal. At least that's what's worked for me.
diga is offline   Reply With Quote
Old 04-27-2022, 09:34 AM   #898
Ohio Enthusiast
Drives: 2018 BRZ
In my experience there are two main ways to heel and toe:
  1. Left edge of the shoe on the right side of the brake pedal. Roll the foot to the right to catch the gas pedal with the right edge of the shoe.
  2. The ball of the foot on the brake pedal, shoe angled diagonally between the gas and brake pedal. Catch the gas pedal with the bottom right of the shoe.
I find that it greatly depends on the car, shoe size and shoe dimensions as well as personal preference and kinematics (position of the seat and steering wheel, proportions of the leg, etc.).
I used method 1 in my Focus ST, but switched to method 2 in my BRZ.
The Following User Says Thank You to Ohio Enthusiast For This Useful Post:
The Red One (04-27-2022)
Old 04-27-2022, 10:59 AM   #899
OkieSnuffBox
Drives: '23 BRZ Limited
That's how I do it. I was never able to keep consistent pressure on the brake pedal doing it the other way.
It was really difficult on a sportbike before they started using slipper clutches. My bike years ago did not have one. Don't get it right and you lock up the rear going into a corner.
The Following User Says Thank You to OkieSnuffBox For This Useful Post:
soundman98 (04-27-2022)
Old 04-27-2022, 11:15 AM   #900
LancePower
Drives: 2020 BRZ tS
Method #1 for me also.
LancePower is offline   Reply With Quote
Old 04-27-2022, 01:37 PM   #901
rBobby
Drives: 2022 BRZ
I installed my SRP pedal cover. I have been using their wider gas pedals in most of my cars.
rBobby is offline   Reply With Quote
The Following 2 Users Say Thank You to rBobby For This Useful Post:
Flarpswitch (04-27-2022), Panda Grahams (04-27-2022)
Old 04-27-2022, 06:24 PM   #902
Flarpswitch
Flarpswitch's Avatar
Drives: 2022 BRZ Ltd, 2025 Ascent Touring
On my first cars, heel and toe was more double-clutch shifting. Some of my cars did not have a synchro first gear and the other gears had synchronizers that were total crap and would only work if you took your time between gears or were good at heel and toe. My later cars had full synchro gearboxes with floating synchro rings and not the press-on-the gear hub type. We affectionately call our transmissions "Crash Boxes". One time I missed a shift from second to third on my Triumph and knocked a tooth off the cluster gear. I still had a first gear if I needed it, but it went thunk, thunk, thunk. Those of you that were born after the first Moon Landing won't know of those joys.
The ants are our friends, they’re blowing in the wind, that ants are blowing in the wind.
Flarpswitch is offline   Reply With Quote
The Following 2 Users Say Thank You to Flarpswitch For This Useful Post:
PBR (04-27-2022), soundman98 (04-27-2022)
Old 04-27-2022, 09:45 PM   #903
CZ6T
Drives: 2022 crystal white BRZ
Cleaned the ole beast. I've gotten most of the stuff done and settled, that I want to do right now, so I've been driving it around town mostly.
CZ6T is offline   Reply With Quote
The Following 2 Users Say Thank You to CZ6T For This Useful Post:
Flarpswitch (04-29-2022), kaesu (04-30-2022)
Old 04-27-2022, 11:41 PM   #904
OkieSnuffBox
You're fitment and stance look great! Details?
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
Old 04-28-2022, 01:11 AM   #905
diga
my feet aren't big enough for #1, I'm stuck with #2 as my only option and even then I have to lift my foot up and angle it almost 45 degrees to reach the accel pedal...but I'm a women's size 8.5
Old 04-28-2022, 09:08 AM   #906
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
The Cusco pedal cover may help you:
https://www.counterspacegarage.com/c...s-toyota-gr-86
Old 04-28-2022, 10:44 AM   #907
CZ6T
I'm on superstreet-1 coilovers, lowered about 1.5" (last I checked, it may have settled a smidge more) and about -2.5⁰ camber all around. The wheels are 17x9" apex arc 8 with 245/40R/17 sumitomo HTR PS-03 tires.
OkieSnuffBox (04-28-2022), Racecomp Engineering (05-03-2022)
Old 04-28-2022, 11:08 AM   #908
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Do you think the rears would clear with a bit less camber? -1.7 or so?
Old 04-28-2022, 11:21 AM   #909
CZ6T
Probably so, I ran the wheels/tires for a couple weeks with some 3mm spacers up front on stock suspension and didn't have any rubbing. It pokes a little bit out the top without negative camber.
Old 04-28-2022, 07:25 PM   #910
Panda Grahams
Panda Grahams's Avatar
Drives: '22 BRZ
Going to be a fun weekend... Straight from Japan.
Panda Grahams is offline   Reply With Quote
The Following 4 Users Say Thank You to Panda Grahams For This Useful Post:
DougNuts (04-30-2022), jongers (04-29-2022), kaesu (04-29-2022), PBR (04-29-2022)
WHAT DID YOU DO TO YOUR FRS TODAY? KalbiCool88 Scion FR-S / Toyota 86 GT86 General Forum 1 11-04-2015 11:36 PM
Do you know what today is? Yruyur Off-Topic Lounge [WARNING: NO POLITICS] 26 01-21-2015 03:51 PM
just got my OFT today...help please! carlitosway6891 Software Tuning 9 02-20-2014 11:05 PM
TODAY, TODAY, I GET IT TODAY!!!! :D Trashed675 Scion FR-S / Toyota 86 GT86 General Forum 54 02-14-2013 02:16 AM
