Old 06-19-2015, 05:34 PM   #71
FRS Justin
Drives: 2013 Asphalt FRS
Originally Posted by nikitopo View Post
It looks that the FA20 engine was revised lately. I found the following differences in the 2015 model (manufacture year after July 2014):
valve-intake
valve-exhaust
camshaft sprocket
camshaft complete-intake (left, right)
camshaft complete-exhaust (left, right)
head and valve set-cylinder
Actually, they have different part numbers. Even the entire engine assembly has a different part number.
Any ideas why they made these changes? Any known issue?
I know about the valves because I had to order a custom set they are longer. Go to supertech valve and they list the specs. The valve swap was done in 2013.5 to current. I believe the rocker changed too I can't remember. long day and night
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 06-23-2015, 06:56 AM   #72
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
So, we verified that at least the intake valves are changed. The new ones are longer:
This doesn't look to be just a change in the source of parts. It seems to be an actual change.
There was also a plan to replace some internal parts with others with less friction. I am not sure if we have already some of these parts changed in the 2015 & 2016 car models.
Old 06-29-2015, 03:24 PM   #73
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
Any input regarding known engine internal changes over the years with the FA20?
@celek @cf6mech @FT-86 SpeedFactory @FullBlown @Element Tuning @CSG Mike @Evasive Motorsports
We know the rocker pivots are different and have different oiling. I believe, but don't hold me to it that the crappy rocker arms were different but still crappy (It's like a Billy Bob made it in his garage)
Element Tuning is offline   Reply With Quote
Old 06-29-2015, 08:35 PM   #74
meWant
Drives: '16 BRZ Limited
Originally Posted by sw20kosh View Post
Advice for 2015 owners: don't dyno your car at 2000 miles...
155 whp 128 wtq on a dynojet where 2013 and 2014's dyno at 165-172 whp
thats odd, I got mine dyno'd at 1800 miles (Back in January) lol
Results were as follows:
Run 1: 163.82whp 138.28wtq
Run 2: 166.45whp 137.75wtq
car was completely stock and this was on a Dynojet as well.
meWant is offline   Reply With Quote
Old 06-29-2015, 08:54 PM   #75
Snake
Drives: ADM Toyota 86 GT
So many variables with Dyno numbers I would take them with a grain of salt.
An example of variables which affect Dyno numbers:
Atmospheric pressure
Temperature
Elevation
Humidity
Dyno age, condition etc
Dyno settings (correction etc)
And that's just a few of the variables which don't apply to the car.
Snake is offline   Reply With Quote
Old 06-30-2015, 01:29 AM   #76
meWant
Temperature
Elevation
Humidity
you're definitely right about that. as long as the car is still fun to drive and brings a smile to your face amirate?
Old 07-09-2015, 03:13 PM   #77
Element Tuning
Well we just ran into this on an engine build. The new rocker arm has different manufacturing in the pivot area mostly and it effects the valve lash adjustment. This is why there is a new valve speced with a longer stem.
Old 07-09-2015, 03:17 PM   #78
celek
Resident Gear Head
celek's Avatar
Well the shooting rocker issue is fixed we hope...
celek is offline   Reply With Quote
Old 07-09-2015, 03:27 PM   #79
Element Tuning
Nope they didn't change the pin locking manufacturing. It's still crappy as ever
Old 07-10-2015, 08:37 AM   #80
celek
Resident Gear Head
celek's Avatar
Have you been kind enough to notify Ferrera and any other valve manufacture of the changes in the valves? I would assume you were building a customer head and discovered the differences ordering valves that no longer fit.
Old 07-10-2015, 02:47 PM   #81
Jeff Lange
Jeff Lange's Avatar
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
I understand what you say, but this doesn't justify to change the entire muffler. You need to change only the exhaust tips. In fact the tips are a separate part:
http://i59.tinypic.com/2wp7yw5.jpg
The tips were separate on Japan/European mufflers, but they actually come with the muffler on North American cars. Even so, the muffler section did change as well, the 2015 muffler has shorter tail pipes. If you put the 2015 tips (which are not exactly the same as the Japan/Europe ones) on a 2013-14 they will stick out further than they do on the 2015 muffler.
Originally Posted by Poodles View Post
Is this a part number change for Toyota or Subaru? I know if Toyota changes the part number there is a reason (and they'll have a supersede note for the old part number).
Where's Jeff Lange when I need him...
As was shown, the valves are actually a different length, so they won't supersede. That said, it looks like the valves actually changed for 2014. 2014-2016 have the same valves, only 2013 has the earlier valves.
The cams changed at the same time as the valves.
The cam gears changed a couple of months later.
Jeff
2011 Lexus IS350 F-Sport 6MT with LSD
1986 Toyota Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
Old 07-11-2015, 11:05 PM   #82
avishenoy1
avishenoy1's Avatar
Drives: 2015 FR-S Release Series 1.0
The theory is that the car is A. still breaking in at 2000 miles. Either that or
B. my engine is a lemon
C. very very very bad tank of gas
D. high humidity
E. combination of A C &/or D
So my 2015 is right around 2000, picked it up about A month ago. I really wanna get in a stock dyno now since I'm itching to install a bunch of parts that I've already bought but you think I should wait?
avishenoy1 is offline   Reply With Quote
Old 07-12-2015, 10:59 PM   #83
celek
Resident Gear Head
celek's Avatar
Really my 2013 stock in 2012 was 158 with 3000+ miles.
Every engine is different and every dyno and every geographical location / weather that day.
Old 07-13-2015, 04:07 AM   #84
meWant
I think you should be fine, after all there are many things that go into the dyne time and results like so:
Temperature
Elevation
Humidity
Anyone have specs on differences btw 2014 and 2015 FR-S jeepmor Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-25-2014 04:54 AM
Two reviews of the 2015 up - handling differences noted Sport-Tech Scion FR-S / Toyota 86 GT86 General Forum 56 08-13-2014 01:22 PM
The 2015 STI use 2.0T Engine for Nurburing 24H Whitigir Other Vehicles & General Automotive Discussions 6 03-18-2014 04:22 PM
Can anyone confirm the engine in a 2015 Subaru WRX? Figo Other Vehicles & General Automotive Discussions 28 01-01-2014 11:43 AM
FR-S vs. BRZ Differences - Engine/Model Codes Flipside909 Scion FR-S / Toyota 86 GT86 General Forum 5 05-07-2012 02:26 PM
