#855 |
Drives: 2012 FR-S
Our congratulation to Fricke and his awesome victory this past weekend. +1.5s over the closest competitor!
On the topic of videos, here's 1 min clip of our testing day with new AMB aero package (70% complete) [ame="https://www.youtube.com/watch?v=oyVJYqvxEYg"]ACE/Delicious Tuning + AMB Aero test 31/05/16 - YouTube[/ame] Now, off to LeMans! Happy Driving, Team ACE |
#856 |
Drives: 2015 AOZORA EDITION
what is the reason needed to use the harden engine mounts? i figured i show get a set too but if its not mandatory right now then ill hold off.
#857 |
Drives: Whiteout Scion FR-S
I was told it will reduce fatigue on the headers during hard cornering.
Sent from my SM-N920T using Tapatalk |
#858 | |
Drives: Toyota GT86
I guess it all comes down to how were out your mounts are, and how well you sell of the radiant heat from the header. My header is wrapped with thermal bandage, and that seems to do the trick. |
| The Following 3 Users Say Thank You to Fricke For This Useful Post: |
#859 |
Drives: Toyota GT86
this is what i think is the fast lap
![]() [ame="https://www.youtube.com/watch?v=X8rJB1_-Cn0"]Timeattack NU rond 1 Kinnekulle - YouTube[/ame] |
| The Following User Says Thank You to Fricke For This Useful Post: | ysu (06-24-2016) |
#861 | |
Drives: Toyota GT86
![]() But as you said, the rear end do lose traction from not doing it, so I guess if I managed to get it all right, and use more of the track for some parts, the 01:01xxx should be there. |
#862 |
Drives: Toyota 86 GTS
UEL with stock cat back:
250 with stock cat back and not rubbing on skid plate: They will sound different at the top because UEL was on E85 so revving much higher, where as ace is on 98 ron. Apart from that, the ace is louder due to more overlap, but smoother due to EL obviously. I tried keeping the windows up as much as possible, but will have to listen around the wind noise. |
#863 |
Legendary Member
Drives: HyperBlue BRZ
Not sure if someone already has but, can someone post Ace Header exhaust cold start, idle, and some revs? Stock FP and catback are okay, if Tomei 60R perfect, curious to see how it sounds with other combinations
#864 | |
Drives: N/a
Sent from my SM-N910T using Tapatalk |
#865 |
It's going to sound like every other header with the same cat back.
#866 |
Drives: GT86
@Wayno that's for the videos, I am currently running OFH and thinking of switching to ACE cs400. I have an auto and from memory you said UEL is a little better for us auto guys. What's you thought champ.
Sent from my iPad using Tapatalk |
#867 | |
On the other hand if you want EL sound, the ace is the only choice. That is unless you can keep stock fp and muffler, then el/uel difference is hardly noticeable. |
| The Following User Says Thank You to Wayno For This Useful Post: | ollie (06-24-2016) |
#868 | |
Drives: GT86
Thanks buddy, already running e85 on your tunes. Will just keep it as is. Sent from my iPad using Tapatalk |
| Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? | alanhung85 | CANADA | 6 | 10-21-2014 11:41 PM |
| RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP | NickFRS | Engine, Exhaust, Transmission | 44 | 04-19-2014 06:42 PM |
| Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! | TopGearSolutions | Engine, Exhaust, Bolt-Ons | 82 | 04-14-2014 09:16 PM |
| Gutted cat stock header vs aftermarket catless header NA application | stevo585 | Engine, Exhaust, Transmission | 8 | 04-04-2014 05:12 PM |
| Wanted: UEL header with Perrin header back and tune. | skye67 | Engine, Exhaust, Transmission | 7 | 12-21-2013 11:34 PM |
