Old 06-07-2016, 09:44 AM   #855
AceHeader-MT
AceHeader-MT's Avatar
Drives: 2012 FR-S
Our congratulation to Fricke and his awesome victory this past weekend. +1.5s over the closest competitor!
On the topic of videos, here's 1 min clip of our testing day with new AMB aero package (70% complete)
[ame="https://www.youtube.com/watch?v=oyVJYqvxEYg"]ACE/Delicious Tuning + AMB Aero test 31/05/16 - YouTube[/ame]
Now, off to LeMans!
Happy Driving,
Team ACE
AceHeader-MT is offline   Reply With Quote
The Following 3 Users Say Thank You to AceHeader-MT For This Useful Post:
CSG Mike (06-09-2016), Fricke (06-09-2016), solidONE (06-08-2016)
Old 06-09-2016, 01:48 AM   #856
86Tony
Drives: 2015 AOZORA EDITION
what is the reason needed to use the harden engine mounts? i figured i show get a set too but if its not mandatory right now then ill hold off.
86Tony is offline   Reply With Quote
Old 06-09-2016, 01:50 AM   #857
_Se7en_
Drives: Whiteout Scion FR-S
I was told it will reduce fatigue on the headers during hard cornering.
Sent from my SM-N920T using Tapatalk
_Se7en_ is offline   Reply With Quote
Old 06-09-2016, 03:41 AM   #858
Fricke
Drives: Toyota GT86
There's no direct need for, I'm driving oem mounts on my track car and newer have had any problems.
I guess it all comes down to how were out your mounts are, and how well you sell of the radiant heat from the header.
My header is wrapped with thermal bandage, and that seems to do the trick.
Fricke is offline   Reply With Quote
The Following 3 Users Say Thank You to Fricke For This Useful Post:
AceHeader-MT (06-09-2016), CSG Mike (06-09-2016), ysu (06-24-2016)
Old 06-12-2016, 08:22 AM   #859
Fricke
Drives: Toyota GT86
this is what i think is the fast lap
[ame="https://www.youtube.com/watch?v=X8rJB1_-Cn0"]Timeattack NU rond 1 Kinnekulle - YouTube[/ame]
The Following User Says Thank You to Fricke For This Useful Post:
ysu (06-24-2016)
Old 06-12-2016, 11:15 AM   #860
TkTk
TkTk's Avatar
Drives: 2014 TRD GT86 CUP, 2014 991 GT3
Congratulations on the win!
From the video I noticed that you don't use auto blip or heel-toe in downshifting. This will shorten your clutch life and make the rear lose traction.
TkTk is offline   Reply With Quote
The Following User Says Thank You to TkTk For This Useful Post:
Fricke (06-12-2016)
Old 06-12-2016, 02:44 PM   #861
Fricke
Drives: Toyota GT86
Yes that's a good observation, I didn't get the heel toe to work for me that well, actually did lose time trying to get it right, so did skip that for the finals
But as you said, the rear end do lose traction from not doing it, so I guess if I managed to get it all right, and use more of the track for some parts, the 01:01xxx should be there.
Old 06-21-2016, 04:37 AM   #862
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
UEL with stock cat back:
250 with stock cat back and not rubbing on skid plate:
They will sound different at the top because UEL was on E85 so revving much higher, where as ace is on 98 ron.
Apart from that, the ace is louder due to more overlap, but smoother due to EL obviously.
I tried keeping the windows up as much as possible, but will have to listen around the wind noise.
The Following 3 Users Say Thank You to Wayno For This Useful Post:
CSG Mike (06-21-2016), Hicklinc (06-21-2016), ollie (06-22-2016)
Old 06-21-2016, 05:10 AM   #863
nova.86
Legendary Member
nova.86's Avatar
Drives: HyperBlue BRZ
Not sure if someone already has but, can someone post Ace Header exhaust cold start, idle, and some revs? Stock FP and catback are okay, if Tomei 60R perfect, curious to see how it sounds with other combinations
nova.86 is offline   Reply With Quote
Old 06-21-2016, 05:11 AM   #864
Hicklinc
Drives: N/a
Oops its on the other independent testing thread
Sent from my SM-N910T using Tapatalk
Hicklinc is offline   Reply With Quote
Old 06-21-2016, 05:47 AM   #865
Wayno
Wayno's Avatar
It's going to sound like every other header with the same cat back.
chaoskaze (06-21-2016), CSG Mike (06-21-2016), tony-brz (02-19-2017)
Old 06-22-2016, 08:31 AM   #866
ollie
ollie's Avatar
Drives: GT86
@Wayno that's for the videos, I am currently running OFH and thinking of switching to ACE cs400. I have an auto and from memory you said UEL is a little better for us auto guys. What's you thought champ.
ollie is offline   Reply With Quote
Old 06-22-2016, 09:43 AM   #867
Wayno
Wayno's Avatar
First, I wouldn't change if you have access to e85. Second, i think final drive will give you more satisfaction for your money. Third, the free and public OFH avcs tables are already refined, where as the performance of the ace will come down entirely to your tuner.
On the other hand if you want EL sound, the ace is the only choice. That is unless you can keep stock fp and muffler, then el/uel difference is hardly noticeable.
The Following User Says Thank You to Wayno For This Useful Post:
ollie (06-24-2016)
Old 06-24-2016, 07:27 AM   #868
ollie
ollie's Avatar
Drives: GT86
Thanks buddy, already running e85 on your tunes. Will just keep it as is.
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 11:41 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 06:42 PM
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! TopGearSolutions Engine, Exhaust, Bolt-Ons 82 04-14-2014 09:16 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 05:12 PM
Wanted: UEL header with Perrin header back and tune. skye67 Engine, Exhaust, Transmission 7 12-21-2013 11:34 PM
