Old 06-20-2012, 12:14 PM   #71
Hanzo
Hanzo's Avatar
Drives: Waiting for the ND Miata
Originally Posted by CzRceCar View Post
Definitely doesn't sound normal :\
What are you comparing to? This is the only D4-S Subaru engine made.
Hanzo is offline   Reply With Quote
Old 06-20-2012, 12:15 PM   #72
Hanzo
Hanzo's Avatar
Originally Posted by Jayde View Post
Mine chirps at a low RPM only. Say 1000rpm or lower. Basically, whenever the DI kicks on is when I hear it, but only after the car has been driven for some time.
That is exactly how mine is.
Old 06-20-2012, 01:17 PM   #73
davisk6
There is another post floating around here where Subaru posted an update to technicians explaining that this "chirping" is part of the dual DI/Port injection system and is completely normal. There is some pretty high pressure fuel injection going on here and the noise is the DI system managing that pressure.
davisk6 is offline   Reply With Quote
Old 06-20-2012, 01:24 PM   #74
Jayde
Jayde's Avatar
Unless I'm thinking of a different one, that explained the ticking sound, which is normal.
Jayde is offline   Reply With Quote
Old 06-20-2012, 01:43 PM   #75
Moto-P
Moto-P's Avatar
Drives: Many types of cars in R&D.
Originally Posted by fenton View Post
I notice mine chips a bit too. rev it up just a bit and it stops but at idle you can hear it.
Mine makes a faint whistling noise too. It first I thought it was the EGR system bleeding out of my Cusco catch tank, but not sure.
I am suspecting that its either that or some high capacity line of 4D-S system. Regardless, I doubt it is a malfunction of any sort. I'll keep posted if you I hear anything from Toyota side of things.
Moto Miwa
R&D Driving Engineer, Product Designs
Consulting for Cusco, OEM+, RS-R, Toyota Japan, and Unplugged Performance.
Moto-P is offline   Reply With Quote
The Following 3 Users Say Thank You to Moto-P For This Useful Post:
Hanzo (06-20-2012), Jayde (06-20-2012), Sigh-on-Rice (06-20-2012)
Old 06-20-2012, 02:10 PM   #76
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
Thanks for stopping in Moto. I know you have been having fun with the car longer then a lot of us had. So if you are not to concerned nor am I.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 06-20-2012, 02:26 PM   #77
driftartist
Kurenai Samurai
driftartist's Avatar
Drives: Red and manual
mine does it too i am sure it is normal we are all overreacting cause it is new and we dont want anything wrong with it...
driftartist is offline   Reply With Quote
Old 06-20-2012, 02:46 PM   #78
xcelir8brz
Drives: 2013 BRZ Limited
subscribed
xcelir8brz is offline   Reply With Quote
Old 06-20-2012, 02:59 PM   #79
Jayde
Jayde's Avatar
I'm sure we're just overreacting.
Old 06-20-2012, 03:05 PM   #80
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Crap I forgot to check mine.. sorry Jayde. I'll check it tonight if it's not raining when I get home.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 06-20-2012, 03:08 PM   #81
Jayde
Jayde's Avatar
No problem.
Old 06-20-2012, 06:19 PM   #82
fistpoint
Drives: Supercharged Golf Cart
Yes, and they are full of shit or explaining away a different sound than the cricket.
Did you guys not listen to the 2 videos back to back? If it's normal, they ALL would do it. Clearly this is not the case because of the video where no cricket noise is heard. Why doesn't that car/video do it?
Honda refused to acknowledge the 3rd gear grind for a year or more, what makes Subaru any different when admitting to screw ups?
fistpoint is offline   Reply With Quote
The Following User Says Thank You to fistpoint For This Useful Post:
csaba (06-20-2012)
Old 06-20-2012, 06:34 PM   #83
davisk6
My car does it. Every other BRZ I'm come across does it.
The situation only presents itself after the car has been driving for some time. My commute typically runs about 90 minutes every day and I can tell you that after each run, the sound can be heard.
Old 06-20-2012, 08:04 PM   #84
driftartist
Kurenai Samurai
we will be fine guys just remember we are ll under warranty
Hard shifting into first gear; normal? blalor Engine, Exhaust, Transmission 54 08-31-2017 09:57 PM
Idle issue? yayforaddison Issues | Warranty | Recalls / TSB 891 07-14-2016 10:42 AM
What function can it be used for, the idle button place yuli8466 Cosmetic Modification (Interior/Exterior/Lighting) 50 01-29-2013 03:17 PM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 12:00 PM
Scion goes normal terrypm Other Vehicles & General Automotive Discussions 21 05-02-2012 10:16 AM
