Old 02-16-2023, 12:12 PM   #869
Riftur
Riftur's Avatar
It has been a while since I have used my OBD2 adapter with the torque app. I had a different phone and had no issues at all. I tried to use it yesterday and I am able to pair the bluetooth adapter but it does not stay connected. I read that even though it shows its not connected, it still might be but when I try to select the adapter in torque, it says there are no adapters available. anyone know how to fix this? Thanks
Riftur is offline   Reply With Quote
Old 02-16-2023, 04:00 PM   #870
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
Originally Posted by PikachuBRZ View Post
Hey. I have the Elm 327 and Torque pro. Everything works great except for fuel pressure. I've tried to use all 3 options for fuel pressure and i get no data. I see that other people are able to monitor the HPFR without having to do anything. I've tried deleting and reinstalling torque pro but it hasn't helped. Is there any direction I can get towards what to try next or maybe the PID
you might need to get a better ECU reader. That being said, when I used a ELM 327, I was able to read the fuel pressure no problem. Only the oil temp PID didn't work for me.
Old 02-16-2023, 04:01 PM   #871
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
That sounds like an issue between the phone and the ecu reader. Try leaving the ecu reader unplugged and disconnected to everything else for a few minutes, then try plugging it back into the car while its off and connect to it.
Or buy a new one lol
Old 11-27-2023, 09:26 AM   #872
qiumaoyuan
qiumaoyuan's Avatar
Drives: 2017 BRZ MT, 2009 Civic sedan AT
Hi, Does anyone knows how to ready 'Knock Correction Learn Value' and 'Knock Correction'?
qiumaoyuan is offline   Reply With Quote
Old 03-04-2024, 10:00 PM   #873
tarzan_nojane
tarzan_nojane's Avatar
Drives: 2014 FR-S
Originally Posted by TheBoss77 View Post
If anybody is looking for the automatic transmission temperature PID, this one worked on my '17 86.
OBD2 Mode and PID: 0105
Minimum Value: 0
Maximum Value: 200
Scale factor: x1
Unit type: C
Equation: A-40
OBD Header: TCM
This is absolutely identical to Engine Coolant Temperature
tarzan_nojane is offline   Reply With Quote
android, app, boost, gauges, torque
Torque app for android question Brody602 Electronics | Audio | NAV | Infotainment 8 01-08-2015 04:53 PM
Torque for Android Freeman Scion FR-S / Toyota 86 GT86 General Forum 7 11-22-2012 11:05 PM
Android Torque app questions Craig Engine, Exhaust, Transmission 1 11-12-2012 04:14 PM
Bluetooth OBD scanner and Android Torque - less than 25 shipped whataboutbob Engine, Exhaust, Transmission 7 10-20-2012 01:15 PM
Android Tablet + torque CharlieChaos Electronics | Audio | NAV | Infotainment 3 10-04-2012 08:23 PM
